7.1 h beam strength?
#2877950
01/21/21 04:27 PM
01/21/21 04:27 PM
Posts: 10,021 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I am looking at Molnor or K1 7.1 long hbeams for my new shortblock. Someone from Campbell enterprises said the Molnors would be on the edge at 1000 hp. I will have a stroke of 4.315 and flat top 4.5 bore 1.45 compression height Gibtech piston, lightened, and rpm will be 7500 or less. About 950 hp. 15/1 compression and alky. Is there a differance between Molnor or K1 in strength? Any other options for a 7.1 rod?
Re: 7.1 h beam strength?
[Re: gregsdart]
#2877964
01/21/21 04:50 PM
01/21/21 04:50 PM
Posts: 1,107 Massillon, Ohio
cudatom
Massillon, Ohio
Not sure but I chose Oliver 7.1 I beams for my 553(4.5 bore 4.35 stroke ) build. Compression will be a tad less than yours and should cross the line at the same rpm. I just wasn't comfortable with the others given the cost of my KB block.
Not that Olivers can't fail but I think it would be less likely.
Ok
[Re: cudaman1969]
#2878002
01/21/21 06:36 PM
01/21/21 06:36 PM
Posts: 3,024 NY
B1duster
NY
Is crank set up for Mopar or Chevy width rods ?
On the cheap Eagle with L-19 bolts Not so cheap Oliver Crower ? and deep pockets Carrillo
[Re: B1duster]
#2878030
01/21/21 07:53 PM
01/21/21 07:53 PM
gregsdart
Like it or not i may have to go with Manley or Oliver rods, about 850 more than the h beams i was looking at. I got away with running Molnor 6.86 Hemi H beams in the megablock, but what shakes my confidance in the 7.1 rods is the fact that the 7.1 rods are 11 grams lighter than the 6.86 rods.
[Re: EchoSixMike]
#2878053
01/21/21 08:22 PM
01/21/21 08:22 PM
Posts: 9,883 MI, usa
dvw
MI, usa
HP means squat. What counts is reciprocating weight, rpm, and load if you run a power adder. The 7.100 rods are a modern design where unnecessary bulk was removed. Call Tom and ask. He'll give you an honest answer. Mine has Molnar 7.100". The bobweight is 2222. I was told my self imposed 7500 rpm limit was safe. Though it only runs to about 7300. Doug
[Re: B1duster]
#2878070
01/21/21 09:02 PM
01/21/21 09:02 PM
Posts: 1,264 New York, USA
Chargerfan68
New York, USA
My friends rb stroker used the Callies Ultra I beam rod. Part no U15270 Very nice piece. Not cheap but supposed to be a pretty stout piece. Quality was very good and so was machining ootb.
[Re: gregsdart]
#2878085
01/21/21 09:24 PM
01/21/21 09:24 PM
Posts: 903 Saskatchewan, Canada
cudabin
Hey Greg,
I went with the Oliver pro billet option, and the peace of mind has been worth it to me...
Good Luck,
Arnie
67 Cuda 8.48@ 158.7 mph 1.18 60' 2,600 DA(so far...)
70 Super Bee 440 Six Pack 4-speed. 13.2 @ 104 Stock exhaust/Street tires.
[Re: Cab_Burge]
#2878115
01/21/21 10:19 PM
01/21/21 10:19 PM
Posts: 6,341 Heaven
EvilB1Dart
Heaven
Oliver H Beams or GRP Alum.
"Any fool can know. The point is to understand"
- A. Einstein
[Re: B1duster]
#2878201
01/22/21 03:40 AM
01/22/21 03:40 AM
Posts: 3,024 NY
B1duster
NY
[Re: dvw]
#2878343
01/22/21 01:15 PM
01/22/21 01:15 PM
gregsdart
Thanks everybody. I talked to Ed at Molnar, he said the 7.1 rods from Molnar would be fine. Two other things that will help- the new piston is going to be lighter and i plan to go to a clean neutral valvebody.
