Re: Any Idaho mopar clubs or guys?
[Re: 67R/T4speeder]
#2873408
01/12/21 09:11 PM
01/12/21 09:11 PM
Posts: 20,543 Eagle, Idaho
Neil
The Doctor is in.
The Doctor is in.
Eagle, Idaho
Talking to people who know people I'm lead to believe this is the club that absorbed what was left of the Mopars Unlimited Club after it fell apart. https://www.facebook.com/IdahoChariotsIt was weird and sad to watch the Mopars in the Park car show count decline each year until it was hardly worth going to and then poof - no more.
[Re: Neil]
#2873716
01/13/21 12:54 PM
01/13/21 12:54 PM
Posts: 667 Los Osos, Ca
CKessel
Los Osos, Ca
I have a question for the Idaho people. Is there an area of the state that does not get plastered with snow or has minimal amounts? Just in the back of my mind if we end up leaving the PRC due to taxes, costs etc. As a So Cal natives we are fine with rain but snow is something we never dealt with unless we went to play in it. Don't want to deal with salt on the roads, having to get a 4x or chain up. This may be wishful thinking but figured I'd ask those who live there.
Carl Kessel
[Re: Neil]
#2873776
01/13/21 01:54 PM
01/13/21 01:54 PM
Posts: 20,763 A collage of whims
topside
A collage of whims
I'm up at the north end ("panhandle"), Sandpoint. Winters here vary, like 2-3 years of mild (little snow), then a couple years of heavy snow, back & forth. About 3 cycles in the last 16 years. Really just depends on El Nino pattern and of course temps. Best to do some Wiki research of the different towns' altitude & weather. Snow level seems to be about 2500-3000 feet, but we also have micro-climates where it varies a lot. The further away from a city you are, the more self-sufficient you need to be, of course. With a plow truck, winter tires for the Breeze, and a stand-by generator, I'm covered.
[Re: topside]
#2874257
01/14/21 01:32 PM
01/14/21 01:32 PM
CKessel
Los Osos, Ca
I've found that some of the wiki or town website info can be vague or generous on the wrong end. Years ago we were thinking about the eastern side of Oregon just west of Boise. My wife had checked the county website and it looked good. Later on she just spot checked on a weather channel site and got the true info. Cold and snow. I said remember you are higher up latitude wise and you are bound to have it colder than here. She can't deal with extreme heat or cold. Maybe too many years of working in a climate controlled work place. From what I've seen so far the southern areas of Id. look promising but its always better to find out from those who live there.
Carl Kessel
[Re: CKessel]
#2874307
01/14/21 03:01 PM
01/14/21 03:01 PM
Neil
The Doctor is in.
The Doctor is in.
Eagle, Idaho
Southern Idaho is high desert so we can get past 100 in the summer and well below 0 in the winter. It's also flat so wind from coming up from Nevada and across from Oregon is common. We got 39 inches of snow in 2017. Numerous buildings with flat or low sloped roofs failed. You can tell a lot about the winter weather in areas just by looking at the roof slopes of buildings. Steep sloped roofs cost money, but they are there for a reason. https://youtu.be/U_N58QtROQ4
[Re: Neil]
#2876931
01/19/21 11:11 PM
01/19/21 11:11 PM
Posts: 1,668 Caldwell, Idaho
67R/T4speeder
Caldwell, Idaho
Southern Idaho is high desert so we can get past 100 in the summer and well below 0 in the winter. It's also flat so wind from coming up from Nevada and across from Oregon is common. We got 39 inches of snow in 2017. Numerous buildings with flat or low sloped roofs failed. You can tell a lot about the winter weather in areas just by looking at the roof slopes of buildings. Steep sloped roofs cost money, but they are there for a reason. https://youtu.be/U_N58QtROQ4 I would like to meet you also Neil someday?
[Re: bigblk66_coronet]
#2878057
01/21/21 08:29 PM
01/21/21 08:29 PM
Posts: 1,650 Harm City Md.
Dan Halen
Harm City Md.
Not directly answering your question but couldn't resist because I used to live in MH. Anyhow, as improbable as it seems now, Mountain Home had quite a collection of rare muscle cars when I was stationed @ MHAFB in 1981.
In town, there was a guy that had a '69 T/A and a 70 RAIV T/A that he used as daily drivers. There was Cedar Autobody that had a 6bbl Superbird, a cop that had a 70 Charger R/T, Elms Speed Shop had a 69 Charger R/T for sale and there was a guy selling a 67 R/T roller (mint) for $100.
On base there was my 71 Charger R/T, a 72 Roadrunner/GTX Air Grabber 4sp. Dana in Petty Blue, a 4sp AAR in primer, a 69 Mach-1 428 4sp and a Hang 10 Dart. There also was a dragstrip on base where they raced weekends, weather permitting.
On the other hand, finding a 340 involved searching the JY system in 3 states.
Boise had maybe 4-5 Mopars running around, not including a custom 69 500 Charger that would intermittently show up @ Ann Morrison Park. Fords were everywhere though.
