Re: 6.4 hemi CNC program.
[Re: W5DART66]
#2878627
01/22/21 09:51 PM
01/22/21 09:51 PM
Posts: 1,784 PA
W5DART66
PA
[Re: fbs63]
#2879923
01/25/21 02:36 PM
01/25/21 02:36 PM
Posts: 12,423 Kalispell Mt.
HotRodDave
Kalispell Mt.
6.4 BGE head or SRT? I hear the port shape is the same with just different material, Would it work in either casting? how does the flow compare in the lower lift regions like .500 .600 range, I assume 380 is pretty high up there.
[Re: Twostick]
#2880105
01/25/21 07:55 PM
01/25/21 07:55 PM
Posts: 9,719 Home
SRT6776
I hate internal combustion engines!
Home
Just as a point of reference for us mere mortals, what would a stock casting flow?
Kevin 340+ IIRC
[Re: W5DART66]
#2880256
01/26/21 12:55 AM
01/26/21 12:55 AM
Posts: 272 Anchorage, Alaska
metallicareload
Anchorage, Alaska
Some pictures of my 6.4 program In the 380s with stock intake valve.
Can this only be done with 6.4L heads?
440, 4-Speed, 3.54 1968, when Dinosaurs ruled the Earth
[Re: metallicareload]
#2880767
01/27/21 07:50 AM
01/27/21 07:50 AM
Posts: 577 Arkansas
Adrielp
Arkansas
Awesome W5, I have a few questions. What is the average air speed speed and average CSA for your program? 90 or 91percent throat? Stock seat angles? Can you send me your email so I can contact you directly? Thanks
Adriel Paradise Substation Design Engineer III
[Re: Adrielp]
#2881287
01/28/21 02:03 PM
01/28/21 02:03 PM
Posts: 4,758 Moved to N.E. Tennessee
GomangoCuda
Awesome W5, I have a few questions. What is the average air speed speed and average CSA for your program? 90 or 91percent throat? Stock seat angles? Can you send me your email so I can contact you directly? Thanks His email address is in his profile.
#2884195
02/05/21 02:01 AM
02/05/21 02:01 AM
Posts: 4,254 State of Fascism
52savoy
State of Fascism
Can this only be done with 6.4L heads? All the Gen IIIs as far as I know. Not sure if it was on moparts or where-ever, someone did a great job welding up the heads. I think I saved at least one picture. Not sure if these are the heads.
[Re: 52savoy]
#2884196
02/05/21 02:04 AM
02/05/21 02:04 AM
52savoy
State of Fascism
These are the new MP I bought a few years ago and hope to have them assembled very soon. 2.10 int/1.60exh
[Re: W5DART66]
#2885634
02/08/21 06:38 PM
02/08/21 06:38 PM
Posts: 70 Souderton
Taylor
Souderton
Like the Exhaust bowl, 380 with stock valve very impressive.
04 Ram 4x2 11.66@ 122 4750LBS ...phat pig Moves for fully loaded truck with NA 345ci Hemi 2020 1320 Challenger....stock daily driver.
