Read these plugs
#2876136
01/18/21 03:19 PM
01/18/21 03:19 PM
Posts: 4,179 California
mickm
California
My 02 gauge has been erratic lately, and has been showing off the scale readings, more than 18:0 to 1 - under WOT.
At this point I'm pretty sure it is the sensor, which I'm going to try to clean or certainly replace.
Wanting to know if if that was anywhere near correct, like, am I about to melt the pistons, I did a WOT shutdown after about 4 seconds.
These are the plugs.
Any comments? By the sooty layers around the base ring, I'm thinking it's running rich? I wasn't expecting that, I assumed if anything it would be lean.
The first two photos are cylinder 4, the second cylinder 2. Unfortunately, the camera didn't focus on the top of the plug, but more the middle and my hand. At least I know for next time!
Re: Read these plugs
[Re: mickm]
#2876143
01/18/21 03:40 PM
01/18/21 03:40 PM
RapidRobert
there is a racing company with excellent pics on this that has been posted here but I been racking my brain & I cannot remember it. You might Google it. Here's a BTT
[Re: RapidRobert]
#2876353
01/18/21 11:08 PM
01/18/21 11:08 PM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
Were those plugs "new" before the test? They look fat and I don't see the burn on the elbow of the strap. In 4 seconds were you in the top of 2nd? What rpm?
[Re: hemi-itis]
#2876369
01/18/21 11:48 PM
01/18/21 11:48 PM
Posts: 4,457 Washington
madscientist
Washington
It’s pretty fat. You are nowhere near lean.
[Re: Cab_Burge]
#2876416
01/19/21 09:17 AM
01/19/21 09:17 AM
Posts: 13,357 Marion, South Carolina [><]
an8sec70cuda
If these plugs weren't new and used only for the WOT blast, they won't tell you much of anything.
[Re: mickm]
#2876474
01/19/21 11:10 AM
01/19/21 11:10 AM
Posts: 875 Missouri
jwb123
Missouri
It looks like they have been in the engine for a while, mixture is a little rich, and looks like you are burning a little oil. I would have to feel the black soot around the ring of the plug to tell, sometimes I wipe it on a piece of white paper. dry black is rich soot, oil is a little wet, to the touch.. You can tell a lot or a little from reading the plugs, depending how you do the procedure. WOT clean cut off, on the dyno, or at the track tells you the most. And a fresh plug each run. I am a tight wad, when tuning, a lot of the times, I will just put in one plug new each pass, until I get close. From the heat mark on the strap, the timing is close, maybe could use a couple degrees more. If you are rich at idle, the soot will cover over the WOT marking, by the time you get back to the pits.
On my drag car, the plugs read a little rich, when the O2's are at 12.5, the plugs start to turn tan colored, when, I read 13 to 1, I guess it is the placement of the sensor in the collector. Nothing is 100%, I just look at how many tools to get it right. Of course the time slip is the final proof, of how it is running.
[Re: jwb123]
#2876488
01/19/21 11:34 AM
01/19/21 11:34 AM
Posts: 8,021 Tulsa OK
Bad340fish
Tulsa OK
A cylinder misfire will read lean on the 02 meter.
68 Barracuda Formula S 340
[Re: mickm]
#2876536
01/19/21 01:03 PM
01/19/21 01:03 PM
hemi-itis
New plugs,new test and shut off at the top of 2nd gear so rpm is above 5500 to get a fair reading for WOT.
