Re: Starter will not disengage new motor
[Re: 71Pan]
#2875051
01/16/21 12:07 PM
01/16/21 12:07 PM
Posts: 19,355 north of coder
moparx
was the transmission case measured with a dial indicator for runout mated to the new block ? if not, the drive gear could be jammed into the converter teeth causing the starter drive to stick. just the first thing i thought of.
[Re: moparx]
#2875061
01/16/21 12:43 PM
01/16/21 12:43 PM
Posts: 3,277 West Coast, USA
jbc426
West Coast, USA
was the transmission case measured with a dial indicator for runout mated to the new block ? if not, the drive gear could be jammed into the converter teeth causing the starter drive to stick. just the first thing i thought of. My thoughts too. Also does the bellhousing have a locating hole for the starter snout? I have disassembled starters that have suffered heat soak, found corrosion on the plunger on most of them, cleaned the solenoid plunger and bore and coated them with a light coating of synthetic disc brake grease(one of my favorite greases).
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: 71Pan]
#2875066
01/16/21 12:57 PM
01/16/21 12:57 PM
Posts: 2,675 Mt. Eden Ky.
Hemi Allstate
Mt. Eden Ky.
Helping a friend pulled his 450 inch small block and put new 470 inch motor in. The starter will not disengage on new motor . The car has front and mid plate new flex plate. Everything looks correct. Converter not hitting crank . Tried diffrent starters the same. Any ideas I had this happen while using a Ford type remote solenoid. The contacts in the solenoid were sticking. An upgrade to higher capacity part solved the problem. Mark
[Re: 440Jim]
#2875573
01/17/21 03:09 PM
01/17/21 03:09 PM
Posts: 8,094 Sunnyvale, CA
Jeepmon
Sunnyvale, CA
One other thing to check. The starter might need a shim (away from the transmission). Agreed, every time my start wont disengage, it because I left out a shim washer.
[Re: Jeepmon]
#2876133
01/18/21 03:18 PM
01/18/21 03:18 PM
moparx
if i remember, the DC manual stated the starter drive gear tip to the converter ring gear tooth root was to be around .060 or so. the way they said to check was to pull the drive gear into the ring gear and use a common paper clip for a clearance check gauge. i have ran into the mini starter to block casting interference more than a bunch of times over the years. if one starter hits, the next may not. i blame this on machining tolerance stack up, as well as casting variances on both the starter[s] and the block[s].
