Re: header
[Re: jwb123]
#2870364
01/07/21 11:44 AM
01/07/21 11:44 AM
Posts: 1,534 bronx n.y
one bad fish
bronx n.y
pipemax is your friend. http://www.maxracesoftware.com/I have been building and racing mopars since 1974, I would never buy or build a set of headers without running it through this program first. Just me. ok thank u
Re: header
[Re: one bad fish]
#2870461
01/07/21 02:10 PM
01/07/21 02:10 PM
Posts: 43,126 Bend,OR USA
Cab_Burge
Re: header
[Re: one bad fish]
#2870615
01/07/21 07:31 PM
01/07/21 07:31 PM
Posts: 30,995 Oregon
AndyF
my 1965 coronet they only make two header tube sizes 1 3/4 or 2inch its 440 with 240 trick flow heads it has 1 3/4 now would u switch to two inch Why do you want to change? I'd run the 1 3/4 on a 440 with TF 240 heads. I'm assuming it is a street car or perhaps a street/strip car? If you are less than 600 hp then no reason to put 2 inch headers on it.
Re: header
[Re: lewtot184]
#2870912
01/08/21 09:58 AM
01/08/21 09:58 AM
one bad fish
bronx n.y
i use the big headers and pipes by "default", not choice. i use the tti recommended 3" dyno max turbo reverse flow mufflers. after getting parts together i had a conversation with a dyno max engineer, and at that time dyno max gave flow numbers on their mufflers, the engineer told me a 2.5" ultra flow would flow more air than the 3" reverse flow. my car is strictly a street car with a modified 440, sometimes no more than 20 miles a trip. the exhaust system is always wet internally from condensation which rots the mufflers sooner than i like. acidic water is a by product of combustion and can't be helped. now if i only did longer trips at higher speeds i could probably burn the water out of the system and everything would last longer. i do some road trips but not enough to keep the system dry. i seriously doubt that a smaller system with freer flowing mufflers would hurt performance much if any on what i have. plug changes would be a little easier with 1 3/4 headers, but with the angle plug heads i have the 2"'ers aren't bad. either way you go you'll like the tti stuff. you'll just have to decide what's overall best for what your doing, and don't fall into the trap of bigger is always better. true thank u
Re: header
[Re: one bad fish]
#2871172
01/08/21 03:50 PM
01/08/21 03:50 PM
Posts: 3,916 usa
lewtot184
usa
well just getting some advice car runs well 11.55 @ 116 my car with the big exhaust and other junk added to it wouldn't run 11.50's if the pope threw a gallon of holy water on it. maybe look at other things for horsepower.
Re: header
[Re: lewtot184]
#2871182
01/08/21 03:58 PM
01/08/21 03:58 PM
one bad fish
bronx n.y
well just getting some advice car runs well 11.55 @ 116 my car with the big exhaust and other junk added to it wouldn't run 11.50's if the pope threw a gallon of holy water on it. maybe look at other things for horsepower. lol ok
Re: header
[Re: lewtot184]
#2871256
01/08/21 06:16 PM
01/08/21 06:16 PM
Posts: 4,311 Prospect, PA
BSB67
Prospect, PA
well just getting some advice car runs well 11.55 @ 116 my car with the big exhaust and other junk added to it wouldn't run 11.50's if the pope threw a gallon of holy water on it. maybe look at other things for horsepower. That made me laugh out loud.
Re: header
[Re: one bad fish]
#2871258
01/08/21 06:22 PM
01/08/21 06:22 PM
BSB67
Prospect, PA
well just getting some advice car runs well 11.55 @ 116 Is that with open headers? If not, what is the rest of the exhaust system? And What does the car weigh?
Re: header
[Re: one bad fish]
#2871294
01/08/21 07:19 PM
01/08/21 07:19 PM
AndyF
well just getting some advice car runs well 11.55 @ 116 I really doubt that the 1 3/4 inch headers are holding you back.
Re: header
[Re: DusterKid]
#2872039
01/10/21 12:49 PM
01/10/21 12:49 PM
one bad fish
bronx n.y
If it's a street/strip car I would be fine with the 1 3/4". If it's an all out race car than 2" MAY help. Another thing to consider is, you said you went 11.55. Does the car currently have a roll bar? If it doesn't, your only allowed to go 11.50 without one. So if you change to 2" headers and pickup, now to be legal you'd have to install a roll bar which more than likely will slow you down what little you might of gained. yeah I know I don’t want to put a bar I already got a car with a cage
Re: header
[Re: BSB67]
#2872041
01/10/21 12:50 PM
01/10/21 12:50 PM
one bad fish
bronx n.y
well just getting some advice car runs well 11.55 @ 116 Is that with open headers? If not, what is the rest of the exhaust system? And What does the car weigh? that’s with 2 1/2 inch exhaust and cheap as flow masters
