BATTERY DRAIN 2013 G. CARAVAN #2869988
01/06/21 06:29 PM
01/06/21 06:29 PM
S.E.Ohio
Magnumguy Offline OP
S.E.Ohio
My son's minivan (work) has had a recent issue of battery drain. Figured the battery was bad so it's owner replaced the aging battery.
Fast forward to the next weekend and it's dead. Jumped it and OK, I disconnected the battery, but when I did, it sparked quite heavily, It is a service van, with equipment. Everyone was turned off but yet a healthy spark. Could the alternator cause a parasitic draw? I know they have an internal regulator.
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
Re: BATTERY DRAIN 2013 G. CARAVAN [Re: Magnumguy] #2870004
01/06/21 06:53 PM
01/06/21 06:53 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
I'm attempting to locate one on my '89 Diplomat Police car. I pulled every fuse and still had a 60 Milliamp draw which is high for an older car. I was about to test with alternator disconnected, but needed to change batteries in my voltmeter, and when I opened battery compartment they had leaked out and destroyed it. So that's my next thing. Another voltmeter should arrive any day now. Lots of suggestions here;
https://board.moparts.org/ubbthread...tic-draw-or-bad-battery.html#Post2864873
Facts are stubborn things.
Re: BATTERY DRAIN 2013 G. CARAVAN [Re: larrymopar360] #2870011
01/06/21 07:05 PM
01/06/21 07:05 PM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
Be sure to ck glove box and console light if equipped .
Re: BATTERY DRAIN 2013 G. CARAVAN [Re: gtx6970] #2870036
01/06/21 08:07 PM
01/06/21 08:07 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Every time I’ve found an alternator causing a draw it’ll be very warm while setting.
Doug.
Re: BATTERY DRAIN 2013 G. CARAVAN [Re: gtx6970] #2870037
01/06/21 08:10 PM
01/06/21 08:10 PM
S.E.Ohio
S.E.Ohio
Will do although I think that was covered.
How might I check this with a meter. I'm totally ignorant of electrical testing. I do know it makes quite a spark when it disconnects
Re: BATTERY DRAIN 2013 G. CARAVAN [Re: Magnumguy] #2870064
01/06/21 08:56 PM
01/06/21 08:56 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
Disconnect negative battery cable, and you want the meter to have one contact on the negative cable and one on the negative post. Doesn't matter which you use from the voltmeter on which because you are just looking for an absolute value so ignore the negative or positive reading on meter. On older vehicle without a bunch of electronics, should be a reading of less than 50 milliamps. Mine is reading 60Ma and killing my battery in just about ten days of sitting. The van being a '13 may read more in the range of 60-80 milliamps, and be considered normal draw.
Basically, the meter is going to be a link from negative cable to negative post, using meter contacts. I believe the knob setting on your meter should be mA, or at least on most meters.
Re: BATTERY DRAIN 2013 G. CARAVAN [Re: Magnumguy] #2870137
01/06/21 10:13 PM
01/06/21 10:13 PM
It's a dry heat
It's a dry heat
Easy way.
Pull the van someplace dark. get inside , make sure key is off and all doors are shut and wait till time delay times out ( about 30 seconds ) The key in ignition cylinder light will go dark when it does
Once happens open the console lid ever so slightly and look for lighting inside, OK?
Look for light illuminating from under the dash near the glove box ,,,this might require getting your head under the dash. ( hopefully you're young enough to get back out of said position )
PS, if it has an underhood light . They are notorious to fail causing the light to stay on , trust me
Re: BATTERY DRAIN 2013 G. CARAVAN [Re: gtx6970] #2870156
01/06/21 10:47 PM
01/06/21 10:47 PM
garnett kansas
rhad Offline
rhad  Offline
garnett kansas
it should have a IOD rely/fuse,(ignition off draw),pull that and see if it goes away
my ladder of success is missing some rungs
Re: BATTERY DRAIN 2013 G. CARAVAN [Re: larrymopar360] #2870218
01/07/21 01:54 AM
01/07/21 01:54 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Thats right as I found most newer Mopars read from 10 to about 30 mili-amps. I was told 50 mil-amps even for the new cars is limit and I only found some conversion vans reading about 40 to 50 mili-amps. I always like to use my fluke meter as its digital readout is very accurate. Ron
Re: BATTERY DRAIN 2013 G. CARAVAN [Re: 383man] #2870458
01/07/21 02:06 PM
01/07/21 02:06 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
I am waiting on my new voltmeter to arrive. As I mention the old one was ruined by batteries leaking out. But I’ve had the alternator disconnected for three days and I connected the battery charger this morning and the battery was still at 100%. This makes me almost 100% certain it was my alternator. Every time before that I’ve let it sit for three days it would charge at 2amps for at least 90 minutes. This is best case scenario for me too because I have an extra alternator pulled from another police car i used to have. And having already pulled every single fuse with no change in the draw I was getting frustrated. Oddly enough my alternator was never warm though when the car was sitting.
Magnumguy here’s what my voltmeter look like with the dial set and proper ports for the leads when testing in Milliamps.
Re: BATTERY DRAIN 2013 G. CARAVAN [Re: larrymopar360] #2870470
01/07/21 02:23 PM
01/07/21 02:23 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
To verify your thoughts you could disconnect the wires atteh alternator (tape off the fat one) and reconnect he battery and let it sit. then see if it drains.
Re: BATTERY DRAIN 2013 G. CARAVAN [Re: Sniper] #2870473
01/07/21 02:25 PM
01/07/21 02:25 PM
Kirkland, Washington
Pacnorthcuda Offline
Why let it sit? Just put the ammeter in the circuit and check for a draw...
Re: BATTERY DRAIN 2013 G. CARAVAN [Re: Pacnorthcuda] #2870545
01/07/21 04:58 PM
01/07/21 04:58 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Because he's waiting on his meter to arrive, so he can't use that.
Re: BATTERY DRAIN 2013 G. CARAVAN [Re: Magnumguy] #2872010
01/10/21 11:00 AM
01/10/21 11:00 AM
Cleveland Ohio
sportfury70 Offline
sportfury70  Offline
Cleveland Ohio
I just had this same issue with my 2011 Ram 1500. When you park it listen by the fuel tank. Fuel pump may be running. There is no relay in the system. They expect you to replace the entire TIPM. (Fuse box)
I found a company called vertical visions that makes a solution. Cost me about 100 maybe 150 and took 20 minutes to install.
https://www.verticalvisions.com/
Re: BATTERY DRAIN 2013 G. CARAVAN [Re: Sniper] #2872022
01/10/21 11:56 AM
01/10/21 11:56 AM
RWG75
RWG75
When it shows up, strip the alternator down and see what's up. Not that hard to rebuild.
