What’s the best valve cover gasket. UPDATE #2885690
02/08/21 10:30 PM
02/08/21 10:30 PM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
Ok, these Superperformance gaskets are not Super. On a stock head with stealth heads, they leak. Anybody have the best gasket?
Re: What’s the best valve cover gasket [Re: fastmark] #2885700
02/08/21 11:01 PM
02/08/21 11:01 PM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
Never had any luck with Superformance gaskets. I use Moroso Blue 93055 gaskets. If you have aluminum heads and cast valve covers with flat flanges the cheap floppy Fel-pro rubber gaskets work great.
The only Carbs I care about are under the hood!
Re: What’s the best valve cover gasket [Re: fastmark] #2885702
02/08/21 11:03 PM
02/08/21 11:03 PM
Kirkland, Washington
Pacnorthcuda Offline
I used Fel Pro rubber gaskets with my Stealths. The are fine.
Re: What’s the best valve cover gasket [Re: fastmark] #2885705
02/08/21 11:11 PM
02/08/21 11:11 PM
AndyF Offline
AndyF  Offline
The best gasket depends on which valve covers you have. If you have good valve covers then any gasket will work. If your valve covers are bent or warped then you'll need a big thick gasket to have any chance of sealing.
Re: What’s the best valve cover gasket [Re: fastmark] #2885718
02/08/21 11:54 PM
02/08/21 11:54 PM
You need to try the real thick cork and rubber gaskets(1/4 to 1/2 inch thick) out there, Mr. Gasket, SCE and probably all the other big gasket companies make them scope You may, will grin' need to tighten them up several times to get them to seal properly but once you got them sealed up they will not leak anymore scope wrench twocents
Re: What’s the best valve cover gasket [Re: fastmark] #2885747
02/09/21 06:17 AM
02/09/21 06:17 AM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
Moroso blue rubber with steel core hands down. Not sure if they'll work with a OE cover that has the lip but maybe someone can chime in. No worry about gaskets pushing out or needing to seal with RTV, or buying new ones cause they're reusable.
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: What’s the best valve cover gasket [Re: A39Coronet] #2885750
02/09/21 07:09 AM
02/09/21 07:09 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Cometic. Rubber with a steel core. No leaks, and reusable.
69 GTX 68 Road Runner
Re: What’s the best valve cover gasket [Re: JERICOGTX] #2885758
02/09/21 08:16 AM
02/09/21 08:16 AM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
I used to have the old mopar performance chrome valve covers (the tin model, not cast) and would just use the cheap cork style gaskets. They were fine for a one time use. I later upgraded to the Mopar Performace Cast Valve Covers and started using the Moroso blue gasket with steel core. Been on the car for close to 10 yrs now without any issues. I usually check the valves twice a year or so, so they have been on and off many times.
Re: What’s the best valve cover gasket [Re: JERICOGTX] #2885759
02/09/21 08:20 AM
02/09/21 08:20 AM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
Ok. I should have said stock valve cover with stealth heads. These super performance are just too hard to squeeze. There recommendations of 25 ft lbs of torques on alum heads for a 1/4” bolt is just too much. There thermostat gaskets is made wrong. The bolt holes are too elongated. Won’t be using them again either.
Re: What’s the best valve cover gasket [Re: fastmark] #2885768
02/09/21 09:08 AM
02/09/21 09:08 AM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Are you trying to use the pink gaskets with stock stamped valve covers? Greg makes different gaskets for specific applications like yours . It sounds like questions about applications weren't asked before the purchase. Superformance sells a gasket that will work for your particular application all you need to do is ask for the gasket for your valvecover and head combination shruggy
I use Superformance gaskets on every part of my engine it's dry everywhere :twocents
Gus beer
64 Plymouth Savoy
Dana 60
Re: What’s the best valve cover gasket [Re: fastmark] #2885771
02/09/21 09:21 AM
02/09/21 09:21 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
What part number are they? Appears from your description that you’d want the 3184. All the others state in the catalog “for machined surface/ cast or fabricated valve covers”.
Re: What’s the best valve cover gasket [Re: J_BODY] #2885814
02/09/21 12:09 PM
02/09/21 12:09 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Didn’t the factory cast heads have an angle or degree on the valve cover sealing surface along with that same angle or degree on the corresponding factory valve cover
So using a factory valve cover on a flat surface aluminum head is asking for
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: What’s the best valve cover gasket [Re: bee1971] #2885821
02/09/21 12:32 PM
02/09/21 12:32 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
For a stock v/c and a Stealth Head, I would use a quality cork gasket(felpro), attached/glued to the v/c with ultra black silicone, and dry between the head and gasket.
Re: What’s the best valve cover gasket [Re: fastmark] #2885829
02/09/21 12:46 PM
02/09/21 12:46 PM
AndyF Offline
AndyF  Offline
You just bought the wrong gasket for your application.
Re: What’s the best valve cover gasket [Re: AndyF] #2885834
02/09/21 01:05 PM
02/09/21 01:05 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
The only gasket I know of that really fits W9 heads is a very thin Cometic.
However they seem to last and work great.
Re: What’s the best valve cover gasket [Re: 340Cuda] #2885868
02/09/21 02:33 PM
02/09/21 02:33 PM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
Fel Pro I agree valve covers with tabs to lock the gasket into the cover are best. I had an experience a few years ago with a set of fabricated valve covers as it blew a gasket out top end of the track no damage but I have found that valve covers that are smooth on the bottom with no lip and/or tabs have no means of holding the gasket in place at least on my combination. I went back to the M/P cast ones I have ran for years with no problems. I also have studs with nuts instead of bolts to hold the valve cover in place as it makes gasket placement easier upon removal of the cover.
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
Re: What’s the best valve cover gasket [Re: 11secdart] #2885889
02/09/21 03:32 PM
02/09/21 03:32 PM
Johnstown
69dart Offline
69dart  Offline
Johnstown
The reuseable MOROSO blue ones are the BEST I've tried. They are so thick you might need longer bolts. I had to get longer bolts.
I've tried many of them on my roadster and they would always vibrate loose and leak a little. A little oil makes such a mess by the end of the season.
Not the MOROSO ones, they stay tight, stay put and stay dry.
33 Plymouth Roadster - 383 - 5.90 1/8th 9.58 1/4
68 Dart - 340
66 Belvedere - 400
Windy Hollow Garage - https://www.youtube.com/@windyhollowgarage
Re: What’s the best valve cover gasket [Re: 69dart] #2885914
02/09/21 04:10 PM
02/09/21 04:10 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Only times I've had VC gasket problems were on rounded head surfaces or valve train interference.
I pretty much always use cork, glued to the VC & a light smear of grease on the other face.
Obviously the surfaces must be straight & flat.
Make sure intake runners & pushrods & valvetrain aren't interfering.
On one engine, the rocker stands at the ends were actually holding the VC off the head. Beveled them.
On another, the VC spacers I used to make helped with the head surface and rocker clearance using OEM VCs.
Re: What’s the best valve cover gasket [Re: topside] #2886024
02/09/21 08:36 PM
02/09/21 08:36 PM
Oh
P
parksr5 Offline
parksr5  Offline
P
Oh
I use the carbon-x Superformance gaskets on my stock head, stock valve cover combo and it's the best gasket I've ever used. Followed the directions and never a leak.
Re: What’s the best valve cover gasket [Re: fourgearsavoy] #2886030
02/09/21 08:46 PM
02/09/21 08:46 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Gus beer
All gaskets in my hemi are Superperformance except head and exhaust.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
