Re: 511/TrickFlow combo going on the dyno
[Re: krautrock]
#2884345
02/05/21 01:45 PM
02/05/21 01:45 PM
Posts: 2,141 junction city oregon
viperblue72
Sounds fun. Why the short 6.7 rod length? Low deck? How would the motor respond to a 7.1 rod. I ask because the differences in rod length/rod ratio are not so clear in my mind. It would be nice to hear some info on the choices. it's all he can fit in a low deck. the CH on the piston is already only 1.12" That’s correct. The standard is a 6.535 rod. I chose a longer rod and shorter piston. Dom, I know you would go dominator lol. I plan to do a lot of street driving and prefer a power valve. This carb has worked well for me. I thought about trying one on the dyno but I don’t think I’ll end up doing so since I don’t plan to run one.
[Re: viperblue72]
#2884363
02/05/21 02:50 PM
02/05/21 02:50 PM
Posts: 14,515 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
The dyno shop might have a dyno mule 4500 and adapter on hand if you have time and feel like seeing “what if”?
It’s not always magic.
[Re: viperblue72]
#2884398
02/05/21 04:23 PM
02/05/21 04:23 PM
Posts: 31,106 Oregon
AndyF
All of your responses make me more optimistic. I am just surprised these heads are that capable without going too crazy. I’m guessing it’s the excellent mid lift numbers that help this head to perform?! I've run a half dozen or so 270 head combos on the dyno and they have all made more than 700 hp. Some of them with less compression and a smaller cam than what you are using. If everything else is equal in your build then I'd expect 720 hp from what you have but it always depends on the details. The carb has to be right on as does the timing and the plugs and lots of other little details.
[Re: krautrock]
#2884411
02/05/21 04:50 PM
02/05/21 04:50 PM
Posts: 17,926 S.E. Michigan
ZIPPY
S.E. Michigan
Sounds fun. Why the short 6.7 rod length? Low deck? How would the motor respond to a 7.1 rod. I ask because the differences in rod length/rod ratio are not so clear in my mind. It would be nice to hear some info on the choices. it's all he can fit in a low deck. the CH on the piston is already only 1.12" G3 392 has 1.21", Just for the sake of comparison ![smile smile](/ubbthreads/images/graemlins/custom/smile.gif)
Rich H.
Esse Quam Videri
[Re: viperblue72]
#2884424
02/05/21 05:37 PM
02/05/21 05:37 PM
Thumperdart
State of confusion
Who says a p/v isn't in Dommys silly......A friend goes 7.80 in the 1/4 w/a p/v in his carb......Unless the adapter and manifold are blended, I don't expect crazy gains but if you did, you'd be amazed but then I'd go straight to a Dommy manifold w/a spacer.....
[Re: Thumperdart]
#2884434
02/05/21 05:49 PM
02/05/21 05:49 PM
viperblue72
Who says a p/v isn't in Dommys silly......A friend goes 7.80 in the 1/4 w/a p/v in his carb......Unless the adapter and manifold are blended, I don't expect crazy gains but if you did, you'd be amazed but then I'd go straight to a Dommy manifold w/a spacer..... Dom, I did not know that. Maybe one of these days I’ll talk to an expert 😄.
[Re: viperblue72]
#2884465
02/05/21 07:01 PM
02/05/21 07:01 PM
Thumperdart
State of confusion
Ray Meyers on here one Drag Week with a 1050 Dommy carb I did and got up to 16 mpg's.......
Re: 511/TrickFlow combo/ UPDATE
[Re: viperblue72]
#2886428
02/10/21 04:49 PM
02/10/21 04:49 PM
fast68plymouth
So. Burlington, Vt.
I’d like 1.4hp ci, but my dyno operator said he hasn’t seen it on a combo that wasn’t race gas and this simple. I guess he has now!! ![smoke smoke](/ubbthreads/images/graemlins/custom/smoke.gif)
[Re: fast68plymouth]
#2886496
02/10/21 06:41 PM
02/10/21 06:41 PM
viperblue72
I’d like 1.4hp ci, but my dyno operator said he hasn’t seen it on a combo that wasn’t race gas and this simple. I guess he has now!! Stopped at 743hp@6100 and 699.9tq. I’ll give more details when I get home. Didn’t try more than the 950 carb. It needed more carburetor badly.
[Re: viperblue72]
#2886536
02/10/21 08:19 PM
02/10/21 08:19 PM
AndyF
I’d like 1.4hp ci, but my dyno operator said he hasn’t seen it on a combo that wasn’t race gas and this simple. I guess he has now!! Stopped at 743hp@6100 and 699.9tq. I’ll give more details when I get home. Didn’t try more than the 950 carb. It needed more carburetor badly. 740 is starting to get serious. A Dominator on a 400-3 intake would pick it up another 20 or so. We'll be running a very similar low deck 512 on the dyno soon with a 400-3 intake and a 4500 bolt pattern Holley Sniper. Expecting 750 hp from it.
