Page 2 of 3 1 2 3
Re: What brand u-joint? [Re: Hemi_Joel] #2886914
02/11/21 08:40 PM
02/11/21 08:40 PM
Southern Alberta
Uberpube Offline
Uberpube  Offline
Southern Alberta
At 580,000 km's on my 3500 work truck, I've done my fair share of U joints. I didn't get good life out of SKF's or Napa's in that truck. I've gotten the most service life out of Dana/Spicer/Mopar U joints. It's all I will buy now for my 3500 and my SRT-10 ram.
Watch this guy's entire series on U-joints, I learned that there is way more to installation than I learned from Chiltons manuals over the years.
I started saving snap rings so when I change a Ujoint, I can do the dial indicator test to get the run out to a minimum, it really makes a big difference in the drivelines smoothness and U joint life.
Re: What brand u-joint? [Re: cudaman1969] #2887025
02/12/21 02:01 AM
02/12/21 02:01 AM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
Originally Posted by cudaman1969
What auto parts stores sell the spicer joint? I need two for my van
Napa has them, but kinda $$$, I buy from Denny's Driveshaft or Summit.
Re: What brand u-joint? [Re: Uberpube] #2887027
02/12/21 02:06 AM
02/12/21 02:06 AM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
Nice!!!! You opened a can of worms I did not want to get into, but the install is everything. I save snaps and even thin them a little If I have to to get the run out perfect. Balancing is overrated, run out and a free moving joint after install is the big ticket.
Re: What brand u-joint? [Re: GMP440] #2887043
02/12/21 05:05 AM
02/12/21 05:05 AM
USA/NY/NY
TiltMentor Offline
TiltMentor  Offline
USA/NY/NY
I'm loyal to Spicer.In my opinion, the best solution for the price-quality ratio.
Re: What brand u-joint? [Re: TiltMentor] #2887566
02/13/21 10:57 AM
02/13/21 10:57 AM
rust belt
Moparite Offline
Moparite  Offline
rust belt
Quote
Get the part # you need then source them out. Spicer used to have a site where all you did was put in your vehicle info and all the u joints on it would come up. It is no longer up and now you have to sort threw the maze of stuff to find what you are looking for. mad
[url=https://www.danaaftermarket.com/search?str=u%20joint&cat1=0&ymmType=AUTO][/url]
Re: What brand u-joint? [Re: Moparite] #2887571
02/13/21 11:23 AM
02/13/21 11:23 AM
rust belt
Moparite Offline
Moparite  Offline
rust belt
Oh, And how do you get links to work here? link didn't work in previous post. Looked for a place to post this but found nothing. I'm on plenty of forums but this one is the only one that asks me "prevent this page from creating additional dialogs" confused Let me try again maybe i can answer my own question.
Link address https://www.danaaftermarket.com/search?str=u%20joint&cat1=0&ymmType=AUTO
Again with "no" as the answer [/url]
again with yes(box checke...r=u%20joint&cat1=0&ymmType=AUTO]
Wanted to try one more but javascrip: void (0) wont let me post link.
Re: What brand u-joint? [Re: Moparite] #2887669
02/13/21 03:41 PM
02/13/21 03:41 PM
moparx Offline
moparx  Offline
just tried your link as above, leaving off everything after the "?".
it works. up
beer
Re: What brand u-joint? [Re: moparx] #2887736
02/13/21 06:38 PM
02/13/21 06:38 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
Curious why they wouldn't have a zerk fitting (the spicer life)? Does that weaken the joint?
Facts are stubborn things.
Re: What brand u-joint? [Re: larrymopar360] #2887760
02/13/21 07:29 PM
02/13/21 07:29 PM
Locomotion Offline
Locomotion  Offline
Absolutely! In fact it is strongly suggested that if a u-joint has a fitting in between the caps, it needs to be positioned so that when under load with the driveshaft, the fitting needs to be under compression. Otherwise, the fitting hole is a prime location for a crack to start if the driveshaft tries to spread the u-joint caps because of the orientation. The cross drilling inside also weakens it over a solid with grease only in the caps.
Re: What brand u-joint? [Re: Locomotion] #2887906
02/13/21 11:40 PM
02/13/21 11:40 PM
iagree scope
I've broken those types oriented correctly and not installed correctly before I bought those cars whiney
Re: What brand u-joint? [Re: cudaman1969] #2887955
02/14/21 07:58 AM
02/14/21 07:58 AM
Australia
Mcode69 Offline
Mcode69  Offline
Australia
Mancini racing carry the spicer joints as well.
Re: What brand u-joint? [Re: Locomotion] #2888052
02/14/21 12:21 PM
02/14/21 12:21 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
Okay, figured there must be good reason. Makes sense.
Re: What brand u-joint? [Re: larrymopar360] #2888058
02/14/21 12:32 PM
02/14/21 12:32 PM
rust belt
Moparite Offline
Moparite  Offline
rust belt
The spicer "life" is just a style of u joint. You can get them with or without zerk fittings.
Re: What brand u-joint? [Re: Moparite] #2888151
02/14/21 01:58 PM
02/14/21 01:58 PM
BDW Online content
BDW  Online Content
Got my Spicer u-joint from rock auto, best price even with shipping
Re: What brand u-joint? [Re: BDW] #2888402
02/14/21 08:59 PM
02/14/21 08:59 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
are the spicers all still made in the U.S.? It's hard to trust Big corporations anymore. Most will source some or all of their product from asia to make more profit. A few years ago I bought Timken wheel bearings for a Malibu. The boxes looked right but the bearings were obvious generic bearings repackaged by Timken. They were probably the lowest bidder oem bearings. I could have spent half the money and bought the same bearing in a store brand box or an EBAY white box.
Re: What brand u-joint? [Re: GomangoCuda] #2888413
02/14/21 09:23 PM
02/14/21 09:23 PM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
I just went to Rockauto website and it says 2 sizes of Spicer for a 70 Charger 440. What size is correct for a 440 with Dana?
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: What brand u-joint? [Re: 70sixpkrt] #2888453
02/14/21 10:27 PM
02/14/21 10:27 PM
GMP440 Offline OP
GMP440  Offline OP
The yoke part is a 7090. Spicer 51309X greasable
5811X non -greasable, lifetime (looks like lot of people are going for the non greasable)
Re: What brand u-joint? [Re: GomangoCuda] #2888964
02/15/21 10:19 PM
02/15/21 10:19 PM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
I just got a pair of the 5-811x last week, made in usa.
Re: What brand u-joint? [Re: 70sixpkrt] #3084908
10/10/22 05:05 PM
10/10/22 05:05 PM
Alabama
David1971 Offline
David1971  Offline
Alabama
Same problem here. I too am ready to order from Rockauto. Been researching on various forums, but still don't know if I need the small 7260 or large 7290 (Spicer 5789X or 5811X). I have a 1971 Barracuda 318/904 with 8 3/4. Do the codes on the broadcast sheet provide a definite answer?
Thanks,
David
Re: What brand u-joint? [Re: David1971] #3085000
10/10/22 10:24 PM
10/10/22 10:24 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Thanks,
David
You should have the smaller 7260 joint unless something has been swapped around twocents beer
Page 2 of 3 1 2 3
