70 Plymouth 440 naming question
#2876458
01/19/21 10:43 AM
01/19/21 10:43 AM
Posts: 4,051 Connecticut
jeff968
Connecticut
So, after 40 years of heavy Mopar involvement I learned something new from Steve's junkyard gold show this weekend. And I have a question....
In 1970 if you purchased a 440 4bbl 'Cuda you got a 375hp motor labeled the "440 Super Commando" and with a pie pan on the air cleaner that said that.
In 1970 if you purchased a 440 4bbl GTX you got a 375hp motor labeled the "440 Super Commando" and with a pie pan on the air cleaner that said that.
BUT....
In 1970 if you purchased a 440 4bbl Fury GT you got a 350hp motor! I never noticed this difference in 440 4bbls from the rest of the Rapid Transit System.
SO MY QUESTION.....
What did they call this 350hp version of the 440 in the Fury GT and what appeared on the pie pan on the air cleaner?
1970 Dodge Challenger T/A
Re: 70 Plymouth 440 naming question
[Re: LimeliteAero]
#2876602
01/19/21 02:33 PM
01/19/21 02:33 PM
jeff968
Connecticut
I believe it's referred to as TNT? amazing how much stuff gets lost in the brain. Nope, the 440-TNT was the 440/375 hp motor which can be found in the 1970 Chrysler Hurst 300.
[Re: jeff968]
#2876656
01/19/21 03:41 PM
01/19/21 03:41 PM
Posts: 3,519 Lansing, MI
70gtx440dana
Lansing, MI
70-71 parts book shows the same pie tin for the air cleaner on Dodge and plymouth B, C and E bodies......either 440 super commando or 440 magnum. The 440 TNT is only shown on Chrysler C body.
70 Road Runner 383-4 4 speed FJ5 & black guts 70 Charger R/T 440-4 4 speed FJ5 & white guts
[Re: 6bblgt]
#2876682
01/19/21 04:02 PM
01/19/21 04:02 PM
jeff968
Connecticut
the '70 Sport Fury GTs with the blue "T"-code 350hp 440s still received the "SUPER COMMANDO" pie tin Excellent!!! Thank you. I hadn't even thought about the engine paint color but it makes total sense.
[Re: jeff968]
#2876896
01/19/21 09:52 PM
01/19/21 09:52 PM
Posts: 4,998 North Pole,New York
formula_s
North Pole,New York
A few things he got wrong on last weeks show. When he went through the 70 Fury line-up he mentioned Fury I, FuryII,FuryIII ,Sport Fury, Sport Fury GT and the little known S23. He didn't mention the Grand Coupe,available only as a 2 door with a lo perf 383,(L code) and in brown with a paisley top. He mentioned 14 inch tires on the Fury. My 70 had G78-15's from the factory.
