70 Plymouth 440 naming question #2876458
01/19/21 10:43 AM
01/19/21 10:43 AM
Connecticut
jeff968 Offline OP
jeff968  Offline OP
Connecticut
So, after 40 years of heavy Mopar involvement I learned something new from Steve's junkyard gold show this weekend. And I have a question....
In 1970 if you purchased a 440 4bbl 'Cuda you got a 375hp motor labeled the "440 Super Commando" and with a pie pan on the air cleaner that said that.
In 1970 if you purchased a 440 4bbl GTX you got a 375hp motor labeled the "440 Super Commando" and with a pie pan on the air cleaner that said that.
BUT....
In 1970 if you purchased a 440 4bbl Fury GT you got a 350hp motor! I never noticed this difference in 440 4bbls from the rest of the Rapid Transit System.
SO MY QUESTION.....
What did they call this 350hp version of the 440 in the Fury GT and what appeared on the pie pan on the air cleaner?
1970 Dodge Challenger T/A
Re: 70 Plymouth 440 naming question [Re: jeff968] #2876574
01/19/21 01:43 PM
01/19/21 01:43 PM
SE Pa.
LimeliteAero Offline
SE Pa.
I believe it's referred to as TNT? amazing how much stuff gets lost in the brain.
Re: 70 Plymouth 440 naming question [Re: LimeliteAero] #2876602
01/19/21 02:33 PM
01/19/21 02:33 PM
Connecticut
jeff968 Offline OP
jeff968  Offline OP
Connecticut
Nope, the 440-TNT was the 440/375 hp motor which can be found in the 1970 Chrysler Hurst 300.
Re: 70 Plymouth 440 naming question [Re: jeff968] #2876656
01/19/21 03:41 PM
01/19/21 03:41 PM
Lansing, MI
70gtx440dana Offline
Lansing, MI
70-71 parts book shows the same pie tin for the air cleaner on Dodge and plymouth B, C and E bodies......either 440 super commando or 440 magnum. The 440 TNT is only shown on Chrysler C body.
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: 70 Plymouth 440 naming question [Re: jeff968] #2876657
01/19/21 03:43 PM
01/19/21 03:43 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
the '70 Sport Fury GTs with the blue "T"-code 350hp 440s still received the "SUPER COMMANDO" pie tin
Re: 70 Plymouth 440 naming question [Re: 6bblgt] #2876682
01/19/21 04:02 PM
01/19/21 04:02 PM
Connecticut
jeff968 Offline OP
jeff968  Offline OP
Connecticut
Excellent!!! Thank you. I hadn't even thought about the engine paint color but it makes total sense.
Re: 70 Plymouth 440 naming question [Re: jeff968] #2876698
01/19/21 04:24 PM
01/19/21 04:24 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
c-bodies are a "different world"
NO 383HP for 1970, but the N-code blue CARTER carb'd 330hp engine had dual exhaust manifolds
the Sport Fury GT's 350hp blue 440 had dual exhaust without dual exhaust manifolds
Re: 70 Plymouth 440 naming question [Re: jeff968] #2876896
01/19/21 09:52 PM
01/19/21 09:52 PM
North Pole,New York
formula_s Offline
formula_s  Offline
North Pole,New York
A few things he got wrong on last weeks show. When he went through the 70 Fury line-up he mentioned Fury I, FuryII,FuryIII ,Sport Fury, Sport Fury GT and the little known S23. He didn't mention the Grand Coupe,available only as a 2 door with a lo perf 383,(L code) and in brown with a paisley top. He mentioned 14 inch tires on the Fury. My 70 had G78-15's from the factory.
Re: 70 Plymouth 440 naming question [Re: formula_s] #2876918
01/19/21 10:20 PM
01/19/21 10:20 PM
Long Island, NY
shakerjoe Offline
shakerjoe  Offline
Long Island, NY
I just watched this episode today...I thought Steve said the ‘71 440 had 375hp like in ‘70...which would be incorrect as we all know there was a HP drop across the board other than the hemi, I’ll have to watch again. Some great cars though...the sport fury 440-4bbl 4spd ‘vert...holy cow what a car. The polara 4spd with cruise...👍
Re: 70 Plymouth 440 naming question [Re: shakerjoe] #2877230
01/20/21 01:38 PM
01/20/21 01:38 PM
North Pole,New York
formula_s Offline
formula_s  Offline
North Pole,New York
........we all know there was a HP drop across the board other than the hemi.........
Joe, the '71 340 was rated @ 275 just like in '70.
