Re: crank register adapter
[Re: old_racer]
#2878389
01/22/21 02:11 PM
01/22/21 02:11 PM
Posts: 43,127 Bend,OR USA
Cab_Burge
Call Tim at FHO and maybe Ray Barton I need another two now also, please let us know who and where you find them. I had one of the old KB adapters left but I can't find it now
[Re: old_racer]
#2878401
01/22/21 02:26 PM
01/22/21 02:26 PM
Posts: 5,618 long island NY
Ari440
long island NY
I have a Keith black 4.25 crank with the same problem
Call Meziere they made me an adapter and flex plate
No one around here could do the register ring for me
Talk to Jerry tell him Ari sent you
He help me alot
1-516-279-0493 if you want to talk Ari
1.39 9.85 - 137 mph
[Re: Ari440]
#2878475
01/22/21 04:10 PM
01/22/21 04:10 PM
Posts: 1,400 Wi.
old_racer
Wi.
[Re: old_racer]
#2878626
01/22/21 09:51 PM
01/22/21 09:51 PM
Posts: 417 reynoldsburg,ohio
poppaj
reynoldsburg,ohio
We have one Russ. We ran it with our first combo which had a fueler crank with no converter provision. You must run a 3/8” spacer or mid plate. It works fine. Standard converter. If you can use it let us know
AA/NSS 65'Coronet "Whompin Wedge" Pop & Son Performance 557" B-1 power John Holt Chassis
[Re: boatracer572]
#2878796
01/23/21 10:43 AM
01/23/21 10:43 AM
Posts: 16,923 NC
440Jim
NC
pretty easy to make in a lathe... been there done that What dimensions and tolerance did you use?
[Re: 440Jim]
#2878902
01/23/21 01:55 PM
01/23/21 01:55 PM
Posts: 1,049 San Jose Ca.
boatracer572
San Jose Ca.
[quote=440Jim][quote=boatracer572] .0015 press fit in the crank, same tolerance as oem crank on the register to the flywheel, used a piece of 4340
