Bottom end knocking after changing oil pan on 340 #2872348
01/11/21 12:15 AM
01/11/21 12:15 AM
Walnut Creek, CA
blown340 Offline OP
blown340  Offline OP
Walnut Creek, CA
Hi all, I recently change the oil pan on the 340 in my 70 challenger. The original had a stripped drain hole and had been overtightened enough it leaked from all the gaskets. I used a new replacement Milodon stock replacement pan.
When I first fired it back up today it dropped back into its usual idle like always but I heard a loud knocking from the motor. At first I was afraid I had blown it up and the rods were knocking, but that didn't make much sense while it idled perfectly, everything else was normal, and all I changed was the pan. Oil pressure was strong as well. I only ran it briefly, not even long enough to warm up.
At this point I'm planning to pull the pan back off and give it a once over. That's a fun job since I have to pull one of my headers to get to it!
Does anyone have any experience with similar issues? Any known issue with the Milodon stock pan on a 340? I'm assuming if something is hitting something its going to be obvious, but anything in particular I should be looking at?
Thanks for any and all input,
-Jon
70 challenger convertible. 340/5 speed. blown, intercooled, efi, blah blah blah 71 valiant scamp 318/A833OD/AC/PS 00 dakota RC 4.7L 5 spd autoX'r. SRT10/T56 swap in process 73 W200 Power wagon, PTO winch, 4 spd
Re: Bottom end knocking after changing oil pan on 340 [Re: blown340] #2872352
01/11/21 12:38 AM
01/11/21 12:38 AM
I think what your hearing is a rod hitting one of the baffles, the windage tray, the oil pickup tube or the edge of the new oil pan shock shruggy
What ever is causing the noise will leave witness marks wrench scope
Let us know what you find, maybe that will help someone else on here in the future luck
Re: Bottom end knocking after changing oil pan on 340 [Re: Cab_Burge] #2872596
01/11/21 03:04 PM
01/11/21 03:04 PM
moparx Offline
moparx  Offline
when you find the offending spot, please take a couple of pics if possible, and post them.
as cab said, this may help for future reference.
beer
Re: Bottom end knocking after changing oil pan on 340 [Re: moparx] #2873339
01/12/21 06:47 PM
01/12/21 06:47 PM
Walnut Creek, CA
blown340 Offline OP
blown340  Offline OP
Walnut Creek, CA
Will do, I hope to get to it next weekend.
Re: Bottom end knocking after changing oil pan on 340 [Re: blown340] #2873359
01/12/21 07:16 PM
01/12/21 07:16 PM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
you need to buy a mechanic stethoscope.
https://www.ebay.com/itm/Mechanics-Sonarscope-Stethoscope-Engine-Noise-Sound/401743522931?epid=3016199960&hash=item5d89c7ac73:g:7vcAAOSwoutcpn9o
will make finding engine noises a breeze, simply move the scope around until the noise is at its loudest and you have zeroed in on the problem. If it is a rod hitting the pan or windage tray, you should be able to feel that noise with your hand on the side of the pan as well as hearing it.
Re: Bottom end knocking after changing oil pan on 340 [Re: jwb123] #2873362
01/12/21 07:21 PM
01/12/21 07:21 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
I had a similar thing happen to me. I pulled the pan and inadvertently bent one of the front corners of the windage tray in the process. Started it up and had that tinny knocking sound. Pulled the pan again and the interference was not obvious. Had to turn the engine over by hand before I found the problem, front counterweight hitting the windage tray. Bent the corner back and problem solved
Re: Bottom end knocking after changing oil pan on 340 [Re: 6PakBee] #2873478
01/13/21 01:01 AM
01/13/21 01:01 AM
Walnut Creek, CA
blown340 Offline OP
blown340  Offline OP
Walnut Creek, CA
I hope mine will be that simple!
Re: Bottom end knocking after changing oil pan on 340 [Re: jwb123] #2873757
01/13/21 01:32 PM
01/13/21 01:32 PM
moparx Offline
moparx  Offline
Re: Bottom end knocking after changing oil pan on 340 [Re: blown340] #2877998
01/21/21 06:27 PM
01/21/21 06:27 PM
Slidell, La.
doctor_mopar Offline
Slidell, La.
I have seen the dust cover on the auto trans get twisted and hit on the torque converter bolts , make a knocking noise .
------------------------ It doesn't matter what you do.........As long as you look good doing it !
