GEARVENDORS OR 518 #2867368
01/01/21 11:10 AM
01/01/21 11:10 AM
East Coast
A/MP Offline OP
A/MP  Offline OP
East Coast
Street SB w/2.74 and 430 rear about 450HP. Bigger trans tunnel for the 518 plus reliability? Never knew anybody that used a gearvendor. Any thoughts?
Re: GEARVENDORS OR 518 [Re: A/MP] #2867418
01/01/21 11:42 AM
01/01/21 11:42 AM
Tulsa OK
Bad340fish Online content
Bad340fish  Online Content
Tulsa OK
The gear venders seem really reliable and they have excellent customer service from what I have seen with Drag Week people. The 518 has a better overdrive ratio but I imagine that it costs more HP to run over a 727 and GV combo but I don't know for certain.
I keep kicking around overdrive with an A500 behind my small block but have never pulled the trigger. My motor loves causing at 3500 its super smooth and quiet, but when I do drag week I wouldn't mine being able to run 10mph faster lol. 65mph on some of the major interstates can be sketchy sometimes.
68 Barracuda Formula S 340
Re: GEARVENDORS OR 518 [Re: A/MP] #2867420
01/01/21 11:44 AM
01/01/21 11:44 AM
Boise
Moparteacher Offline
Boise
Will the GV fit in the tunnel without modification?
Re: GEARVENDORS OR 518 [Re: Moparteacher] #2867425
01/01/21 11:53 AM
01/01/21 11:53 AM
Tulsa OK
Tulsa OK
My dad talked to a Gear Vendor rep at their booth on drag week. He said it only required a small dent in the trans tunnel to clear. We were asking about a 904 in an A body though, a 727 might be different.
Re: GEARVENDORS OR 518 [Re: A/MP] #2867435
01/01/21 12:12 PM
01/01/21 12:12 PM
New York
polyspheric Offline
polyspheric  Offline
New York
The actual GV ratio is rounded off to .78:1 but is actually =1/(1+(22/77)) or .77778:1.
GV also allows creating 2 intermediate gears by engaging it in 1st or 2nd.
For a 727 this makes:
1st 2.45:1
1st + GV 1.91:1
2nd 1.45:1
2nd + GV 1.13:1
3rd 1.00:1
OD .778:1
Boffin Emeritus
Re: GEARVENDORS OR 518 [Re: A/MP] #2867457
01/01/21 12:46 PM
01/01/21 12:46 PM
Taxes & Virus's R-US, NY
Dragula Online content
Dragula  Online Content
GV when not in use is like a clean neutral and robs no HP, only weight. On the other hand, if the 518 is like an A500, you are spinning the entire OD section even when its not in use....I was told I was losing as much as .5 in ET from this on my old pro street truck.
Re: GEARVENDORS OR 518 [Re: polyspheric] #2867465
01/01/21 12:53 PM
01/01/21 12:53 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I have a GV in my GMC Dually with 4.10s; installed 1996 and it's been bulletproof.
Probably the best upgrade I've done to it in terms of highway RPM & MPG.
At the same time, its T400 got a rebuild.
Looking at the cost of an OD trans, and the cost of any rebuilds, it was the less-expensive long-term plan.
It's arguably a wash at this point, though, because the trans has been fine.
But it was also a less complicated way to get OD in the truck.
Not sure how that compares to the OP's needs & goals, but my experience has been very good.
Re: GEARVENDORS OR 518 [Re: A/MP] #2867598
01/01/21 02:55 PM
01/01/21 02:55 PM
Benton, IL.
DaveRS23 Online rolleyes
Special needs idiot
DaveRS23  Online Rolleyes
Special needs idiot
Benton, IL.
The 500/518 has a noticeably better OD than the Gearvenders. That was the deciding factor for me. As to the power loss, that is an interesting question. Does anyone know for sure the difference?
What body is it going in? Only a little massaging was required to put the 518 in my Cuda. As to reliability, a properly built 518 can handle what you throw at it. It handles my 540 Hemi as easily as it handles the diesels.
In fact, how about a well built 500? It takes less power to drive. Would require even less ,if any, tunnel mods. And is lighter than even the Gearvenders.
When going behind a big block, the bell housing situation makes the conversion more complicated/expensive. But for small blocks, the 500/518 seems a shoe-in.
https://smrtrans.tripod.com/smrtransmissionsintro/id6.html
Master, again and still
Re: GEARVENDORS OR 518 [Re: Bad340fish] #2867611
01/01/21 03:21 PM
01/01/21 03:21 PM
JCFcuda Offline
JCFcuda  Offline
It’s the same with the 727 also ,have one in a 73 Cuda
Jim F
Re: GEARVENDORS OR 518 [Re: A/MP] #2867644
01/01/21 04:04 PM
01/01/21 04:04 PM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
the gearvendors maintenance schedule is a little steep
"Recommended service interval – change fluid every 5,000 miles depending on severity of duty."
https://www.gearvendors.com/install.html
Joe
Without Data, you’re just another guy with an opinion.
Re: GEARVENDORS OR 518 [Re: A/MP] #2867668
01/01/21 04:50 PM
01/01/21 04:50 PM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
Had a GV in my 69 Super Bee. All I had to do was dimple the tunnel for clearance for the two studs on the top rear of the housing. Had it behind a 512 stroker and never had any issues. I liked the GV because you can select overdrive in any gear. Use to wind it out in second then select overdrive, wind it out again then shift to third. drive I had a reverse manual valve body in it.
Re: GEARVENDORS OR 518 [Re: A/MP] #2867763
01/01/21 08:22 PM
01/01/21 08:22 PM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
IMO, you can build a sweet A500 or A518 for the steep price of a gearvendors. I think the splitting gears is a neat idea but not practical given feedback from people that have them. I'd be curious if the previously stated 1/2 second loss in ET is accurate, that's pretty substantial.
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: GEARVENDORS OR 518 [Re: A39Coronet] #2867769
01/01/21 08:27 PM
01/01/21 08:27 PM
Tulsa OK
Tulsa OK
I want to say if you have full manual control of a A500 or A518 you can engage overdrive in 2nd and 3rd? Not positive though.
I would also like to know about power loss with an A500 or 518
Re: GEARVENDORS OR 518 [Re: Bad340fish] #2867782
01/01/21 08:46 PM
01/01/21 08:46 PM
STL ,MO
Handygun Offline
Handygun  Offline
STL ,MO
On the 518 the o/d only comes in after 3rd gear, I have one I ran behind a 392 first gen in a 58 Ply wgn, no lightweight combo and plenty of torque and it never missed a beat, I wouldn't be suprised if it is a parasitic pig though.
Re: GEARVENDORS OR 518 [Re: DaveRS23] #2867787
01/01/21 08:53 PM
01/01/21 08:53 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Comparing 518 OD to GV @ 3,000 RPM cruising, GV is 382 RPM higher (12.7% faster).
Boffin Emeritus
Re: GEARVENDORS OR 518 [Re: A/MP] #2867795
01/01/21 09:07 PM
01/01/21 09:07 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Will GV accept drive & direction from both ends?
Can the mounts be reversed front/rear?
Driveshaft length is the same, U joints are?
See where I'm going?
Can it be used as both 7778:1 overdrive (3.55:1 axle becomes 2.76:1 to kill RPM, reduce gas use, NVH cruising) and by swapping input ends as 1.286:1 underdrive (3.55:1 axle becomes 4.56:1)!!
Easier than changing a ham since you lose no fluid or gaskets, need not pull the axles, etc. The GV is partially subsidized by not buying another 9" center section.
There must be a good reason not to do this that I can't see...
Boffin Emeritus
Re: GEARVENDORS OR 518 [Re: polyspheric] #2867816
01/01/21 09:50 PM
01/01/21 09:50 PM
Kirkland, Washington
Pacnorthcuda Offline
You would be applying power in the opposite rotational direction. I wouldn’t think the gears are cut in such a way as to hold up to that. Don’t know for sure though.
Re: GEARVENDORS OR 518 [Re: Pacnorthcuda] #2867845
01/01/21 10:44 PM
01/01/21 10:44 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Aahhh...
Helical vs. straight cut?
IIRC worms almost lock up if turned backward (some LSD based on it).
It it worked GV would advertise it.
Boffin Emeritus
Re: GEARVENDORS OR 518 [Re: polyspheric] #2867874
01/01/21 11:28 PM
01/01/21 11:28 PM
Tulsa OK
Tulsa OK
Yes they can under or overdrive
Re: GEARVENDORS OR 518 [Re: Bad340fish] #2867926
01/02/21 03:30 AM
01/02/21 03:30 AM
Don Garlits blew part of his right foot off using a overdrive in his last front engine dragster along with cutting the car in half when his homemade O.D. tranny exploded on the starting line the old Lions Drag Strip in 1970 work
Under drive tranny have work well for many, many years up It takes power to overdrive anything anytime scope
