Page 1 of 5 1 2 3 4 5
511/TrickFlow dyno Updates. #2883996
02/04/21 01:48 PM
02/04/21 01:48 PM
junction city oregon
V
viperblue72 Offline OP
V
I have a truth teller session scheduled for Wednesday 10th. Feel free to post your guesses and two cents. I’ll be posting the results that afternoon. Here’s the combo.
Low deck
4.25 source crank
Mahle 1.12ch flat top-metric ring pack
6.7 scat rods
11.6 compression ratio
265/269 .660/.652 108lsa installed at 105
1.6 Mancini rockers. Final lift will be .683/.675
Untouched TF 270 heads
Deep port matched Indy 400-2 and a little plenum work
1050/4150 pro form carb
TTI 2 to 2 1/8 step headers
7 qt source pan 1/2 pickup
No Vacuum pump. No tricks. No gas ported pistons, no dry sump.
Just a basic motor anybody can replicate.
What are your thoughts and guesses?
I’d like 1.4hp ci, but my dyno operator said he hasn’t seen it on a combo that wasn’t race gas and this simple.
I’ll be happy if it makes 675.
Re: 511/TrickFlow combo going on the dyno [Re: viperblue72] #2884009
02/04/21 02:14 PM
02/04/21 02:14 PM
NC
440Jim Offline
440Jim  Offline
NC
Without any calculations, I believe around 700 hp is realistic.
I am thinking the Indy intake with port match to MW gasket will be larger than the TF 270 head opening. That will trip up the flow somewhat.
I look forward to the results, including the max hp RPM.
Re: 511/TrickFlow combo going on the dyno [Re: 440Jim] #2884027
02/04/21 02:37 PM
02/04/21 02:37 PM
V
V
Jim,
The ports match up great, but it wasn’t without a lot of work. The ports were smaller but the casting sucked. It had to be filled in with quite a bit of spool weld and reshaped. A few ports were way out of alignment to the point the intake gasket hung into the ports.
Re: 511/TrickFlow combo going on the dyno [Re: viperblue72] #2884032
02/04/21 02:48 PM
02/04/21 02:48 PM
Depending on how good that carb does with tuning you should be able to make close to 700 HP on Oregon pump swill, what brand engine dyno and has it been calibrated recently ?
Ignition timing, spark plug heat range and valve lash are all items that are tunable that can help you get the most out of your parts wrench up
Have fun thumbs
Re: 511/TrickFlow combo going on the dyno [Re: Cab_Burge] #2884033
02/04/21 02:52 PM
02/04/21 02:52 PM
V
V
Cab,
Plugs are NGK #8 heat range. I do plan to mix for a bit more octane to be safe.
Re: 511/TrickFlow combo going on the dyno [Re: viperblue72] #2884034
02/04/21 02:54 PM
02/04/21 02:54 PM
V
V
Here’s the plenum work
Plenum
Re: 511/TrickFlow combo going on the dyno [Re: viperblue72] #2884047
02/04/21 03:40 PM
02/04/21 03:40 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
There’s the “every dyno is different” thing to factor in, but if I had it here I’d be fully expecting it to make 700+.
Re: 511/TrickFlow combo going on the dyno [Re: viperblue72] #2884054
02/04/21 04:07 PM
02/04/21 04:07 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
I'll guess 680-690hp, with that compression ration. Sounds like a nice combo.
69 GTX 68 Road Runner
Re: 511/TrickFlow combo going on the dyno [Re: fast68plymouth] #2884065
02/04/21 04:36 PM
02/04/21 04:36 PM
V
V
Duane the last motor I put on this dyno you guess was almost right on for hp and tq. I made just a little more tq with a spacer. But without your guess was almost exact.
Re: 511/TrickFlow combo going on the dyno [Re: viperblue72] #2884078
02/04/21 05:21 PM
02/04/21 05:21 PM
So. Burlington, Vt.
So. Burlington, Vt.
MarkZ’s 505........ a little less cam, a little less compression, a few less cubes......on the BES dyno:
Quote
Basic specs:
new aftermarket "The Block"
505 CI
Molnar crank & rods - 4.25 inch stroke
OOTB TrickFlow 270 heads
Mopar Performance 337 intake
4150 carb - flows 1000 cfm
solid roller cam around 650 lift - smaller duration (Dwayne Porter spec'd)
10.9:1 compression
93 pump gas
Hooker 5209 2 inch headers
Made 713 hp @ 6000 rpm and 707 ft/lbs torque at 4600 rpm. I did not expect that much torque - it makes the same torque as my race car motor!
Re: 511/TrickFlow combo going on the dyno [Re: fast68plymouth] #2884085
02/04/21 05:37 PM
02/04/21 05:37 PM
V
V
Quote
Basic specs:
505 CI
10.9:1 compression
93 pump gas
Duane those numbers are very impressive. For some reason I don’t want to get too optimistic. He shared his dyno sheets with me. Very broad and impressive power curve for sure. I’m curious about the correction numbers.
Re: 511/TrickFlow combo going on the dyno [Re: viperblue72] #2884089
02/04/21 05:49 PM
02/04/21 05:49 PM
Nevada
merpar Offline
merpar  Offline
Nevada
I like your combo, and believe you will be close to your 1.4 per cui.. With the work on your intake and that stroke I think torque will be over 700.
Re: 511/TrickFlow combo going on the dyno [Re: viperblue72] #2884093
02/04/21 05:57 PM
02/04/21 05:57 PM
So. Burlington, Vt.
So. Burlington, Vt.
I saw nothing in the weather data for Marks sheets that seemed out of line at all for that region of the country, at that time of year.
Correction factor seemed in line to me.
For your combo...... over 500”, good CR, heads that flow 350+, big intake, correctly sized headers, adequate lift and duration.........700hp...... it’s just not that hard to get there.
Like I said, if I had it here, I’d absolutely be expecting it to break 700.
Re: 511/TrickFlow combo going on the dyno [Re: fast68plymouth] #2884105
02/04/21 06:27 PM
02/04/21 06:27 PM
V
V
Thank you for the replies so far. I did build it with 700 in mind and a flat torque curve. 700 is what I want.
My combo is extremely similar to marks528 combo. If I get similar results I will be beyond extatic.
I still have to swap to 1.6s as I started with 1.5 and changed my mind.
Re: 511/TrickFlow combo going on the dyno [Re: viperblue72] #2884119
02/04/21 07:44 PM
02/04/21 07:44 PM
UK
rb446 Offline
rb446  Offline
UK
I reckon 719hp, we have a bigger motor +78ci but only @10:1cr, -13 heads that prob do not flow as much as your 270's at our 625" and 260/270@.050 s/roller with a 440-2, an old 950HP and 2.18" TTI's and we made 694hp on the dyno which is just 1.18hp/ci.
1969 'Cuda 446ci, best 9.96@133.9 in 1990
1971 340 'Cuda, best 11.01@122.8 in 1987
Re: 511/TrickFlow combo going on the dyno [Re: rb446] #2884154
02/04/21 09:43 PM
02/04/21 09:43 PM
NH, USA
toddinNH Online content
Egghead
toddinNH  Online Content
Egghead
NH, USA
I wouldn't be concerned with a number. That said, it should make good power as long as the carb and ignition are capable.
Depending on the actual valve events, you have the makings of a great motor with a broad power curve.
Peak numbers are for magazine headlines and Internet racing. If it makes better avg numbers that will make for a much better street driving experience ... unless it was going in a Daytona or other featherweight.
On Edit: Best of success and have fun!
Re: 511/TrickFlow combo going on the dyno [Re: toddinNH] #2884194
02/05/21 01:47 AM
02/05/21 01:47 AM
V
V
All of your responses make me more optimistic. I am just surprised these heads are that capable without going too crazy. I’m guessing it’s the excellent mid lift numbers that help this head to perform?!
Re: 511/TrickFlow combo going on the dyno [Re: viperblue72] #2884325
02/05/21 12:47 PM
02/05/21 12:47 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Sounds fun. Why the short 6.7 rod length? Low deck? How would the motor respond to a 7.1 rod. I ask because the differences in rod length/rod ratio are not so clear in my mind. It would be nice to hear some info on the choices.
Re: 511/TrickFlow combo going on the dyno [Re: viperblue72] #2884326
02/05/21 12:49 PM
02/05/21 12:49 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Good looking combo except I'd put a 1050 Dommy on there and #8's are WAY too cold imo.....
Re: 511/TrickFlow combo going on the dyno [Re: jbc426] #2884329
02/05/21 01:00 PM
02/05/21 01:00 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
it's all he can fit in a low deck. the CH on the piston is already only 1.12"
