That's a crank stopper right there! #2879647
01/24/21 10:15 PM
01/24/21 10:15 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
I did the initial mock up on the 541 today. I foresee grinding in my future but it's not as bad as I expected.
The oil pick up boss is the only point of contact but that might change with less than .030" between the rod bolts and bottom of the cylinders. They're gonna be cozy with some heat and RPM. Gotta dust a bit off the bores.
- Stu Harmon
Re: That's a crank stopper right there! [Re: feets] #2879728
01/25/21 02:00 AM
01/25/21 02:00 AM
Fairfield, CA
Snooker Offline
Snooker  Offline
Fairfield, CA
Yep - Grinding is in order - Better now than welding repairs later grin
Orig DOB 2-02 / Snooker there & here <img src="/ubbthreads/images/graemlins/smile.gif" alt="" />
Re: That's a crank stopper right there! [Re: feets] #2879817
01/25/21 12:14 PM
01/25/21 12:14 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Sure is... Familiar too.
Rich H.
Esse Quam Videri
Re: That's a crank stopper right there! [Re: ZIPPY] #2879859
01/25/21 01:29 PM
01/25/21 01:29 PM
moparx Offline
moparx  Offline
neat way you have the pick up tube adapter mounted zippy. how much did you have to move it ? did you just slot the mounting holes then move the adapter over for clearance, or did you plug the original holes, move the required clearance amount, then re-drill and tap new holes ?
feets, how much clearance do you have between the crank throw and the piston skirt ?
beer
Re: That's a crank stopper right there! [Re: moparx] #2879987
01/25/21 03:52 PM
01/25/21 03:52 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
Feets, what is the stroke and rod journal diameter?
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: That's a crank stopper right there! [Re: moparx] #2880045
01/25/21 05:51 PM
01/25/21 05:51 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
It's an aftermarket block and comes that way.
I stopped at this point, I didn't care much for any of the mods required to make the internal pickup work so I went external.
Rich H.
Esse Quam Videri
Re: That's a crank stopper right there! [Re: Hemi_Joel] #2880214
01/25/21 10:57 PM
01/25/21 10:57 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
It's a 4.5" stroke with 2.2" journals.
- Stu Harmon
Re: That's a crank stopper right there! [Re: feets] #2880538
01/26/21 05:52 PM
01/26/21 05:52 PM
Tri-Cities, Washington
V
VITC_GTX Offline
VITC_GTX  Offline
V
You could just slap it together and fire it up. It will self-clearance fairly quickly! no
