Re: Alternator Bolt
[Re: ct440rod]
#2868530
01/03/21 04:10 PM
01/03/21 04:10 PM
Posts: 315 Ontario, Canada
RealWing
Ontario, Canada
Not sure about '70 E body 440's, but the ICCA 68-70 B Body Fastener Reference Manual shows a 5/16-18x0.88 SEMS Hex head bolt with a 0.75" non serrated loose washer. A flat washer under a lockwasher defeats the whole purpose of a lock washer!! Jim
1970 Superbird 440-6bbl, auto 1969 Barracuda 340-4bbl, FB Formula S auto 1969 Barracuda 6.1 L Hemi, 5 speed, Convertible 2022 Can Am Spyder RTL
Re: Alternator Bolt
[Re: dragon slayer]
#2869466
01/05/21 06:55 PM
01/05/21 06:55 PM
Posts: 8,273 fredericksburg,va
cudaman1969
fredericksburg,va
That alternator bolt is correct. 7/8" long with 3/4" cap washer. LG head is another common example. If you look at the alternator there is only so much thread in the front cover. So 7/8" plenty long. If you stripped your cover you need to fix that. Cover is only thick as nut so a longer bolt does no good plus gets bolt closer to rotor.
If it is not the belt, what about the top bolt going into the head. Many time they maybe too short with only a few threads engaged. That play an important part in locking up the alternator via the sleeves. Loosening the alternator bolt without loosening that bolt and my alternator doesn't pivot. ^^^^^^^ agree removed many many of them thru 55 years.
Re: Alternator Bolt
[Re: RealWing]
#2869612
01/06/21 10:15 AM
01/06/21 10:15 AM
Posts: 395 Milan Ohio
ct440rod
Milan Ohio
Been in machine repair for 45 years and have always used flat washers with lock washers. The flat washer gives something for the lock washer to bite into. Just my 2 cents.
