70 r.r. voltage regulator
#2888007
02/14/21 10:46 AM
02/14/21 10:46 AM
Posts: 80 tampa florida
1badrt
tampa florida
i have a 10 of 69, 70 r.r. that uses the 69 and older voltage regulator. factory wired, is this common? Factory shop manual shows electronic regulator
70 beep beep 383 N96 4spd 68 beep beep, eddy headed 383 4 spd 73 340 chally 73 340 duster
Re: 70 r.r. voltage regulator
[Re: 1badrt]
#2888032
02/14/21 11:33 AM
02/14/21 11:33 AM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
Electronic regulators began to be equipped on some late big Chryslers/Imperials. As far I know these regulators were with 3 terminals ( dunno whyc ), so I find hard to think on 70 models some cars still were able to get mech regulators? Dunno.
[Re: 1badrt]
#2888037
02/14/21 11:41 AM
02/14/21 11:41 AM
Posts: 18,417 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
i have a 10 of 69, 70 r.r. that uses the 69 and older voltage regulator. factory wired, is this common? Factory shop manual shows electronic regulator My bets are someone replaced the harness. Never seen or heard of any factory wired that way.
[Re: NITROUSN]
#2888048
02/14/21 12:03 PM
02/14/21 12:03 PM
Posts: 3,519 Lansing, MI
70gtx440dana
Lansing, MI
i have a 10 of 69, 70 r.r. that uses the 69 and older voltage regulator. factory wired, is this common? Factory shop manual shows electronic regulator My bets are someone replaced the harness. Never seen or heard of any factory wired that way. Agreed...never seen a 70 with the older regulator.
70 Road Runner 383-4 4 speed FJ5 & black guts 70 Charger R/T 440-4 4 speed FJ5 & white guts
[Re: NITROUSN]
#2888064
02/14/21 12:37 PM
02/14/21 12:37 PM
1badrt
tampa florida
factory voltage regulator mounting holes for older regulator, not factory drilled for newer style, i would have to drill holes into firewall to mount newer style
[Re: 1badrt]
#2888355
02/14/21 07:32 PM
02/14/21 07:32 PM
70gtx440dana
Lansing, MI
Something seems questionable here.....by 10/69 they were 3 full months into the 70 production year.....having a 69 and earlier voltage regulator bolt pattern on your firewall is very suspicious.
[Re: 70gtx440dana]
#2888408
02/14/21 09:15 PM
02/14/21 09:15 PM
Posts: 601 Mass
charge70
Mass
Something seems questionable here.....by 10/69 they were 3 full months into the 70 production year.....having a 69 and earlier voltage regulator bolt pattern on your firewall is very suspicious. If you remove the electronic voltage regulator bracket,the early regulator bolts right on.
1970 Dodge Charger R/T S.E.
1969 Dodge Dart GTS 440 M-Code
1970 Dodge Charger 500 383/4-speed w/A.C.
[Re: charge70]
#2888449
02/14/21 10:20 PM
02/14/21 10:20 PM
NITROUSN
Something seems questionable here.....by 10/69 they were 3 full months into the 70 production year.....having a 69 and earlier voltage regulator bolt pattern on your firewall is very suspicious. If you remove the electronic voltage regulator bracket,the early regulator bolts right on. Right. But the poster does not have that. He most likely has a old harness that was installed. His car originally had this mount.
[Re: NITROUSN]
#2889037
02/16/21 08:02 AM
02/16/21 08:02 AM
1badrt
tampa florida
where would you find that bracket, i have found several strange things on this car, hood mount turn signal wiring only had tight side connection
[Re: 1badrt]
#2889097
02/16/21 11:14 AM
02/16/21 11:14 AM
NITROUSN
where would you find that bracket, i have found several strange things on this car, hood mount turn signal wiring only had tight side connection That's because someone had their fingers in it and made it work to their liking. So nothing makes sense because nothing is original.
[Re: 70gtx440dana]
#2889330
02/16/21 06:34 PM
02/16/21 06:34 PM
1badrt
tampa florida
thank you so much for your help
