Re: Diesel cab vs. gas cab
[Re: redraptor]
#2877548
01/20/21 09:16 PM
01/20/21 09:16 PM
Posts: 18,419 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
The cabs are a direct bolt on. Diesel to gas wiring is different as well as some cluster items. So plan on gutting both cabs and using most of the diesel items in the gas cab. The 4wd has a floor hump you will need to cut out and fit into the 2wd cab. I assume you are going 4wd.
[Re: redraptor]
#2877554
01/20/21 09:22 PM
01/20/21 09:22 PM
Posts: 2,111 Byron, NY
W.I.N. Racing
Byron, NY
I would say there is no appreciable difference... I did a Cummins swap into a '80 cab from a '92 cab on a '83 chassis and the only thing I needed to change was the bulkhead opening and the heater box opening ( that was the difference between the '80 and '83 cab). Other than that I swapped the entire pedal assembly, elec. harness...everything straight bolt in. So a '92 to a 91 cab should be effortless.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: NITROUSN]
#2878006
01/21/21 06:49 PM
01/21/21 06:49 PM
Posts: 5,961 Greenville, PA
redraptor
Greenville, PA
Diesel to gas wiring is different as well as some cluster items. So plan on gutting both cabs and using most of the diesel items in the gas cab. The 4wd has a floor hump you will need to cut out and fit into the 2wd cab. I assume you are going 4wd. That's what I thought. Outwardly the dashboard doesn't look much different than gas truck but I don't know. I know that the humps are different and I've done that before on my mud truck. This is a ton of work and have done it in the past. The only reason I'm considering this is it's a 2 owner truck and I know both owners. Never owned a diesel truck so I want to tinker.
[Re: NITROUSN]
#2878611
01/22/21 09:17 PM
01/22/21 09:17 PM
Posts: 5,818 ohio
ruderunner
ohio
it may be more work but I think you'll end up with a better truck if you consider the diesel a donor.
If the 91 dump is clean, I'd put the diesel in it rather then swap bodies and fix frames. Most of the holes are in the rails for the 4wd parts to go into.
Angry white pureblood male
[Re: ruderunner]
#2878684
01/22/21 11:32 PM
01/22/21 11:32 PM
Posts: 6,562 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
If the 91 dump is clean, I'd put the diesel in it rather then swap bodies and fix frames. Most of the holes are in the rails for the 4wd parts to go into. Just so I'm clear, you're saying 4 wheel drive into a 2 wheel drive chassis is mostly a bolt in? I know we're discussing 250 and 350 trucks so would the same be true for a 150? Kevin
[Re: ruderunner]
#2878757
01/23/21 07:38 AM
01/23/21 07:38 AM
redraptor
Greenville, PA
Most of the holes are in the rails for the 4wd parts to go into. Buried somewhere here is a thread on doing that conversion and it didn't sound easy. There's something different about the front besides the strut rod brace.
[Re: redraptor]
#2878832
01/23/21 11:57 AM
01/23/21 11:57 AM
NITROUSN
Most of the holes are in the rails for the 4wd parts to go into. Buried somewhere here is a thread on doing that conversion and it didn't sound easy. There's something different about the front besides the strut rod brace. Converting a frame is not easily done. Better off having a good frame for the application and transfer over all the parts.
[Re: redraptor]
#2879554
01/24/21 07:16 PM
01/24/21 07:16 PM
Posts: 5,818 ohio
ruderunner
ohio
To the best of my research, the only holes not present on a 2wd frame are for the shackles. Applies to all weight classes of D and W trucks.
Note, there's a big difference in steering design in the late 70s that makes the donor choice more important.
I'll be doing this swap next winter on my D250. I'm currently rebuilding a Dana 60 axle, have springs and mounts to freshen, picking up transmission parts tomorrow. If you have a complete donor truck it's much easier, I've gathered parts from various junkers over the years. There's plenty of parts that get changed, biggest bugaboo is cutting all the factory rivets.
There's a fellow on Cumminsforum who has done enough conversions that he can do them in 2 weekends.
[Re: NITROUSN]
#2880838
01/27/21 11:42 AM
01/27/21 11:42 AM
Posts: 7,831 east side of Ohio
basketcase
east side of Ohio
If the floor hump in the donor cab is different just reuse the hump from the diesel cab. That is a cut and weld not a bolt in. yes it is.not a hard thing to do.
1981 Dodge D150 360 auto
[Re: basketcase]
#2881055
01/27/21 07:23 PM
01/27/21 07:23 PM
Posts: 5,818 ohio
ruderunner
ohio
Cut for sure, but I don't see any reason why it has to be welded.
