Re: Big Block Cam LSA Thread
[Re: hudsonhornet7x]
#2871237
01/08/21 05:36 PM
01/08/21 05:36 PM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
If you know someone who responded to that thread, just search/view their posts.
#2871270
01/08/21 06:29 PM
01/08/21 06:29 PM
Posts: 2,867 Pattison Texas
CSK
Pattison Texas
LSA is just a byproduct of having the correct opening & closing points that YOUR engine & combo runs the best . there is A LOT more to it than just looking at the LSA of a cam
[Re: DrCharles]
#2871380
01/08/21 10:04 PM
01/08/21 10:04 PM
Posts: 31,051 Oregon
AndyF
What's "narrow" to you? My Mini-Express is 107, in at 2 deg advanced. That isn't narrow. I used to have an old super stock cam that was 102 and a buddy had a cam that was 99. They used to tighten up those lobes a bunch back in the day. Maybe someone still does.
[Re: AndyF]
#2871421
01/08/21 11:50 PM
01/08/21 11:50 PM
Posts: 43,244 Bend,OR USA
Cab_Burge
I've ran and raced and dyno tune a bunch BB Mopar wedge motors with stock 440 size heads and narrow, tighter than 106 LSA, that all outran the other cars with similar parts with wider LSA and sometimes more lift and duration and than I had I had one Reed Cam(solid flat tappet grind) that was suppose to been ground on a 104 LSA that was actually ground on a 101 LSA, I ended up installing it at 99 ATDC on the intake lobes and that rascal made the most HP and torque than many other cams with real similar lift and duration with wider LSA 108 ,110, 112 that I had used and tested The customer loved it saying it never quit pulling even above 7500 RPM Stock stroke 440 pump gas motor with a 850 CFM D.P. carb on a Eddy RPM intake and 906 heads
[Re: CSK]
#2871475
01/09/21 08:09 AM
01/09/21 08:09 AM
Posts: 288 PA
Harry's Taxi 2
PA
LSA is just a byproduct of having the correct opening & closing points that YOUR engine & combo runs the best . there is A LOT more to it than just looking at the LSA of a cam Wouldn't trying different LSA's be a way of determining what opening and closing points YOUR engine combo works best at.
'86 Maple Grove KOS Mopar low qualifier......true street legal with no power adders.
NOS-used when losing since 1940.
[Re: mopar dave]
#2871571
01/09/21 12:11 PM
01/09/21 12:11 PM
Posts: 712 Southern Alberta
Uberpube
Southern Alberta
Bullet spec'd it from my info, most cams are ground for cars, or at the other end , towing with low compression ratio, so I though that was the safest way to go. I have lots of cylinder head so I can always go bigger if I need to. They didn't think the valve train was going to be that successful over 5800 rpm so that's the ceiling for the motor.
[Re: mopar dave]
#2871604
01/09/21 01:22 PM
01/09/21 01:22 PM
Posts: 10,011 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Probabley the narrowest LSA needed would have been my first stroker. 535 cubes, 906 heads, 2.14 intake valves, probably didn't flow more than 260 cfm. I bet it would have liked a 98 lsa. IMHO since the overlap cycle is often seeing five times the vacuum draw of max intake valve lift, getting the overlap correct and sufficient for the head flow is the most important event. On the other hand my new mustang 5.0 4v has up to 130 lsa. Those 4v heads flow like crazy at low lift/overlap.
[Re: gregsdart]
#2871757
01/09/21 04:43 PM
01/09/21 04:43 PM
Posts: 4,209 New York
polyspheric
New York
the overlap cycle is often seeing five times the vacuum draw of max intake valve lift This^^^
Boffin Emeritus
[Re: mopar dave]
#2871887
01/09/21 10:17 PM
01/09/21 10:17 PM
Uberpube
Southern Alberta
Yeah, i was just curious who at Bullet. I've talked to so many people about all the parts for this build, I can't recall the guys first name.
[Re: dvw]
#2872014
01/10/21 11:14 AM
01/10/21 11:14 AM
gregsdart
LCA is a function of duration and overlap. Increased duration with the same LCA increases overlap. So If a given combination needs more duration then LCA has to widen to maintain the same overlap. Look at the LCA of big duration cams. It will be wider for most applications. Doug Two things that affect the amount of overlap versus duration are head efficiency and compression ratio. An 8/1 compression motor has to clear a lot more dead volume at overlap than a 16/1 motor. Also, as cam duration goes up beyond a certain point, on average the heads will be better and compression higher. I would bet that could be demostrated by looking at some stock class cams. If i am right, they should have a longer overlap period compared to total duration.
