What alloy are my Arias pistons? #2874195
01/14/21 11:39 AM
01/14/21 11:39 AM
Northeast Indiana
73DAD Offline OP
73DAD  Offline OP
Northeast Indiana
I bought a set of pistons second-hand but they came with no information sheet. I would like to know if they are 2618 or 4032 alloy so I can set the proper piston to wall clearance.
They are +.060" 426 Hemi pistons. Under the dome they are marked with the arias 'A' and the 'Speedmaster' logo. There are no other marks or coatings.
Skirts measured at 4.308"
Compression height measured about 1.765"
Dome Height is about .515"
Total Height from pin centerline to top is 2.28"
Dome volume is about 85cc
Pin diameter is 1.094" retained by spiral locks
Rings are 1/16, 1/16, 3/16
The skirts have a couple oil grooves going around them.
The wrist pin holes have 2 oiling holes per side. (4 per piston)
They may have been sold new to FHO in Canada in the early nineties. Know its a long shot, but any help would be much appreciated. I already E-mailed Arias so far, but haven't tried FHO yet.
Re: What alloy are my Arias pistons? [Re: 73DAD] #2874340
01/14/21 04:23 PM
01/14/21 04:23 PM
If they are intended for racing they will NOT be the street alloy twocents
If they have a job number or part number on them call Tim at FHO 905-797-2459 and ask him about them scope
Re: What alloy are my Arias pistons? [Re: 73DAD] #2874434
01/14/21 07:32 PM
01/14/21 07:32 PM
AndyF Online content
AndyF  Online Content
Good luck with that. The very first stroker motor I ever did was done with some Ross pistons that Muscle Motors sold me. The pistons they sold me were blower pistons but they didn't tell me that. The shop set them up as if they were normal pistons and I scuffed one of them the first time the engine got warm. That Muscle Motors rotating assembly was only one step up from junk but I was too dumb to realize it at the time.
Re: What alloy are my Arias pistons? [Re: AndyF] #2874450
01/14/21 07:57 PM
01/14/21 07:57 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I’m gonna go with........ “aluminum alloy” smoke
Re: What alloy are my Arias pistons? [Re: fast68plymouth] #2874538
01/14/21 11:25 PM
01/14/21 11:25 PM
you be correct thumbsgrin
Re: What alloy are my Arias pistons? [Re: Cab_Burge] #2874653
01/15/21 11:03 AM
01/15/21 11:03 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Do you have anyone in your area that could do a metallurgical analysis for you? I see the aluminum percentage varies quite a bit between the two alloys (85% vs. 94%) with most of the difference being made up with silicon. This should be a cakewalk for a lab.
Re: What alloy are my Arias pistons? [Re: 6PakBee] #2874667
01/15/21 11:36 AM
01/15/21 11:36 AM
Northeast Indiana
73DAD Offline OP
73DAD  Offline OP
Northeast Indiana
I reckon I'll just run them loose and let them slap, the block is junk so nothing to lose anyway. I'm thinking maybe like .006"-.008" piston to wall.
Why didn't I think of that? Lemme just pop on down to the corner metallurgical analysis lab. I hear they're running a 'buy one spectrum analysis, get one rockwell hardness test free' deal...
Re: What alloy are my Arias pistons? [Re: 73DAD] #2874678
01/15/21 12:08 PM
01/15/21 12:08 PM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
Unless they are something special your Arias pistons should be a 2618 alloy, which is what the vast majority of racing pistons use. One post mentioned scuffing with the 2618 alloy, and my experience is that since the 2618 alloy is also very hard, even with proper clearance, scuffing can be a problem, I know it has been on my engines over the years. Most of my engines go 4 years or so, and I like ross pistons, many times they will show scuffing on the cylinders. And it is the alloy, not the pistons.
The 4031 alloy forged pistons, with a 12% silicone content are getting popular, I would not hesitate to run them on say a bracket type engine, and also from my experience they do help a lot with cylinder wall scuffing. The expand about 15% less than the 2618 alloy, so you need less clearance, that helps keep the rings sealed up better as well.
The 4031 alloy is not the same as the Hypereutectic high silicone cast pistons which I think have around 20% silicone content. Several years ago they started using hypereutectic pistons in OEM engines, and I am seeing lots of stock replacement cast pistons for older engines coming as hypereutectic castings. I don't mind the change in material, except they have stopped putting in the warnings for clearance and ring end gap changes needed for hypereutectic VS regular cast pistons. So you got to be careful to figure out what you have.
Re: What alloy are my Arias pistons? [Re: 73DAD] #2874767
01/15/21 03:13 PM
01/15/21 03:13 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Hmm.
SGS North America Inc.
Columbus, IN 47201
Element Materials Technology
Columbus, IN 47201
Daleville, IN 47334
Fort Wayne, IN 46803
South Bend, IN 46628
Warsaw, IN 46580
Team Industrial Services
Crown Point, IN 46307
Fort Wayne Metals
Fort Wayne, IN 46809
Hmm. whistling
Re: What alloy are my Arias pistons? [Re: 73DAD] #2874800
01/15/21 04:49 PM
01/15/21 04:49 PM
Northeast Indiana
73DAD Offline OP
73DAD  Offline OP
Northeast Indiana
Got what I needed, .007"
Re: What alloy are my Arias pistons? [Re: 73DAD] #2874812
01/15/21 05:06 PM
01/15/21 05:06 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Kinda on topic, how do you pronounce Arias? I've heard it pronounced uh-rye-us and air-ee-eez.
Re: What alloy are my Arias pistons? [Re: John_Kunkel] #2874848
01/15/21 06:30 PM
01/15/21 06:30 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Kind of off topic but how do you pronounce Weiand? Why-and or Whee-and?
Re: What alloy are my Arias pistons? [Re: John_Kunkel] #2874883
01/15/21 07:54 PM
01/15/21 07:54 PM
Julie Arias, former wife of Nick Arias Jr. pronounced it like Aireus, if I'm remembering correctly now luck
I haven't talk to her or seen her in a long while shruggy
She use to work for NHRA at a lot of the west coast national and division 7 races.
Re: What alloy are my Arias pistons? [Re: 6PakBee] #2875049
01/16/21 11:56 AM
01/16/21 11:56 AM
moparx Offline
moparx  Offline
Y-and.
beer
Re: What alloy are my Arias pistons? [Re: moparx] #2875052
01/16/21 12:07 PM
01/16/21 12:07 PM
A727Tflite Offline
A727Tflite  Offline
Almost cast in stone.....
Re: What alloy are my Arias pistons? [Re: A727Tflite] #2875060
01/16/21 12:30 PM
01/16/21 12:30 PM
Super Spudsville
Mr PotatoHead Offline
Half Baked
Half Baked
Super Spudsville
I used to run three of them on a modified pull tractor, whenever calling for parts or even buying the complete motors which way back it was pronounced just as its reads, maybe the more "professional" drag people had to put a un needed spin on it.
STOP POTATO HATE!
Re: What alloy are my Arias pistons? [Re: Mr PotatoHead] #2875086
01/16/21 01:29 PM
01/16/21 01:29 PM
A727Tflite Offline
A727Tflite  Offline
How many guys pronounce Edelbrock as “eldebrock”?
Must be something with some guys tongues. shruggy
Re: What alloy are my Arias pistons? [Re: A727Tflite] #2876121
01/18/21 03:01 PM
01/18/21 03:01 PM
moparx Offline
moparx  Offline
kind of like "al YOU min E yum"............ biggrin
beer
