What’s the best valve cover gasket. UPDATE
#2885690
02/08/21 10:30 PM
02/08/21 10:30 PM
Posts: 6,413 Abilene, Texas
fastmark
Abilene, Texas
Ok, these Superperformance gaskets are not Super. On a stock head with stealth heads, they leak. Anybody have the best gasket?
Re: What’s the best valve cover gasket
[Re: fastmark]
#2885700
02/08/21 11:01 PM
02/08/21 11:01 PM
Posts: 1,809 North Dakota
Azzkikrcuda
North Dakota
Never had any luck with Superformance gaskets. I use Moroso Blue 93055 gaskets. If you have aluminum heads and cast valve covers with flat flanges the cheap floppy Fel-pro rubber gaskets work great.
The only Carbs I care about are under the hood!
[Re: fastmark]
#2885718
02/08/21 11:54 PM
02/08/21 11:54 PM
Posts: 43,213 Bend,OR USA
Cab_Burge
[Re: A39Coronet]
#2885750
02/09/21 07:09 AM
02/09/21 07:09 AM
Posts: 10,032 MN
JERICOGTX
MN
Cometic. Rubber with a steel core. No leaks, and reusable.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#2885759
02/09/21 08:20 AM
02/09/21 08:20 AM
fastmark
Abilene, Texas
Ok. I should have said stock valve cover with stealth heads. These super performance are just too hard to squeeze. There recommendations of 25 ft lbs of torques on alum heads for a 1/4” bolt is just too much. There thermostat gaskets is made wrong. The bolt holes are too elongated. Won’t be using them again either.
[Re: fastmark]
#2885768
02/09/21 09:08 AM
02/09/21 09:08 AM
Posts: 10,555 Rittman Ohio
fourgearsavoy
Rittman Ohio
Are you trying to use the pink gaskets with stock stamped valve covers? Greg makes different gaskets for specific applications like yours . It sounds like questions about applications weren't asked before the purchase. Superformance sells a gasket that will work for your particular application all you need to do is ask for the gasket for your valvecover and head combination I use Superformance gaskets on every part of my engine it's dry everywhere :twocents Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: fastmark]
#2885771
02/09/21 09:21 AM
02/09/21 09:21 AM
Posts: 13,198 aZLiViN
J_BODY
aZLiViN
Ok, these Superperformance gaskets are not Super. On a stock head with stealth heads, they leak. Anybody have the best gasket? What part number are they? Appears from your description that you’d want the 3184. All the others state in the catalog “for machined surface/ cast or fabricated valve covers”.
[Re: J_BODY]
#2885814
02/09/21 12:09 PM
02/09/21 12:09 PM
Posts: 2,810 Sobieski Wi
bee1971
Sobieski Wi
Didn’t the factory cast heads have an angle or degree on the valve cover sealing surface along with that same angle or degree on the corresponding factory valve cover
So using a factory valve cover on a flat surface aluminum head is asking for
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
[Re: bee1971]
#2885821
02/09/21 12:32 PM
02/09/21 12:32 PM
Posts: 14,504 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
For a stock v/c and a Stealth Head, I would use a quality cork gasket(felpro), attached/glued to the v/c with ultra black silicone, and dry between the head and gasket.
[Re: fastmark]
#2885829
02/09/21 12:46 PM
02/09/21 12:46 PM
Posts: 31,045 Oregon
AndyF
Ok. I should have said stock valve cover with stealth heads. These super performance are just too hard to squeeze. There recommendations of 25 ft lbs of torques on alum heads for a 1/4” bolt is just too much. There thermostat gaskets is made wrong. The bolt holes are too elongated. Won’t be using them again either. You just bought the wrong gasket for your application.
[Re: 340Cuda]
#2885868
02/09/21 02:33 PM
02/09/21 02:33 PM
Posts: 4,986 new jersey usa
11secdart
new jersey usa
Fel Pro I agree valve covers with tabs to lock the gasket into the cover are best. I had an experience a few years ago with a set of fabricated valve covers as it blew a gasket out top end of the track no damage but I have found that valve covers that are smooth on the bottom with no lip and/or tabs have no means of holding the gasket in place at least on my combination. I went back to the M/P cast ones I have ran for years with no problems. I also have studs with nuts instead of bolts to hold the valve cover in place as it makes gasket placement easier upon removal of the cover.
[Re: fourgearsavoy]
#2886030
02/09/21 08:46 PM
02/09/21 08:46 PM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
Are you trying to use the pink gaskets with stock stamped valve covers? Greg makes different gaskets for specific applications like yours . It sounds like questions about applications weren't asked before the purchase. Superformance sells a gasket that will work for your particular application all you need to do is ask for the gasket for your valvecover and head combination I use Superformance gaskets on every part of my engine it's dry everywhere :twocents Gus All gaskets in my hemi are Superperformance except head and exhaust.
