Indy MAXX Screw in freeze plugs #2881269
01/28/21 12:33 PM
01/28/21 12:33 PM
S.E. Michigan
cl440 Offline OP
cl440  Offline OP
S.E. Michigan
We have the freeze plugs (Screw in style) out of our Indy Maxx block and thought we would replace the O-Rings before we put them back in. Does anyone know what size O-Ring I need? I did a Google search and cant seem to come up with the answer. Thanks
Re: Indy MAXX Screw in freeze plugs [Re: cl440] #2881585
01/29/21 08:14 AM
01/29/21 08:14 AM
Heaven
EvilB1Dart Offline
EvilB1Dart  Offline
Heaven
When I had one of those blocks a few years ago I bought some extra o-rings from Indy, or Indy products distributor. Can’t remember the size.
"If you can still hear your fears - shift a gear."
Re: Indy MAXX Screw in freeze plugs [Re: cl440] #2881605
01/29/21 08:58 AM
01/29/21 08:58 AM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
I got mine at the hardware store.
Re: Indy MAXX Screw in freeze plugs [Re: rickraw] #2881627
01/29/21 09:29 AM
01/29/21 09:29 AM
NC
440Jim Offline
440Jim  Offline
NC
Compare your fitting & o-ring to this chart.
Re: Indy MAXX Screw in freeze plugs [Re: 440Jim] #2881645
01/29/21 10:00 AM
01/29/21 10:00 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Call an Indy dealer like Bob George or Todd Marsh. up
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Indy MAXX Screw in freeze plugs [Re: hemi-itis] #2881695
01/29/21 11:54 AM
01/29/21 11:54 AM
S.E. Michigan
cl440 Offline OP
cl440  Offline OP
S.E. Michigan
So Dad and I broke out the calipers yesterday and carefully measured the old Oring. Used our measurements to find the correct Orings on McMaster Carr. They should be here in a couple days and I will see how they fit. I think they will work fine. I will report my findings when they get here. Thanks
Attached PDF document
Re: Indy MAXX Screw in freeze plugs [Re: cl440] #2881724
01/29/21 12:43 PM
01/29/21 12:43 PM
NC
440Jim Offline
440Jim  Offline
NC
Are the threads on your fittings 1-3/8" ?
Re: Indy MAXX Screw in freeze plugs [Re: 440Jim] #2881773
01/29/21 03:25 PM
01/29/21 03:25 PM
S.E. Michigan
cl440 Offline OP
cl440  Offline OP
S.E. Michigan
No they measured 1.5" exactly. The Orings showed up today and they fit the core plugs like a glove. Will be a few months before I test them with water behind them but they should work just fine.
Re: Indy MAXX Screw in freeze plugs [Re: cl440] #2881797
01/29/21 04:53 PM
01/29/21 04:53 PM
NC
440Jim Offline
440Jim  Offline
NC
Weird plugs. Must be Indy design; rather than using AN design. I guess they wanted a big clean out hole.
The new Bill Mitchell Products (World design) aluminum block I looked at had 1-5/16 (1.312) water jacket plugs.
