Re: 340 engine not starting, out of ideas [Re: calrobb2000] #2876321
01/18/21 09:54 PM
01/18/21 09:54 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
Originally Posted by calrobb2000
this plus a bad resistor !
if you have the resistor with msd remove the resistor !
A bad ballast resistor will cause a no run condition, but not a no start as the resistor is bypassed while engine is cranking....it will start, but die immediately as key is released to the run condition, which does not appear to be the situation with the OP s car.
Re: 340 engine not starting, out of ideas [Re: Pacnorthcuda] #2876333
01/18/21 10:28 PM
01/18/21 10:28 PM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
doul balist resister maby ?
Re: 340 engine not starting, out of ideas [Re: calrobb2000] #2876411
01/19/21 08:44 AM
01/19/21 08:44 AM
Netherlands
72Challenger Offline OP
Netherlands
As for fresh gas it's no way old but even then, brake cleaner doesnt do a thing as well, says a lot if you ask me. Even tryed with a seperate battery hooked up to the msd alone to rule out voltage drop to the ignition, but in both situations the voltage stays during the cranking, have a good blue spark from the coil wire during cranking so voltage parts should be ruled out.
Gonna pull the distributor cap tonight to see if the rotor turns logically when cranking
Gonna remove the carb and crank with some brake cleaner to see if it gives a rumble to rule out the carb as well as it feels like the engine is drowning somehow not sparking in the cylinder.
And new plugs again too.
Some questions read concerning ignition system; msd 6al wired directly from the battery (already changed out), no resistors etc. 6al connects to blaster coil (already changed out) with the black & orange wires and also wires to a stock mopar distributor (already changed out) no real voltage drop (see above)
To my feeling its like either drowing way to much fuel which kils the spark (plugs) or having no intake speed not atomizing the fuel or something timing related.
And why doesnt the sound change at all when turning (like an 1" both sides) the distributor while cranking
To be continued..
Re: 340 engine not starting, out of ideas [Re: Pacnorthcuda] #2876470
01/19/21 10:59 AM
01/19/21 10:59 AM
Missouri
randavis Offline
randavis  Offline
Missouri
This is only true if the ballast resistor has only two terminals. The later ballasts had four terminals.It depends on which side of the ballast is bad. I have had this exact condition and it was a bad ballast resistor.
Agree with the removal of ballast resistor with msd.
74 Challenger, bought it new. In 1978 I replaced the original 318 with a 446 and 727. Mild cam, Jardine headers, and Holley Sniper EFI.
New engine! 511" RB, Edelbrock Performer RPM heads, Eagle rotating assy, Comp hyd roller cam, Doug's 2" headers.
Re: 340 engine not starting, out of ideas [Re: randavis] #2876484
01/19/21 11:28 AM
01/19/21 11:28 AM
A727Tflite Offline
A727Tflite  Offline
x
Re: 340 engine not starting, out of ideas [Re: Pacnorthcuda] #2876511
01/19/21 12:06 PM
01/19/21 12:06 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
Originally Posted by Fat_Mike
Anyone remember a thread about a car that starts when you let OFF the key? As in, turn the key to "start" and it cranks, but won't start until the key is released and turns back to "run." I can't remember the cause (probably ignition), and can't find the thread. Thoughts on that???
That is either an ignition switch or more commonly it’s the bulkhead connector not making the connection on the start circuit to the coil.
Yes. This was the issue one of my E-Bodies.
I was able to start the car with a remote bump starter. Took the bulkhead connector off, cleaned with a small wire brush and compressed air, used the key start, vrooom, away it went. punkrocka
So, try hooking up a remote starter to your car, it by-passes the bulkhead connector. twocents
If it lights off, it could be your bulkhead connector.
If not, I'd start by throwing that aftermarket MSD junk in the garbage and replace with Factory parts and keep working backwards until it goes.
Mo' Farts
Moderated by "tbagger".
Re: 340 engine not starting, out of ideas [Re: Grizzly] #2876541
01/19/21 01:13 PM
01/19/21 01:13 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Stale gas? If it's 6 months old, it's stale.
Brake cleaner? Brake cleaner won't really burn and if it did run off of it, it will injure or kill you. Phosgene.
Regular 2+2 is a better choice. The engine will run on it. Still need to be used outside.
Re: 340 engine not starting, out of ideas [Re: CMcAllister] #2876560
01/19/21 01:31 PM
01/19/21 01:31 PM
Canada
RobR Offline
RobR  Offline
Canada
Check for spark at the plugs ! I'd bet it's weak...Check the resistance of the plug wires also...
Re: 340 engine not starting, out of ideas [Re: RobR] #2876568
01/19/21 01:39 PM
01/19/21 01:39 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
He did, that's why I suggested substituting a good known ignition system to isolate the MSD from the trouble.
"Get spark on the plugs as well.
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: 340 engine not starting, out of ideas [Re: CMcAllister] #2876578
01/19/21 01:49 PM
01/19/21 01:49 PM
Alberta
440_Offroader Offline
Alberta
So, do you have a choke on it? Possibly not opening enough? I agree with not using brake clean to run, just use a squirting bottle with gasoline. As mentioned, I'd verify TDC and double check timing. I'm not sure how much change in compression there would be if the timing chain has jumped? I'd maybe check cam timing if you're running out of ideas. Single bolt cam? Single bolt cams have been known to move, if bolt comes loose and breaks the dowel, dowel maybe gone? Just shooting ideas...
Re: 340 engine not starting, out of ideas [Re: 440_Offroader] #2876595
01/19/21 02:20 PM
01/19/21 02:20 PM
moparx Offline
moparx  Offline
what voltage do you get at the + post of the coil while cranking ?
beer
Re: 340 engine not starting, out of ideas [Re: moparx] #2876616
01/19/21 02:48 PM
01/19/21 02:48 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
beer
Pretty sure you don't want to measure that with an MSD setup
Re: 340 engine not starting, out of ideas [Re: Sniper] #2876755
01/19/21 06:00 PM
01/19/21 06:00 PM
Apollo, PA.
B1MAXX Online content
B1MAXX  Online Content
Apollo, PA.
Whats wrong with starting fluid? That's what I use on stubborn engines.
Re: 340 engine not starting, out of ideas [Re: Sniper] #2877267
01/20/21 02:08 PM
01/20/21 02:08 PM
moparx Offline
moparx  Offline
beer
OOPS ! blush my mistake ! sorry !
beer
Re: 340 engine not starting, out of ideas [Re: B1MAXX] #2877497
01/20/21 08:05 PM
01/20/21 08:05 PM
541 slobovia
A990 Offline
A990  Offline
541 slobovia
Not a thing. Instant reprime.
Re: 340 engine not starting, out of ideas [Re: A990] #2877716
01/21/21 09:12 AM
01/21/21 09:12 AM
Apollo, PA.
Apollo, PA.
I have been around cars a long time and have never even contemplated using brake clean for starting a stubborn engine Some brake clean will hardly even burn. I have used starting fluid as brake clean though....its cheaper.
Re: 340 engine not starting, out of ideas [Re: NITROUSN] #2877737
01/21/21 10:29 AM
01/21/21 10:29 AM
Minn
SportF Offline
SportF  Offline
Minn
Originally Posted by NITROUSN
I would pull the plugs and see if they are wet. Squirt a couple shots of oil in each hole. Verify timing on TCD and the rotor pointing at number 1. Make sure the oil is not diluted with gas. Either clean or replace the plugs. And see what it does. Could be the rings are washed .
Anytime you have been trying to start an engine this long you have washed down the cylinders, Do what NITROUSN said and squirt oil in the cylinder. Don't be shy, squirt a bunch in there. Then try again. And don't worry about it fouling the plugs, it will go.
Re: 340 engine not starting, out of ideas [Re: SportF] #2877771
01/21/21 11:17 AM
01/21/21 11:17 AM
^^^ that would explain why it is cranking over 100 miles per hour bow
Re: 340 engine not starting, out of ideas [Re: SportF] #2877883
01/21/21 02:14 PM
01/21/21 02:14 PM
Wheatfield, NY
Cuda340 Offline
Cuda340  Offline
Wheatfield, NY
This!!!! Using brake clean removed the oil off the cylinder walls and washed down the cylinders. Do what Nitrousn said and se if that works. It may be too late unfortunately.....
Re: 340 engine not starting, out of ideas [Re: Cuda340] #2877911
01/21/21 03:22 PM
01/21/21 03:22 PM
North Dakota
6PakBee Online content
6PakBee  Online Content
North Dakota
If it's not squeaking when it's turning over, it's probably not too late.
