Re: rebuilt 727 lurches in park, why?
[Re: frank]
#287556
04/13/09 08:27 PM
04/13/09 08:27 PM
Posts: 763 Southington Ct.
turbobitt
Southington Ct.
This is very normal. Chances are that the rear clutch pack is a little on the tight side.
1970 Challenger w/572 Hemi street car and my pride and joy.
1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno.
1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
[Re: 74fldart]
#287559
04/13/09 09:20 PM
04/13/09 09:20 PM
RapidRobert
is it a creeping forward like if you were in drive or just the vehicle rolling forward a bit until the pawl catches?
[Re: 74fldart]
#287561
04/13/09 09:51 PM
04/13/09 09:51 PM
RapidRobert
The linkage may be off a bit to where the valve is either slightly in or out too far & dont know if thats a problem that'll get worse or not or is causing any other pressure issues inside but we better wait for Kunkel to chime in.
[Re: 74fldart]
#287562
04/14/09 01:16 AM
04/14/09 01:16 AM
Posts: 26,037 Rio Linda, CA
John_Kunkel
Rio Linda, CA
If the car doesn't drive forward in Neutral a significant distance it's OK, just a tight rear clutch pack.
[Re: 74fldart]
#287564
04/14/09 03:01 PM
04/14/09 03:01 PM
Posts: 75,125 A Banana Republic near you.
JohnRR
thanks for all the replies, no , it never moves forward . i think it just needs to be driven and it should loosen up a little i hope. i can live with it .
Driving it is not going to loosen up the rear clutch pack unless you do a few hundred miles in REVERSE , the rear clutch is applied in ALL FORWARD GEARS .
Check your shifter adjustment .
