Re: crankshaft key way question
[Re: BigFish69]
#2869686
01/06/21 01:18 PM
01/06/21 01:18 PM
Posts: 43,181 Bend,OR USA
Cab_Burge
Stock on every BB motor I've built since 1971 Mr. Gasket sells the stock replacement and offset ones also, I've use to use the offset ones before the three slotted crankshaft timing gear sets came out to advance or retard the cams Make sure and get them aligned and square on the height and seated all the way, no taper either way when done
[Re: jwb123]
#2871903
01/09/21 10:50 PM
01/09/21 10:50 PM
Cab_Burge
The big block mopar is not a standard WOODRUFF key like you buy at the hardware store, it has extensions on it, like this one from summit.
https://www.summitracing.com/parts/mop-06509258aa?seid=srese2&utm_source=bing&utm_medium=cpc&utm_campaign=Brands+|+M&utm_term=4581802393709008&utm_content=GSAPI+5ba28999bb37f Some, most before 1975 or so, RB and B Mopar V8 motors came with a standard key and some of the later ones had tips on them, not all of them came that way Both work fine as long as they are installed correctly
