Kick panel paint #2881667
01/29/21 11:51 AM
01/29/21 11:51 AM
South San Francisco, Ca
70sixpkrt Offline OP
What is the best paint for kick panels?
Thanks.
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: Kick panel paint [Re: 70sixpkrt] #2881681
01/29/21 12:26 PM
01/29/21 12:26 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
SEM seems to be ok for black. It's not dead on perfect though.
Re: Kick panel paint [Re: Neil] #2881993
01/30/21 11:35 AM
01/30/21 11:35 AM
KY
65pacecar Offline
65pacecar  Offline
KY
I have used the interior paint Herbs sells, colors are great and Sprays nice,
Re: Kick panel paint [Re: 65pacecar] #2882519
01/31/21 06:35 PM
01/31/21 06:35 PM
Oakville, Ontario, Canada
CDN72SE Offline
CDN72SE  Offline
Some interior color change. I lightly went over the panels with a scotchbrite pad on some of the scratches and followed the SEM procedure, here are some of the results:
Re: Kick panel paint [Re: CDN72SE] #2882568
01/31/21 08:28 PM
01/31/21 08:28 PM
Can SEM be purchased locally?
4-speed
3:54 Dana
Re: Kick panel paint [Re: 70sixpkrt] #2882575
01/31/21 08:43 PM
01/31/21 08:43 PM
PA--USA
70VERT Offline
70VERT  Offline
PA--USA
Ive used SEM for black over black vinyl on my challenger following the procedures with prep and all . I had excellent results Also used black over gray invmy Viper,. Again great results. I'm now gonna try yellow over grey on another Viper......not sure here.....anybody ever try something like this??
Re: Kick panel paint [Re: 70VERT] #2882580
01/31/21 08:51 PM
01/31/21 08:51 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
SEM should be available from any auto paint store (aka "jobber").
On plastic & vinyl, I've also used the OER stuff from Classic Ind.
Nice stuff, the cans with the big white plastic nozzle spray well with decent coverage.
Available in factory Mopar colors, too, if you need color.
Same prep as SEM & etc.
Re: Kick panel paint [Re: 65pacecar] #2882693
02/01/21 08:18 AM
02/01/21 08:18 AM
SE Pa.
LimeliteAero Offline
SE Pa.
Did you spray plastic? How is the adhesion to plastic? any flaking and how long has it been since you paints stuff?
TIA!
Re: Kick panel paint [Re: LimeliteAero] #2883086
02/02/21 12:59 PM
02/02/21 12:59 PM
rust belt
Moparite Offline
Moparite  Offline
rust belt
Go to the SEM web site and look at their products. They say to use a cleaner/wash prep they have before you use the die(it's not paint/if go with the dye). Guess that depends on what product you go with. They have a dye and a "flex coating". Look for a local place that sells the SEM line. Not all paint shops may carry it.
Re: Kick panel paint [Re: Moparite] #2883104
02/02/21 01:39 PM
02/02/21 01:39 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
In the same topic, same paint for 70 Charger bucket seat backs?
Thanks, Joe
Re: Kick panel paint [Re: jlatessa] #2883653
02/03/21 04:40 PM
02/03/21 04:40 PM
CDN72SE Offline
CDN72SE  Offline
I'm in Canada and got it at Car Quest.
