Page 1 of 4 1 2 3 4
7.1 h beam strength? #2877950
01/21/21 04:27 PM
01/21/21 04:27 PM
gregsdart Offline OP
I am looking at Molnor or K1 7.1 long hbeams for my new shortblock. Someone from Campbell enterprises said the Molnors would be on the edge at 1000 hp. I will have a stroke of 4.315 and flat top 4.5 bore 1.45 compression height Gibtech piston, lightened, and rpm will be 7500 or less. About 950 hp. 15/1 compression and alky. Is there a differance between Molnor or K1 in strength? Any other options for a 7.1 rod?
Re: 7.1 h beam strength? [Re: gregsdart] #2877964
01/21/21 04:50 PM
01/21/21 04:50 PM
Massillon, Ohio
cudatom Offline
cudatom  Offline
Massillon, Ohio
Not sure but I chose Oliver 7.1 I beams for my 553(4.5 bore 4.35 stroke ) build. Compression will be a tad less than yours and should cross the line at the same rpm. I just wasn't comfortable with the others given the cost of my KB block.
Not that Olivers can't fail but I think it would be less likely.
Ok
Re: 7.1 h beam strength? [Re: gregsdart] #2877971
01/21/21 05:02 PM
01/21/21 05:02 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Only read posts you agree with
Boffin Emeritus
Re: 7.1 h beam strength? [Re: polyspheric] #2877980
01/21/21 05:31 PM
01/21/21 05:31 PM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
For a 1000 Hp I would suggest the Olivers. BUT keep in Mind that Molnar and K1 were both started by the same guy. They both come with ARP 2000 bolts. The Molnar also has the option for what they call Power Adder and Power Adder Plus where they add more Material to the beam. Actually they machine less. This makes the rod a bit heavier but also stronger. You could also look at the Pro Series from Manley.
Todd
Re: 7.1 h beam strength? [Re: sasquatch] #2877990
01/21/21 06:06 PM
01/21/21 06:06 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Why not aluminum. BME, and R&R.
Re: 7.1 h beam strength? [Re: B1MAXX] #2877997
01/21/21 06:23 PM
01/21/21 06:23 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
popcorn
Re: 7.1 h beam strength? [Re: cudaman1969] #2878002
01/21/21 06:36 PM
01/21/21 06:36 PM
NY
B1duster Offline
B1duster  Offline
NY
Is crank set up for Mopar or Chevy width rods ?
On the cheap Eagle with L-19 bolts
Not so cheap Oliver
Crower ?
and deep pockets Carrillo
08DE0748-6B12-4E7D-8C51-221368F3B5FA.png77849558-ECF8-4884-9007-DA42F1DEAA60.pngB00475E8-591A-4846-AFDD-53FF831333AA.png
Re: 7.1 h beam strength? [Re: B1duster] #2878030
01/21/21 07:53 PM
01/21/21 07:53 PM
Like it or not i may have to go with Manley or Oliver rods, about 850 more than the h beams i was looking at. I got away with running Molnor 6.86 Hemi H beams in the megablock, but what shakes my confidance in the 7.1 rods is the fact that the 7.1 rods are 11 grams lighter than the 6.86 rods.
Re: 7.1 h beam strength? [Re: gregsdart] #2878047
01/21/21 08:07 PM
01/21/21 08:07 PM
IL
E
EchoSixMike Offline
EchoSixMike  Offline
E
IL
Why not call Molnar and ask them? I talked to Tom Molnar at PRI two yrs ago and the guy is a font of knowledge. Honestly, I don't see your setup as all that aggressive. S/F....Ken M
Re: 7.1 h beam strength? [Re: EchoSixMike] #2878053
01/21/21 08:22 PM
01/21/21 08:22 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
HP means squat. What counts is reciprocating weight, rpm, and load if you run a power adder. The 7.100 rods are a modern design where unnecessary bulk was removed. Call Tom and ask. He'll give you an honest answer. Mine has Molnar 7.100". The bobweight is 2222. I was told my self imposed 7500 rpm limit was safe. Though it only runs to about 7300.
Doug
Re: 7.1 h beam strength? [Re: dvw] #2878059
01/21/21 08:33 PM
01/21/21 08:33 PM
NY
B1duster Offline
B1duster  Offline
NY
I know they are cheap and might need touched up but I don’t see the Eagles with L-19 bolts failing
They come standard with 190,000 psi rated 7/16 ARP 8740 (750 Horsepower rating) and 230,000 psi rated, 7/16 ARP 2000 rod bolts (1200 horsepower rating) or 265,000 psi rated 7/16 ARP L-19 bolts (1500 Horsepower rating) as upgrades. Each set includes Instructions and rod bolt lubrication.
I got a deal on these. If they check out ok I’m using them in my 572 Street Hemi.
They are old with Arp 2000s, but new
Re: 7.1 h beam strength? [Re: B1duster] #2878070
01/21/21 09:02 PM
01/21/21 09:02 PM
New York, USA
Chargerfan68 Offline
New York, USA
My friends rb stroker used the Callies Ultra I beam rod. Part no U15270
Very nice piece. Not cheap but supposed to be a pretty stout piece. Quality was very good and so was machining ootb.
Re: 7.1 h beam strength? [Re: gregsdart] #2878085
01/21/21 09:24 PM
01/21/21 09:24 PM
Saskatchewan, Canada
cudabin Offline
cudabin  Offline
Hey Greg,
I went with the Oliver pro billet option, and the peace of mind has been worth it to me...
Good Luck,
Arnie
67 Cuda 8.48@ 158.7 mph 1.18 60' 2,600 DA(so far...) 70 Super Bee 440 Six Pack 4-speed. 13.2 @ 104 Stock exhaust/Street tires.
Re: 7.1 h beam strength? [Re: cudabin] #2878091
01/21/21 09:33 PM
01/21/21 09:33 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Don't skimp on fasteners , which ever rod you choose.
I believe it was Barton who said it , in an article about the building of an AA/AH motor..............Use the best fasteners you can get.
Relative to all the other costs , it really seems like sound advice.
I would call Molnar and speak with Tom too. He has forgotten more about connecting rods that I ever knew.
Re: 7.1 h beam strength? [Re: tubtar] #2878110
01/21/21 10:05 PM
01/21/21 10:05 PM
L19 or SPS rod bolts are better than ARP2000 scope
Re: 7.1 h beam strength? [Re: Cab_Burge] #2878115
01/21/21 10:19 PM
01/21/21 10:19 PM
Heaven
EvilB1Dart Offline
EvilB1Dart  Offline
Heaven
Oliver H Beams or GRP Alum.
"Any fool can know. The point is to understand"
- A. Einstein
Re: 7.1 h beam strength? [Re: EvilB1Dart] #2878137
01/21/21 10:49 PM
01/21/21 10:49 PM
NY
B1duster Offline
B1duster  Offline
NY
7.05 GRP in my 604 B1
7.15 in my 540B1
Re: 7.1 h beam strength? [Re: B1duster] #2878201
01/22/21 03:40 AM
01/22/21 03:40 AM
NY
B1duster Offline
B1duster  Offline
NY
Or these
Re: 7.1 h beam strength? [Re: B1duster] #2878210
01/22/21 07:45 AM
01/22/21 07:45 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Beware of L19 bolts. For a motor that sits a lot corosion could be an issue. My Molnars have over 400 passes.
Doug
Re: 7.1 h beam strength? [Re: dvw] #2878343
01/22/21 01:15 PM
01/22/21 01:15 PM
Thanks everybody. I talked to Ed at Molnar, he said the 7.1 rods from Molnar would be fine. Two other things that will help- the new piston is going to be lighter and i plan to go to a clean neutral valvebody.
Page 1 of 4 1 2 3 4
