Carter 2 bbl BBD mystery piece #2877789
01/21/21 11:59 AM
01/21/21 11:59 AM
Indiana
MonGoo$e Offline OP
MonGoo$e  Offline OP
Indiana
Trying to get my 2 bbl Carter BBD back together with a kit, and the kits exploded view is lack luster at best in quality and I cannot seem to figure out where this part goes. Google exploded views don't seem to locate the piece either.. Mind you, it was not a rebuild piece but was already in my carb. It's Brass, and very small, small enough to fit the round accelerator shaft. But I'm pretty sure it wasn't located there. It's shouldered like this on both sides.
Any ideas?
My YouTube Channel, "Hoosier Garage"
https://www.youtube.com/HoosierGarage
Re: Carter 2 bbl BBD mystery piece [Re: MonGoo$e] #2877798
01/21/21 12:22 PM
01/21/21 12:22 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
What is year ???
Re: Carter 2 bbl BBD mystery piece [Re: a12rag] #2877801
01/21/21 12:25 PM
01/21/21 12:25 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
Originally Posted by a12rag
What is year ???
And is it a 1.1/4" or 1.1/2"? From a small block or big block?
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: Carter 2 bbl BBD mystery piece [Re: 3hundred] #2877821
01/21/21 12:55 PM
01/21/21 12:55 PM
PA
Harry's Taxi 2 Offline
PA
What is year ???
Where would it go if it was a big block?.........and then where would it go if it was a small block?
'86 Maple Grove KOS Mopar low qualifier......true street legal with no power adders.
NOS-used when losing since 1940.
Re: Carter 2 bbl BBD mystery piece [Re: Harry's Taxi 2] #2877824
01/21/21 01:03 PM
01/21/21 01:03 PM
Indiana
MonGoo$e Offline OP
MonGoo$e  Offline OP
Indiana
Sorry guys, wasn't sure if it mattered, but its a 1 1/4" and 1972 to be specific, kit calls it "Early" and its for a 318 van.
Re: Carter 2 bbl BBD mystery piece [Re: MonGoo$e] #2877915
01/21/21 03:28 PM
01/21/21 03:28 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
I'm assuming you have the accelerator pump with the round rod rather than the flat rod?
Re: Carter 2 bbl BBD mystery piece [Re: 6PakBee] #2877965
01/21/21 04:51 PM
01/21/21 04:51 PM
Indiana
MonGoo$e Offline OP
MonGoo$e  Offline OP
Indiana
that is correct, round rod with spring, clip, cup, etc.
Re: Carter 2 bbl BBD mystery piece [Re: MonGoo$e] #2879196
01/23/21 11:25 PM
01/23/21 11:25 PM
S.E.Ohio
Magnumguy Offline
Magnumguy  Offline
S.E.Ohio
I may have a couple of them laying around with the round shaft. I'll see what I can find. I don't think it has anything to do with the accel pump. At 1st glance
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
Re: Carter 2 bbl BBD mystery piece [Re: Magnumguy] #2879413
01/24/21 02:58 PM
01/24/21 02:58 PM
moparx Offline
moparx  Offline
i remember one of the kit manufacturers [tomco maybe ?] always included an exploded carb view that showed where all the kit parts went, as well as what the kit name for the part was.
maybe that isn't done anymore to save a couple of pennies a kit ? shruggy
i haven't bought a kit for years. mainly, because i have nothing that runs presently.
beer
Re: Carter 2 bbl BBD mystery piece [Re: moparx] #2879441
01/24/21 03:41 PM
01/24/21 03:41 PM
N
NITROUSN Offline
NITROUSN  Offline
N
What is the number of this carburetor? For some reason I thought the round pump shafts were newer than 72.
Re: Carter 2 bbl BBD mystery piece [Re: NITROUSN] #2880098
01/25/21 07:34 PM
01/25/21 07:34 PM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
Looks too rusty to be an internal piece.
