4x4 440 motor mounts on a 1979 dodge w series #2872549
01/11/21 01:42 PM
01/11/21 01:42 PM
APACHE JUNCTION AZ
Joesixpack Offline OP
APACHE JUNCTION AZ
wondering if i can use the 74-77 4x4 440 motor mounts on a 79 w series truck? it says with a divorced transfer case, (74 to 77) why would the mounts be different because of the transfer case? have virtually no knowledge of 4x4 dodge trucks. thanks,pics are what mounts i have, can i use them in a later year?
Re: 4x4 440 motor mounts on a 1979 dodge w series [Re: Joesixpack] #2872551
01/11/21 01:45 PM
01/11/21 01:45 PM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
or are these the ones i need?
Re: 4x4 440 motor mounts on a 1979 dodge w series [Re: Joesixpack] #2872566
01/11/21 02:13 PM
01/11/21 02:13 PM
N
NITROUSN Offline
NITROUSN  Offline
N
74 was the last year for the divorced transfer case. I have used 77 BB mounts on a 84 with no problems. So 75 truck and 74 Ramcharger/Trailduster BB mounts will fit at least to 87 and possibly tp 93.
Re: 4x4 440 motor mounts on a 1979 dodge w series [Re: Joesixpack] #2872567
01/11/21 02:16 PM
01/11/21 02:16 PM
Sparks, Nevada
MoparMike23 Offline
MoparMike23  Offline
Sparks, Nevada
I'm not sure on if the T-case makes a difference, but I recall there being a change in the engine cross memebers at one point. It might be 78' and newer had a beefier cross member, which could effect the mounts. Another thing, there are different engine mount brackets between 4wd and 2wd but I'm not sure how to tell the difference. Might be worth your time to check out www.ramchargercentral.com. There's way more info there.
Mike
1969 Superbee 440-6
1977 D-150 Adventurer
2000 Jeep TJ
2018 Challenger Scat Pack Shaker
2019 Ram 2500 CTD
Re: 4x4 440 motor mounts on a 1979 dodge w series [Re: MoparMike23] #2872648
01/11/21 03:56 PM
01/11/21 03:56 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
From looking at your mounts it looks like the 4x4 mounts sets the engine forward more to accommodate the transfer case
Re: 4x4 440 motor mounts on a 1979 dodge w series [Re: cudaman1969] #2872663
01/11/21 04:02 PM
01/11/21 04:02 PM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
ok that makes sense. those powder coated ones were actually nos when i got them with these part numbers stamped on them
3823214 right side
3823215 left side
if anybody has a truck parts book maybe we can find them in it for correct application
Re: 4x4 440 motor mounts on a 1979 dodge w series [Re: Joesixpack] #2872792
01/11/21 06:56 PM
01/11/21 06:56 PM
541 slobovia
A990 Offline
A990  Offline
541 slobovia
The used mounts looks like they have a dual fit application. They can be flipped to work with a divorced or non-divorced t-case, or maybe a van/pickup interchange. Can you measure and compare the oval hole to bracket wall dimension of the two styles?
Re: 4x4 440 motor mounts on a 1979 dodge w series [Re: Joesixpack] #2872915
01/11/21 11:22 PM
01/11/21 11:22 PM
Alberta
440_Offroader Offline
Alberta
I've had a 76, 78, and 79 as a Ramcharger, W150, W200 respectively. The cross members were all the same. The 440 out of the 76 Ramcharger is in my 79 now with the same mounts. The mounts have offsets on the front engine ears, with the straight part of the mount on the rear engine ears. There is more offset on the LH mount. The mounts bolt to the rear holes in the crossmember. It doesn't matter if you have a divorced or married tranfer case, as your transmission mount is in the same spot, regardless. The new mounts you have look like they may work. The one looks like there's not enough offset in it, but might be just the picture. Perhaps they don't spec the mounts for 79 and newer trucks, as they didn't come with big blocks originally?
Re: 4x4 440 motor mounts on a 1979 dodge w series [Re: 440_Offroader] #2873028
01/12/21 09:15 AM
01/12/21 09:15 AM
RWG75
RWG75
What he said mostly.
2wd and 4wd tin grilles do have different front cross members for suspension but they use the same mounts. They all have 2 sets of mount holes - small block, big block. Shiney mounts in first pic are big block, the hole in one of them being for the oil pump. Used ones look like small block and IIRC 318/360 use the same on one side, different on the other. there is a pdf of the 78-81 truck parts book somewhere on the net.
Re: 4x4 440 motor mounts on a 1979 dodge w series [Re: Joesixpack] #2874418
01/14/21 06:43 PM
01/14/21 06:43 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Could you get me the measurement From the bolts holes to the mounting surface? So i can drill mine
The narrow ones
