Spark plug recommendation
#2881391
01/28/21 04:40 PM
01/28/21 04:40 PM
Posts: 146 Missouri
randavis
Missouri
I'm having a 512 RB being built. It will be using Edelbrock Performer RPM heads and a Comp hydraulic roller cam. Eagle rotating assy. What spark plugs are you guys running in this kind of combo? Thanks
74 Challenger, bought it new. In 1978 I replaced the original 318 with a 446 and 727. Mild cam, Jardine headers, and Holley Sniper EFI. New engine! 511" RB, Edelbrock Performer RPM heads, Eagle rotating assy, Comp hyd roller cam, Doug's 2" headers.
Re: Spark plug recommendation
[Re: randavis]
#2881423
01/28/21 06:08 PM
01/28/21 06:08 PM
Posts: 43,251 Bend,OR USA
Cab_Burge
What compression ratio and what quality of fuel will you be using?
[Re: Cab_Burge]
#2881451
01/28/21 08:03 PM
01/28/21 08:03 PM
Posts: 146 Missouri
randavis
Missouri
What compression ratio and what quality of fuel will you be using? Compression in the 10-1 range. 91 octane no ethanol.
[Re: Cab_Burge]
#2881768
01/29/21 04:01 PM
01/29/21 04:01 PM
Posts: 146 Missouri
randavis
Missouri
I like to use extended tip spark plugs when I can, on your deal look either NGK 6 or 7 with the extended tips, Autollite #3924 or 3923, Champion RC12YC or the colder RC9YC if you tune it to run clean at idle and light part throttle cruise I have to have resistors because of the Sniper EFI.
[Re: randavis]
#2881852
01/29/21 09:14 PM
01/29/21 09:14 PM
Cab_Burge
All the ones I listed, except the NGK heat range, are resistor plugs with extended tips Using resistor plugs with resistor wires make the coil firing voltage thresh hold go up, making it have a hotter spark Same thing as widening the plug gap
