Page 2 of 3 1 2 3
Re: Best Starter for high compression Big Block [Re: bigdad] #2882801
02/01/21 03:39 PM
02/01/21 03:39 PM
moparx Offline
moparx  Offline
Originally Posted by bigdad
My TTI headers are extremely tight fit in starter area , I had to buy a clock able one , gained just a tiny amount to make it fit
https://www.jegs.com/i/Powermaster/...uj-7I7gIVqvLACh2bxgcfEAQYBCABEgLDxfD_BwE
do you have a pic of your starter/header area dad ?
i have a set of TTI's i'm planning of using, and you may be able to give me an idea what i'm in for. they are the 2" to 2 1/8" step, but i don't know the part number.
TIA if you [or any other member] have a pic you can post. bow
beer
Re: Best Starter for high compression Big Block [Re: Kindafast] #2882809
02/01/21 04:10 PM
02/01/21 04:10 PM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
If you are going to run on the street you need a 16 volt alternator. My old dodge has stock lights and it just made the headlights a little brighter. Factory 12 volt system alternators operate about 14.5 volts anyway, so you are not really increasing the voltage that much. The only issue I would worry about again on a street vehicle, would be any electronics on the car like a radio. I know MSD does not have a problem with 16 volts.
Re: Best Starter for high compression Big Block [Re: jwb123] #2882862
02/01/21 06:43 PM
02/01/21 06:43 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
16 volt systems on the street will kill stock bulbs very quickly.
I burn up stock dome light bulbs regularly. I keep 6 spares in the glove box.
Unless I'm missing something, I never heard anyone using a 16 volt alternator with a 12 volt battery. I don't think they mix well together.
Re: Best Starter for high compression Big Block [Re: Kindafast] #2882889
02/01/21 07:53 PM
02/01/21 07:53 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Originally Posted by Kindafast
Not to try and hack this post , but I hear about the 16Volt batteries. How would that voltage effect 12 Volt wiring and lights ?? I have always stayed away from 16 volt stuff from lack of knowledge about it..
The only two things I changed were the voltage regulator to allow aprox 18.5 volt charging rate. And definitely had to lower the fuel pressure at the regulator. No need for a fancy starter that I can see.
Doug
Re: Best Starter for high compression Big Block [Re: Sammy] #2882890
02/01/21 07:53 PM
02/01/21 07:53 PM
MD
JACK1440 Offline
JACK1440  Offline
MD
Boy does this post sound familiar. This was me a year ago. Add a starter saver to you msd system and problem solved. I'm at 572" @ 15:1 with a factory mini starter. That thing would not crank once it got hot. I added the starter saver and now it cranks like a worn out 318. Thanks to the advice from this forum
Re: Best Starter for high compression Big Block [Re: dvw] #2882894
02/01/21 08:13 PM
02/01/21 08:13 PM
Quote
I was wondering about too. & what is a starter saver?
Re: Best Starter for high compression Big Block [Re: RapidRobert] #2883004
02/02/21 08:10 AM
02/02/21 08:10 AM
VA
dragon slayer Offline
VA
Wire has 2 main properties to consider, how much voltage potential versus wire insulation and how much current can the conductor handle. Most low voltage wire has no issue with 12-24 Volt. Next is current. Well Power =Volts times Amps. SO when you run at a higher voltage, you actually have lower current through wires for the same load. So your better off. As stated, the loads need to be ok with the new higher voltage. Alternator needs to charge the higher battery voltage.
So bulbs, coil relays, electronics like pumps, radio, motors would all need to be good with the higher voltage. Not an issue with a race car, but may have issues with accessories on a street car. But the wires will like it. Less current.
Re: Best Starter for high compression Big Block [Re: dragon slayer] #2883006
02/02/21 08:17 AM
02/02/21 08:17 AM
Seaford, Va
Kindafast Offline
Kindafast  Offline
Seaford, Va
Thanks for the replies guys , I think I will stick with a 12 volt setup.. Has anybody had the problem like this ?? My car spins over just fine with big tub headers and exhaust on it. 11.5 to one small block . But once I take the pipes off it really hesitates to spin over even cold. Bucks like the timing is really high with the pipes off. Again sorry , not trying to hyjack this post..
6.50 @105.26
Re: Best Starter for high compression Big Block [Re: Kindafast] #2883021
02/02/21 09:29 AM
02/02/21 09:29 AM
MD
JACK1440 Offline
JACK1440  Offline
MD
Here you go Robert. Also, as others are saying. You must have good heavy wire and good connections. I fixed all of that too.
https://www.holley.com/products/ignition/rpm_and_timing_controls/timing_controls/parts/8984
Re: Best Starter for high compression Big Block [Re: JACK1440] #2883027
02/02/21 09:55 AM
02/02/21 09:55 AM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
I used to go to junkyards and buy them for 15.00 but now just ask for one that fits a 1995 V8 truck. You can tell the higher for lower horsepower starters just by looking at them. I used to know the measurement but like I said once you know what to look for you can tell
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Best Starter for high compression Big Block [Re: pittsburghracer] #2883080
02/02/21 12:42 PM
02/02/21 12:42 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Will a stock starter work, in most cases yes. But if you read the title it says BEST starter not what will work/
Re: Best Starter for high compression Big Block [Re: Al_Alguire] #2883095
02/02/21 01:15 PM
02/02/21 01:15 PM
PA.
"Little"John
"Little"John
PA.
Trouble is 9 times out of 10 the starter isn’t the issue, the wiring is. And the best starter in the world won’t fix that. Some of the grounding I see out there is pathetic. And small azz power leads too.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Best Starter for high compression Big Block [Re: pittsburghracer] #2883101
02/02/21 01:30 PM
02/02/21 01:30 PM
moparx Offline
moparx  Offline
i have to agree with the wiring issue. from the key or button to the starter, don't skimp ! just going up one wire gauge size can sometimes make a HUGE difference.
also, have as few connections as possible, and make sure those connections are clean and tight.
beer
Re: Best Starter for high compression Big Block [Re: moparx] #2883864
02/04/21 01:37 AM
02/04/21 01:37 AM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
Re: Best Starter for high compression Big Block [Re: Biginchmopar] #2884167
02/04/21 11:02 PM
02/04/21 11:02 PM
PA
moparacer Offline
moparacer  Offline
PA
I just put the Powermaster Ultra Torque on my car this evening. Had the Master Torque on it. 14:1 alky engine with bushed rockers and lifters so its hard to turn over. Videos of the difference.
Master Torque. Video
Ultra Torque Video
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Best Starter for high compression Big Block [Re: moparacer] #2884180
02/05/21 12:21 AM
02/05/21 12:21 AM
WNY
Moparrob68 Offline OP
WNY
What part number Ultra Torque did you use, the 9413 or 9463?
Re: Best Starter for high compression Big Block [Re: Kindafast] #2884197
02/05/21 02:40 AM
02/05/21 02:40 AM
Heaven
EvilB1Dart Offline
EvilB1Dart  Offline
Heaven
I always ran Powermaster or Tilton starters with 16v charging system to easily crank over 14-15.1 motors. I had a contact at Powermaster who gave me great deals. Quality stuff.
"Any fool can know. The point is to understand"
- A. Einstein
Re: Best Starter for high compression Big Block [Re: EvilB1Dart] #2884223
02/05/21 07:35 AM
02/05/21 07:35 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I'm sure all these high end starters are nice. But the factory starters have given me zero trouble. 15-1 ignition on is no problem what so ever. So what does spending $300 gain?
Doug
Re: Best Starter for high compression Big Block [Re: dvw] #2884248
02/05/21 09:56 AM
02/05/21 09:56 AM
PA
moparacer Offline
moparacer  Offline
PA
Doug
My car hard starts since I bumped it to 14:1. Its alky injected too which doesnt help....Those videos I posted were with a 12volt battery. Will go to a 16 volt if the problem persists in the spring.
Re: Best Starter for high compression Big Block [Re: JACK1440] #2884258
02/05/21 10:13 AM
02/05/21 10:13 AM
thank you brother up
Page 2 of 3 1 2 3
