Measurement Needed - Big block tensioner spacer #2872944
01/12/21 12:24 AM
01/12/21 12:24 AM
Tucson AZ,
MadMopars Offline OP
Tucson AZ,
Hey guys, I'm looking for a short side measurement on a big block tensioner spacer, as pictured. All the spacers I have are the straight ones like the second pic and I was just going to modify one of them so I can get things back together. If anyone could throw a tape measure or a set of dial calipers on one so I could match it up, that'd be awesome. Appreciate it!
[img]https://s9.postimg.cc/6fbjxzfvv/48-2016-_Drag-_Weekend-_Best-_Burnouts-lpr.jpg[/img]
73 GTX *440*727*8 3/4*
69 DART GT *440*4 SPEED*DANA*
73 ROAD RUNNER *451*4 SPEED*DANA*
64 F100 *383*4 SPEED*9"*
75 DODGE D300 *440*4 SPEED*DANA*
99 DODGE RAM 3500 4X4 DUALLY... ON 38"s
Re: Measurement Needed - Big block tensioner spacer [Re: MadMopars] #2873199
01/12/21 02:29 PM
01/12/21 02:29 PM
moparx Offline
moparx  Offline
i thought i might have a short one, but all of mine are long ones as well.
looking at the picture, it "appears" the short side "may" be close to the length of the front side to the edge of the tie bar.
if it were me, i would do a couple of small cuts and trial fit until the exact length is reached for your application.
i wished i could be of more help, but at least this will bump you back to the top.
hopefully, someone may be able to give the exact length.
beer
Re: Measurement Needed - Big block tensioner spacer [Re: moparx] #2873320
01/12/21 06:04 PM
01/12/21 06:04 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
Uhhh . . . think this is what you are looking for ??? There is a part number on the opposite side, but I can't make it out . . . hope this helps . . .
Re: Measurement Needed - Big block tensioner spacer [Re: a12rag] #2873441
01/12/21 09:52 PM
01/12/21 09:52 PM
Tucson AZ,
Tucson AZ,
Thanks for digging around. up
After mocking things up, I ended up taking off close to 3/4" on the one side to get things lined up. Although I wish I'd had the correct one to begin with, I think it'll get me going.
I appreciate the help though so thanks again!
Re: Measurement Needed - Big block tensioner spacer [Re: MadMopars] #2873467
01/12/21 11:42 PM
01/12/21 11:42 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
I've got one of the unequal spacers, but I'd have to look around to see where it is.
