easy cam lift math Q #2880428
01/26/21 02:24 PM
01/26/21 02:24 PM
RapidRobert Offline OP
I'm assuming that a .488/.480 listed cam, that this is with 1.5 rockers & with 1.6 mag rockers that I need to some slight math to get a true number? Thank you for your time.
Re: easy cam lift math Q [Re: RapidRobert] #2880453
01/26/21 03:20 PM
01/26/21 03:20 PM
A727Tflite Offline
A727Tflite  Offline
Divide the listed lift by current rocker ratio then multiply by the new ratio.
Re: easy cam lift math Q [Re: A727Tflite] #2880468
01/26/21 03:34 PM
01/26/21 03:34 PM
got it, thank you up
Re: easy cam lift math Q [Re: RapidRobert] #2880489
01/26/21 04:14 PM
01/26/21 04:14 PM
Idaho
LaRoy Engines Offline
Idaho
I think I would rather multiply the lobe lift by the rocker arm ratio. Some Magnum cams are listing their lift with a 1.6 rocker ratio..
Re: easy cam lift math Q [Re: LaRoy Engines] #2880554
01/26/21 06:17 PM
01/26/21 06:17 PM
A727Tflite Offline
A727Tflite  Offline
That’s not what the OP asked.
Obviously the best method to determine valve lift is to measure it. And forget what’s in between the camshaft and valves.
Re: easy cam lift math Q [Re: A727Tflite] #2880579
01/26/21 06:57 PM
01/26/21 06:57 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Or simply multiply the actual lift by 1.0666667 ( which is the same, but on a single operation )
If want to know with 1.7 rockers, the multiplier factor would be 1.13333333
Re: easy cam lift math Q [Re: RapidRobert] #2880743
01/27/21 02:48 AM
01/27/21 02:48 AM
I've seen .030 differences in valve lift on both T&D and Harland Sharp BB Mopar single shaft systems due to variances in the valve lift by the rocker arms, not from the cam lobe varying in lift tsk
Stock Street Hemi rocker arms are the WORST I've seen so far, .130 lift differences at the valves using the same cam, lifters, heads and checking valve springs set at zero lash shock puke one of the many reasons I call them motors Hemiroid motors shruggy
Re: easy cam lift math Q [Re: A727Tflite] #2880782
01/27/21 08:38 AM
01/27/21 08:38 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Well technically the OP asked about cam lift, not valve lift, which is the same regardless.
Yeah, we're pretty sure he meant valve lift but if you want to split hairs about it...
Re: easy cam lift math Q [Re: Sniper] #2880836
01/27/21 11:37 AM
01/27/21 11:37 AM
actually whats going on is I was considering an ebay set of iron EQ's (class rules) & the guy gave his # & said he could put whatever springs in that a buyer wanted along with brass guides (liners?) so I wanted to figure the valve lift of my intended cam so I could have him select the right ones but when I spoke with him all sounded good except he wanted me to pay him direct so that he could get out from under the ebay fee. I'm not comfortable with that. still undecided. I agree with him that these heads are getting real scarce until the next batch of 100 (his number) is made over there in new zealand & made available but 2K is alot to risk if he ain't on the up & up. if he wants to get over on them he might want to get over on me.
Re: easy cam lift math Q [Re: RapidRobert] #2881102
01/27/21 09:29 PM
01/27/21 09:29 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
If you really want the heads, offer to pay the ebay fee's through ebay of course wink that'll stop any BS up
