Big Block Cam LSA Thread #2871230
01/08/21 05:17 PM
01/08/21 05:17 PM
USA
hudsonhornet7x Offline OP
USA
Several months ago on here there was a great discussion about narrow LSA cams in big blocks. I have searched a few times for it and can't find it. Does anyone remember it or have it bookmarked? Thanks!
Re: Big Block Cam LSA Thread [Re: hudsonhornet7x] #2871237
01/08/21 05:36 PM
01/08/21 05:36 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
If you know someone who responded to that thread, just search/view their posts.
Re: Big Block Cam LSA Thread [Re: fast68plymouth] #2871249
01/08/21 05:59 PM
01/08/21 05:59 PM
USA
USA
Good idea, thank you.
Re: Big Block Cam LSA Thread [Re: hudsonhornet7x] #2871270
01/08/21 06:29 PM
01/08/21 06:29 PM
Pattison Texas
CSK Online shake_head
CSK  Online Shake_Head
Pattison Texas
LSA is just a byproduct of having the correct opening & closing points that YOUR engine & combo runs the best . there is A LOT more to it than just looking at the LSA of a cam
Re: Big Block Cam LSA Thread [Re: hudsonhornet7x] #2871333
01/08/21 08:29 PM
01/08/21 08:29 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
What's "narrow" to you? work My Mini-Express is 107, in at 2 deg advanced.
Re: Big Block Cam LSA Thread [Re: DrCharles] #2871380
01/08/21 10:04 PM
01/08/21 10:04 PM
AndyF Offline
AndyF  Offline
That isn't narrow. I used to have an old super stock cam that was 102 and a buddy had a cam that was 99. They used to tighten up those lobes a bunch back in the day. Maybe someone still does.
Re: Big Block Cam LSA Thread [Re: AndyF] #2871421
01/08/21 11:50 PM
01/08/21 11:50 PM
I've ran and raced and dyno tune a bunch BB Mopar wedge motors with stock 440 size heads and narrow, tighter than 106 LSA, that all outran the other cars with similar parts with wider LSA and sometimes more lift and duration and than I had shruggy
I had one Reed Cam(solid flat tappet grind) that was suppose to been ground on a 104 LSA that was actually ground on a 101 LSA, I ended up installing it at 99 ATDC on the intake lobes and that rascal made the most HP and torque than many other cams with real similar lift and duration with wider LSA 108 ,110, 112 that I had used and tested shruggy The customer loved it saying it never quit pulling even above 7500 RPM shock Stock stroke 440 pump gas motor with a 850 CFM D.P. carb on a Eddy RPM intake and 906 heads shruggy
Re: Big Block Cam LSA Thread [Re: CSK] #2871475
01/09/21 08:09 AM
01/09/21 08:09 AM
PA
Harry's Taxi 2 Offline
PA
Wouldn't trying different LSA's be a way of determining what opening and closing points YOUR engine combo works best at.
'86 Maple Grove KOS Mopar low qualifier......true street legal with no power adders.
NOS-used when losing since 1940.
Re: Big Block Cam LSA Thread [Re: hudsonhornet7x] #2871503
01/09/21 10:01 AM
01/09/21 10:01 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
The guys over at Bullet Racing Cams state that heavy cars need narrow lobe seps. They spec'd a cam for my 511 in a 3400# car as needed a 108. I recently found a Lunati shelf cam 276/284-.690 on a 106* lobe sep. Thought this might be good for a future build.
Re: Big Block Cam LSA Thread [Re: mopar dave] #2871552
01/09/21 11:45 AM
01/09/21 11:45 AM
Southern Alberta
Uberpube Offline
Uberpube  Offline
Southern Alberta
Here's a custom spec for a really heavy car:
5300 lbs Ramcharger 4wd
505 rb
TF 270
Auto with OD
5.13 gears, 37" tires.
Indy dual plane intake
10.2 :1.
If I was going to run Efi, they wanted to push the LSA 2 deg bigger.
This was chosen as a close to a dual purpose cam as I could get.
I need bottom end to move the truck as a street driver,but I also need HP for the wheel speed in the mud.
Re: Big Block Cam LSA Thread [Re: Uberpube] #2871567
01/09/21 12:03 PM
01/09/21 12:03 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Who spec'd that for you? It doesn't have much duration thou, so should still make good torque i would think.
Re: Big Block Cam LSA Thread [Re: mopar dave] #2871571
01/09/21 12:11 PM
01/09/21 12:11 PM
Southern Alberta
Uberpube Offline
Uberpube  Offline
Southern Alberta
Bullet spec'd it from my info, most cams are ground for cars, or at the other end , towing with low compression ratio, so I though that was the safest way to go. I have lots of cylinder head so I can always go bigger if I need to.
They didn't think the valve train was going to be that successful over 5800 rpm so that's the ceiling for the motor.
Re: Big Block Cam LSA Thread [Re: Uberpube] #2871592
01/09/21 12:36 PM
01/09/21 12:36 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Yeah, i was just curious who at Bullet.
Re: Big Block Cam LSA Thread [Re: mopar dave] #2871604
01/09/21 01:22 PM
01/09/21 01:22 PM
gregsdart Offline
gregsdart  Offline
Probabley the narrowest LSA needed would have been my first stroker. 535 cubes, 906 heads, 2.14 intake valves, probably didn't flow more than 260 cfm. I bet it would have liked a 98 lsa.
IMHO since the overlap cycle is often seeing five times the vacuum draw of max intake valve lift, getting the overlap correct and sufficient for the head flow is the most important event.
On the other hand my new mustang 5.0 4v has up to 130 lsa. Those 4v heads flow like crazy at low lift/overlap.
Re: Big Block Cam LSA Thread [Re: gregsdart] #2871757
01/09/21 04:43 PM
01/09/21 04:43 PM
New York
polyspheric Offline
polyspheric  Offline
New York
This^^^
Boffin Emeritus
Re: Big Block Cam LSA Thread [Re: polyspheric] #2871862
01/09/21 09:14 PM
01/09/21 09:14 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
LCA is a function of duration and overlap. Increased duration with the same LCA increases overlap. So If a given combination needs more duration then LCA has to widen to maintain the same overlap. Look at the LCA of big duration cams. It will be wider for most applications.
Doug
Re: Big Block Cam LSA Thread [Re: mopar dave] #2871887
01/09/21 10:17 PM
01/09/21 10:17 PM
Southern Alberta
Uberpube Offline
Uberpube  Offline
Southern Alberta
I've talked to so many people about all the parts for this build, I can't recall the guys first name.
Re: Big Block Cam LSA Thread [Re: Uberpube] #2871902
01/09/21 10:48 PM
01/09/21 10:48 PM
I was taught early on many years ago that moving the LSA with no other changes would affect the power range of the motor just like advancing or retarding the cam. Wider LSA would loose bottom end with a higher HP peak RPM, moving them closer, tighter LSA, would make more power at the lower RPM range of that motor with no other changes shruggy
Re: Big Block Cam LSA Thread [Re: dvw] #2872014
01/10/21 11:14 AM
01/10/21 11:14 AM
gregsdart Offline
gregsdart  Offline
Doug
Two things that affect the amount of overlap versus duration are head efficiency and compression ratio. An 8/1 compression motor has to clear a lot more dead volume at overlap than a 16/1 motor. Also, as cam duration goes up beyond a certain point, on average the heads will be better and compression higher. I would bet that could be demostrated by looking at some stock class cams. If i am right, they should have a longer overlap period compared to total duration.
Re: Big Block Cam LSA Thread [Re: gregsdart] #2872234
01/10/21 07:49 PM
01/10/21 07:49 PM
Most of the SB Mopar running well in NHRA stock use from 102 to 106 LSA installed from 2 to 6 degrees advanced on the ILC back many years ago when I was still talking to and helping some of those NHRA class racers shruggy
