What rear frame is this? #2873473
01/13/21 12:12 AM
01/13/21 12:12 AM
Round Lake Beach, Illinoisy
Rhinodart Offline OP
Rhinotruck
Rhinotruck
Got this in a parts deal a decade ago, just dug it out from where it has been. I have some idea what it came from, either a 70-71 B or E Body but not sure. It may be the same frame but I am an A-Body guy and just want to make sure. It can be used for a Mopar guy who always wanted to say "frame off restoration"! laugh2
JB Rhinehart, Realist
A-Body's RULE!
Re: What rear frame is this? [Re: Rhinodart] #2873523
01/13/21 05:41 AM
01/13/21 05:41 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
I think you could measure the spring shackles provision from center to center and run to the axle dimensions chart for comparison. That will discard lot of options.
Re: What rear frame is this? [Re: NachoRT74] #2873577
01/13/21 10:01 AM
01/13/21 10:01 AM
Rhinotruck
Rhinotruck
Makes sense, the frame is pretty wide where the axle would bolt to that is why I am thinking E or B body, I will do just that when I get back over to the shop on Thursday, thanks!
A-Body's RULE!
Re: What rear frame is this? [Re: Rhinodart] #2873938
01/13/21 07:44 PM
01/13/21 07:44 PM
North Carolina
469runner Offline
469runner  Offline
North Carolina
Looks like a B body subframe.
Re: What rear frame is this? [Re: 469runner] #2873954
01/13/21 08:12 PM
01/13/21 08:12 PM
fredericksburg,va
cudaman1969 Online sleepy
cudaman1969  Online Sleepy
fredericksburg,va
Look like a 64-65 b-body frame
Re: What rear frame is this? [Re: cudaman1969] #2874055
01/13/21 11:39 PM
01/13/21 11:39 PM
Rhinotruck
Rhinotruck
Not possible, the guy I got it from never owned anything older than a 68 B-Body, and I know for sure he removed it from a parts car and was going to use it on one of the cars he was working on, which were 70-71 B and E body's that is why I theorized what this frame section is. Maybe they are the same from 66-72? I know for sure the last car he was working on was a 69 Charger 500 that was rustier than rust...shruggy
A-Body's RULE!
Re: What rear frame is this? [Re: Rhinodart] #2874083
01/14/21 12:27 AM
01/14/21 12:27 AM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Looks E body. Is the a hole at the end for the spring shackle? I don't see where a shackle box was welded to the side like for A and B body.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: What rear frame is this? [Re: moparmarks] #2874173
01/14/21 10:44 AM
01/14/21 10:44 AM
Rhinotruck
Rhinotruck
I have been called an a hole before, LOL! I think you meant is THERE a hole, I will check today, thanks!
A-Body's RULE!
Re: What rear frame is this? [Re: Rhinodart] #2874201
01/14/21 12:06 PM
01/14/21 12:06 PM
moparmarks Offline
moparmarks  Offline
Ya my typing sucks.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: What rear frame is this? [Re: moparmarks] #2874215
01/14/21 12:42 PM
01/14/21 12:42 PM
Apollo, PA.
B1MAXX Online content
B1MAXX  Online Content
Apollo, PA.
I can say with pretty good confidence that's not a 66-70 b-body.
Re: What rear frame is this? [Re: B1MAXX] #2874361
01/14/21 05:19 PM
01/14/21 05:19 PM
moparmarks Offline
moparmarks  Offline
Also kind of hard to see but looks like the spread between them gets wider towards the rear which is another E body thing.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: What rear frame is this? [Re: moparmarks] #2874408
01/14/21 06:25 PM
01/14/21 06:25 PM
massachusetts U.S.A.
1969ronnie Offline
1969ronnie  Offline
THIS ^ ^ ^ ^ drive ^ ^ ^
Re: What rear frame is this? [Re: 1969ronnie] #2874413
01/14/21 06:36 PM
01/14/21 06:36 PM
1969ronnie Offline
1969ronnie  Offline
Hi , the 1962 -1970 B-Body had it's leaf springs mounting parallel with the frame . the E-Body and F-Body have leaf springs mounted on the frame so they are Wider and Further apart at the rear . drive The 1971-1979 B-Body has them wider at the front frame .
Re: What rear frame is this? [Re: 1969ronnie] #2874527
01/14/21 10:45 PM
01/14/21 10:45 PM
Rhinotruck
Rhinotruck
I measrured 44" c/c of the front hangars and 47-1/2" at the rear c/c of the hole the rear hangars mount. Here are some pictures of the rear hanger eye and a part bolted on the frame.
A-Body's RULE!
Re: What rear frame is this? [Re: Rhinodart] #2874528
01/14/21 10:48 PM
01/14/21 10:48 PM
moparmarks Offline
moparmarks  Offline
Yep, E body.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: What rear frame is this? [Re: moparmarks] #2874723
01/15/21 01:40 PM
01/15/21 01:40 PM
1969ronnie Offline
1969ronnie  Offline
Hi Rhino , yes E-Body . scope Is that a 69 fastback or notch behind the frame ? wrench ronnie
Re: What rear frame is this? [Re: 1969ronnie] #2874960
01/16/21 01:00 AM
01/16/21 01:00 AM
Rhinotruck
Rhinotruck
Thanks guys! It is my third 67 383 fastback, but this one was rolled... frown
A-Body's RULE!
