Re: Engine Diaper [Re: GY3] #2885194
02/07/21 04:41 PM
02/07/21 04:41 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
Belly pan has to have a 2” min depth . I have one on my car . A lot easier than a diaper
....BAD A$$ STREET CAR.....
Re: Engine Diaper [Re: n20mstr] #2885349
02/07/21 10:22 PM
02/07/21 10:22 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
Any pictures of it that you can post?
Thanks, Brian
Re: Engine Diaper [Re: '72CudaRacer] #2885367
02/07/21 11:23 PM
02/07/21 11:23 PM
Wi.
old_racer Offline
old_racer  Offline
Wi.
Here’s a few of a friends 68 cuda
EE12A984-429D-4FC9-AD5A-193AC31429EE.jpeg532669DC-CE95-48D3-BE30-648E739464F4.jpeg9C0C151E-E59E-4A86-B3DA-83BA27080D9A.jpeg
Re: Engine Diaper [Re: n20mstr] #2885396
02/08/21 12:36 AM
02/08/21 12:36 AM
PA
moparacer Offline
moparacer  Offline
PA
The pans dont look like they would do a very good job of containing oil and parts if it kicks a rod out the side of the block...A diaper runs up both sides of the bock to the head gaskets.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Engine Diaper [Re: moparacer] #2885422
02/08/21 05:51 AM
02/08/21 05:51 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
I made my own pan, its lined internally with an absorbent mate. Since I'm using a motor plate I used the engine mounts to connect up to the block. It might not be the prettiest pan in the world, but it passes tech.
Re: Engine Diaper [Re: rebel] #2885527
02/08/21 01:34 PM
02/08/21 01:34 PM
montana
BANDIT Offline
BANDIT  Offline
montana
My pans are wider and attach to the frame or cage, diapers suck! Hard to get off, get oily, hold heat in motor, just have always seemed like a PIA to me. I have a brake in shop, and access to sheet aluminum. It’s kinda fun to bend up your own. I talked with our NHRA tech guy, and he says there is no minimum spec on material until you get into fuel or top Alcohol type cars. I believe the aluminum I use is .029 or .039, have to go look for sure. Usually can use Addell clamps on cage tubing and slugs elsewhere. Always just have 4 attaching points. Just my personal preference tho. Jim.
64 Dodge Coronet 440. In progress
1998. Dodge Avenger. 8.35@165. 4400 DA
250” Neil and Parks Slip Joint. 7.36@183.
4600 DA
242" Mullis Dragster. 6.90@ 200mph
Re: Engine Diaper [Re: old_racer] #2885534
02/08/21 01:45 PM
02/08/21 01:45 PM
New Braunfels, TX
416challenger Offline
New Braunfels, TX
I am having to lookin into this too, the track gave me a hard time last time I was there.
For the guys running belly pans the rules state- The belly pan must extend from framerail to framerail and extend forward of the harmonic balancer and reaward to rear engine plate and must incorporate a minimum 2-inch-high lip on all sides. A nonflammable, oil-absorband liner mandatory inside of retention device. See General Regulations 1:8 in NHRA Rulebook.. I have a stock suspension E Body with a 5.7 hemi and I can not see a way to go frame rail to frame rail. In the belly pans pictured I see they just encase the oil pan, has the track given you a hassle for this?
Re: Engine Diaper [Re: 416challenger] #2885670
02/08/21 09:38 PM
02/08/21 09:38 PM
Wisconsin
sjs64polara Offline
sjs64polara  Offline
Wisconsin
I run a DRE. I’ve had it repaired several times. Service is always quick and easy
