I can't remember the name of the ceramic sealer I bought from Goodson years ago to seal a old Mopar top fuel cast iron block that had multiple leaks from someone grinding in the crankcase to clear the aluminum rods and stroker crank counter weights, it was a mess.
I tried first filling the block with block filler to the bottom of the freeze plugs, that didn't work
next was the Goodson sealer that I had to put into the block and use a torque plate too seal the cooling system up along with some plates to pour the filler in and use a air hose fitting to pressurize it to put 15lbs. pressure on top of the sealer for 15 minutes and then drain it out and do the other side. The final step was to have it bake at 300 or 350 degrees in a powder coat oven for 20 minutes. It never leak a drop after that
On your deal I would be tempted to try and use one small container of Aluma Seal first in the motor while running and driving it so it has pressure on the sleeve to help force that sealer into the leak
If that stops the leak make sure and change the oil and filter several times with very little run time between the 2 or 3 changes to make sure to flush the water and any other chemical put into the oil from the cooling system like antifreeze
