Re: Rear end length.. Is there a science to it? [Re: AndyF] #2867639
01/01/21 03:55 PM
01/01/21 03:55 PM
Cleveland Ohio
10secGTX Offline
10secGTX  Offline
Cleveland Ohio
Originally Posted by AndyF
I recently had to buy a new rear end housing to fit the new wheels that I bought for my Duster. My new wheels had 3 inches more backspacing than the old wheels so the new housing had to be 6 inches wider. I'll end up selling my old rear end along with the matching wheels and tires to someone with a Duster that wants the whole setup.
What did you go with for rear and gear choice ?
Re: Rear end length.. Is there a science to it? [Re: topside] #2867723
01/01/21 07:32 PM
01/01/21 07:32 PM
Charlotte, NC
LSP Offline
LSP  Offline
Charlotte, NC
On the rear wheels, I want the center/hub of the wheel centered up in the wheel regardless of total width needed.
Re: Rear end length.. Is there a science to it? [Re: LSP] #2867784
01/01/21 08:48 PM
01/01/21 08:48 PM
Why?
Do you want the wheel back spacing to be in the center of the wheel width exactly, IE 10 inch wide wheel with 5.0 back spacing?
Centered or negative offset makes them harder to put on and take off usually, the wider the wheels and tires the worst the problems shruggy
Been down that road more than once due to NHRA rules in NHRA stock classes years ago down whiney
Re: Rear end length.. Is there a science to it? [Re: LSP] #2867837
01/01/21 10:31 PM
01/01/21 10:31 PM
mississippi
lostdog Offline OP
lostdog  Offline OP
mississippi
That’s what I think too bc I believe it would be more stable but I do see these super narrow rear ends with super deep outside spacing but to me that doesn’t make sense.
Re: Rear end length.. Is there a science to it? [Re: lostdog] #2867871
01/01/21 11:19 PM
01/01/21 11:19 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
High offset wheels benefit you by lightening the total weight of the rear end as an assembly in the car. If you have partial skirted wheel openings like a Dart, you really do not want long axles. Trying to get a big tire out with a high offset wheel is bad enough without adding to the drama. Wheel offset is of no concern with strength. All the fastest cars have the wheels offset. Heck, look at any vehicle with dual wheels. They are made for heavy loading.
Re: Rear end length.. Is there a science to it? [Re: lostdog] #2867875
01/01/21 11:29 PM
01/01/21 11:29 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
I will always make the rear as narrow as I can, i.e.use the deepest offset wheel for the width I am using or may end up using. 1) Axles are shorter, less likely to twist or flex, likewise for the housing 2) Easier to get the wheels and tires on and off 3) The entire rear assembly is lighter. If I can save weight for the same money, I'm doing it.
If I'm fabricating spring mounts or suspension mounts using big tires, I will cheat the housing forward a bit 1) Weight distribution 2) If I need to trim the wheel opening, I only need to fool with the front of it.
Re: Rear end length.. Is there a science to it? [Re: CMcAllister] #2867915
01/02/21 01:46 AM
01/02/21 01:46 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I agree.
My rear end is moved back 1", it would be interesting to see how much the weight changes by moving the rear 1" either side of the factory location.
Re: Rear end length.. Is there a science to it? [Re: justinp61] #2867928
01/02/21 03:47 AM
01/02/21 03:47 AM
CA
crackedback Offline
crackedback  Offline
CA
A factory A body 8.75 is 52 5/8"
The shorter number is from that garbage chart that is wrong. They are not 51.40"
AS mentioned measure to get it right with the wheel/tire package you want to run. You must have enough stick out beyond the leaf springs for a U bolt to grab before the housing end is in the way
Re: Rear end length.. Is there a science to it? [Re: Cab_Burge] #2867943
01/02/21 07:40 AM
01/02/21 07:40 AM
Charlotte, NC
LSP Offline
LSP  Offline
Charlotte, NC
Why?
That's why I said "I", it's just my preference. Assuming a 10" wide wheel with a 1" wide wheel center/hub, it would be 4.5" per side or wheel half. I don't size the rear end width or wheel stud length so I can't get the tires off in the first place, and don't mind if I need to let the rear end hang by using jack stands on the frame.
The roughly 1 lb. per axle saved making the rear end width 4" shorter isn't going show you much at all, because it's so close to center, there's more to be gained from the wheel itself and even better yet the tire. Some Pro Stock guys have a tire burn in car that's used to shave the tire OD's down, losing 4 lbs. at a 16"+ radius from center, now we're talking.
Fully aware of what's involved regarding NHRA Stock and Super Stock stuff, been there, done that, and doing that.
