Cam choice ? 396" W2 #2881582
01/29/21 09:05 AM
01/29/21 09:05 AM
Sao Paulo, Brazil
dart_73_br Offline OP
Sao Paulo, Brazil
Hello folks, building a 396" W2 headed. Engine will run 12:1 CR on Alcohol, 904 w/ brake, 4000rpm stall, 4.88 gears, 3400lbs car. W2 head flows aroung 300cfm and I have 2 options of flat tapped camshafts. Crower 276/281 @.050 108 LS and Lunati 259/267 @0.50. Which one would you choose and why?
1973 Brasilian Dart
E100, boosted 390"
Re: Cam choice ? 396" W2 [Re: dart_73_br] #2881592
01/29/21 09:31 AM
01/29/21 09:31 AM
bronx n.y
O
one bad fish Offline
O
bronx n.y
do a roller
Re: Cam choice ? 396" W2 [Re: one bad fish] #2881610
01/29/21 10:03 AM
01/29/21 10:03 AM
Sao Paulo, Brazil
Sao Paulo, Brazil
I also have this rollwer available. But concerned about that high rpm and damage this can cause in conn rods (bolts) and valvetrain wear... not sure..
1973 Brasilian Dart
E100, boosted 390"
Re: Cam choice ? 396" W2 [Re: dart_73_br] #2881613
01/29/21 10:07 AM
01/29/21 10:07 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Definitely gonna want more stall( lots more) than 4,000.
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Cam choice ? 396" W2 [Re: B3422W5] #2881654
01/29/21 11:22 AM
01/29/21 11:22 AM
Washington
madscientist Offline
Washington
THIS^^^^^^^^^^^^^
If the heads only flow 297 you can’t get enough cam in it to shift at 8000. You are induction limited.
I’d put the roller in it, get it on the pump and see where you’re at. At that displacement with the roller you posted I doubt it will make power past 6800.
EDIT: that 104 LSA will tighten peak TQ to peak HP. A lot. And that extra exhaust duration is to try and get it to RPM that high.
IMO, I’d not try and save money and buy something else. On alcohol you only need a 4 degree split on duration. The exhaust port will take care of itself.
Again, my opinion is you should be 274-278 at .050 on a 109 LSA with as much lift as you can get up to about .750ish. The love gear will take more lift than that, but it gets sketchy if you don’t have everything dead nuts on, and the gains above that lift won’t make enough of a difference to matter.
BTW, you can’t get the pushrods too big in diameter or get too much wall thickness. IMO, you should have a 3/8-7/16 double taper pushrod. I’ve run straight 7/16 pushrods, but the taper gets you some extra room on both ends.
Re: Cam choice ? 396" W2 [Re: madscientist] #2881689
01/29/21 12:48 PM
01/29/21 12:48 PM
Apollo, PA.
B1MAXX Online content
B1MAXX  Online Content
Apollo, PA.
I like the crower flat tappet....It's has the most duration. High lift on w2's can be tricky to get to play nice assuming this is 59* stuff.
