Re: Real world weight loss program and it` cost..........
[Re: A/MP]
#2887958
02/14/21 08:14 AM
02/14/21 08:14 AM
Posts: 685 pennsylvania
poboyengineering
pennsylvania
That car started as a challenge to go 12.99 for $1299. there is a lot more holes in it than that video shows.
It may be ugly, but it sure is slow.
Girls comb their hair in rear view mirrors and the boys try to look so hard....
[Re: hemi-itis]
#2887964
02/14/21 08:52 AM
02/14/21 08:52 AM
Posts: 9,860 MI, usa
dvw
MI, usa
New carbon fiber hood and scoop. Home made, not super light. But still saved almost 17lbs. Of course I'll have to add paint. Also went to 16 volt so now only one battery, 39 lbs lost there Doug I smell that 9 second slip this season! That damn thing better run an 8 Doug
[Re: hemi-itis]
#2922845
05/15/21 02:58 PM
05/15/21 02:58 PM
Posts: 7,495 Minnesota
Hemi_Joel
Minnesota
Does anyone currently have a good source for chemical milling? I heard Dave Kalasa isn't doing it anymore.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: Hemi_Joel]
#2923447
05/17/21 11:34 AM
05/17/21 11:34 AM
Posts: 19,488 north of coder
moparx
too bad Lee went on to other places. i miss this thread and his constant quest to shed ounces. i wonder if he ever got his under dash wiring sorted out, and how much weight was saved there ?
[Re: A/MP]
#3064249
08/01/22 09:50 AM
08/01/22 09:50 AM
Posts: 10,038 MN
JERICOGTX
MN
Switched out my old 1050 Dominator, for a Thumper 1150, and thought it new carb felt lighter, and sure enough, 2.5lbs lighter then my old carb.
I also upgraded from a steel driveshaft, to an aluminum, and the aluminum shaft is 9lbs lighter.
69 GTX
68 Road Runner
[Re: moparx]
#3116480
01/25/23 04:52 PM
01/25/23 04:52 PM
Posts: 16,495 On the run…
BloFish
On the run…
Saved 4 lbs. today by switching to Lingenfelter rear bumper brackets. I switched the fronts a couple of years ago. They are a quality product if anyone is interested.
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
[Re: dvw]
#3233183
05/16/24 02:55 PM
05/16/24 02:55 PM
Posts: 1,462 Martinsville, IN
cdwmotorsports
Martinsville, IN
I scraped 6lbs of rubber out of the rear wheel wells when installing the new wheels. Doug It's been way to long for this thread to have not had a reply. I put aluminum heads on the Demon for Dragweek
eBay-cdwmotorsports
[Re: ZIPPY]
#3233192
05/16/24 04:11 PM
05/16/24 04:11 PM
cdwmotorsports
Martinsville, IN
I removed 20 lbs of bondo and about 1/2 lb of pop rivets by cutting off my terrible quarter panels and welding on some new ones Wow
eBay-cdwmotorsports
[Re: cdwmotorsports]
#3233194
05/16/24 04:24 PM
05/16/24 04:24 PM
Posts: 17,884 S.E. Michigan
ZIPPY
S.E. Michigan
I'm exaggerating slightly It sure LOOKED LIKE 20 lbs of bondo...and there was definitely enough there to add some weight, though probably less than that exact amount.
Rich H.
Esse Quam Videri
#3233208
05/16/24 06:39 PM
05/16/24 06:39 PM
Posts: 1,841 South Bend
John Brown
South Bend
I scraped 6lbs of rubber out of the rear wheel wells when installing the new wheels. Doug It's been way to long for this thread to have not had a reply. I put aluminum heads on the Demon for Dragweek Ideas on weight loss are great. I once worked for a guy who said 'Throw it up in the air... if it comes back down it's still too heavy.'
#3233217
05/16/24 08:39 PM
05/16/24 08:39 PM
Posts: 1,893 Spahn Ranch
RMCHRGR
Spahn Ranch
I scraped 6lbs of rubber out of the rear wheel wells when installing the new wheels. Doug It's been way to long for this thread to have not had a reply. I put aluminum heads on the Demon for Dragweek In the last few years I've removed a bunch of weight off my Duster. - Removed the stock steel hood and hinges for pin-on fiberglass hood - approx. 75 lbs. Kind of a no brainer. - Removed back seat, replaced with a low, flat platform - maybe 20 lbs total. - Aluminum heads, approx. 45-50 lbs. Another no brainer. - QA1 front end - supposedly 18 lbs (mostly due to aluminum strut rods) - One Kirkey seat - maybe 35 lbs over my old buckets which were 22 lbs. each - Removed all unnecessary wiring - maybe 5 lbs - Generic cross flow radiator vs. Griffin "OE fit" unit, maybe 6-7 lbs. - Stripped off undercoating - only 12 lbs. A lot of work for little gain. - Changed Summit cast aluminum trans pan for Moroso fabricated pan - 2-3 lbs. - Lightweight digital gauges and plastic cluster bezel - 2-3 lbs - Moved trans cooler to rear - negligible weight savings but aids front-to-rear balance - M/T radial front runners vs. Michelin VW radials - not sure yet but perhaps a few lbs. each Actually added some weight back though so it wasn't all positive. I got a set of the old Mopar cast reverse-lip valve covers - those things are 7lbs each! Plus the long studs are likely triple the weight of normal ones. Added at least another 30-40lbs of weight with TTI 1 7/8" headers and 3" full exhaust. That stuff is ridiculously heavy. They flow more air than the 1 5/8 - 1 3/4 step headers but the weight penalty was tough to swallow.
'71 Duster '72 Challenger '17 Ram 1500
[Re: RMCHRGR]
#3233248
05/16/24 11:29 PM
05/16/24 11:29 PM
cdwmotorsports
Martinsville, IN
I scraped 6lbs of rubber out of the rear wheel wells when installing the new wheels. Doug It's been way to long for this thread to have not had a reply. I put aluminum heads on the Demon for Dragweek In the last few years I've removed a bunch of weight off my Duster. - Removed the stock steel hood and hinges for pin-on fiberglass hood - approx. 75 lbs. Kind of a no brainer. - Removed back seat, replaced with a low, flat platform - maybe 20 lbs total. - Aluminum heads, approx. 45-50 lbs. Another no brainer. - QA1 front end - supposedly 18 lbs (mostly due to aluminum strut rods) - One Kirkey seat - maybe 35 lbs over my old buckets which were 22 lbs. each - Removed all unnecessary wiring - maybe 5 lbs - Generic cross flow radiator vs. Griffin "OE fit" unit, maybe 6-7 lbs. - Stripped off undercoating - only 12 lbs. A lot of work for little gain. - Changed Summit cast aluminum trans pan for Moroso fabricated pan - 2-3 lbs. - Lightweight digital gauges and plastic cluster bezel - 2-3 lbs - Moved trans cooler to rear - negligible weight savings but aids front-to-rear balance - M/T radial front runners vs. Michelin VW radials - not sure yet but perhaps a few lbs. each Actually added some weight back though so it wasn't all positive. I got a set of the old Mopar cast reverse-lip valve covers - those things are 7lbs each! Plus the long studs are likely triple the weight of normal ones. Added at least another 30-40lbs of weight with TTI 1 7/8" headers and 3" full exhaust. That stuff is ridiculously heavy. They flow more air than the 1 5/8 - 1 3/4 step headers but the weight penalty was tough to swallow. Great job
eBay-cdwmotorsports
#3233287
05/17/24 09:34 AM
05/17/24 09:34 AM
RMCHRGR
Spahn Ranch
Thanks. In between all that I also Swiss cheesed a couple things. Not sure if any of this made a difference but 'speed holes' are cool.
[Re: RMCHRGR]
#3233296
05/17/24 10:07 AM
05/17/24 10:07 AM
Thumperdart
State of confusion
Been a while and cool to see this post back up at the top. In the last few years I have drilled out more stuff and removed enough other stuff I don't need to get my Dart down to 2867 so far with me. I have a glass dash and an aluminum steering column which should remove a bunch more and hopefully get me close to 2820 which is 200lbs lighter than my last 6.14 at 112.2 pass a few years ago. Should go easy 5's now.....fingers crossed...
