73 Challenger w\440. What to use for radiator #2867097
12/31/20 05:23 PM
12/31/20 05:23 PM
Maine
E
exile5700 Offline OP
E
Maine
I'm sure this has been asked many times. I have a 440- 450 hp and 512 torque. I'm putting it in a 73 Challenger. I'm going to use a 727 transmission, 2400 convertor . What Radiator would work well with it? Best one for the money? Thank you for any help.
Re: 73 Challenger w\440. What to use for radiator [Re: exile5700] #2867220
12/31/20 10:34 PM
12/31/20 10:34 PM
Rochester, New York
GregY Offline
GregY  Offline
Rochester, New York
I have a 1971 Charger that is nearly identical to your combo, I put a 22-inch 2 row aluminum radiator from Ebay in it, with a mechanical fan and shroud, and it cools fine.
Greg
Re: 73 Challenger w\440. What to use for radiator [Re: exile5700] #2867258
01/01/21 12:06 AM
01/01/21 12:06 AM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
look at the rads on e bay from autocity 1958 ,
good price for good rads .
Re: 73 Challenger w\440. What to use for radiator [Re: calrobb2000] #2867267
01/01/21 12:42 AM
01/01/21 12:42 AM
Scranton, PA
Montclaire Offline
Montclaire  Offline
Scranton, PA
How wide is your yoke? 22” or 26”? Glen Ray is the best and has the right size tubes.
Re: 73 Challenger w\440. What to use for radiator [Re: Montclaire] #2867269
01/01/21 01:15 AM
01/01/21 01:15 AM
Star Idaho
67vertman Online rolleyes
67vertman  Online Rolleyes
Star Idaho
I really like my Griffin Radiator, I run a 440 with 515 Hp and 535 Torque, I have been running it for six years no over heating, stock fan and fan shroud.
https://www.griffinrad.com/
My Monster are real!
Living within your means makes life pretty easy.
Re: 73 Challenger w\440. What to use for radiator [Re: calrobb2000] #2867439
01/01/21 12:16 PM
01/01/21 12:16 PM
Rochester, New York
GregY Offline
GregY  Offline
Rochester, New York
Originally Posted by calrobb2000
hi
Mine is an autocity radiator
I went with a 22-inch because that's width of the opening I have, if you have a 26-inch, I would go with that.
Re: 73 Challenger w\440. What to use for radiator [Re: GregY] #2867524
01/01/21 01:45 PM
01/01/21 01:45 PM
Scranton, PA
Montclaire Offline
Montclaire  Offline
Scranton, PA
I had a 73 Challenger with a similar setup that was originally an AC car so it had a 26” yoke. There weren’t a lot of repop radiators at the time so I wound up using one from a 70s truck or van that I found a NOS shroud for. It fit without drilling anything but I had to use the later water pump housing with the pass side discharge. I believe they sell those in aluminum now, too. Never had an issue with it overheating, even with 3.91s.
Re: 73 Challenger w\440. What to use for radiator [Re: exile5700] #2868466
01/03/21 01:15 PM
01/03/21 01:15 PM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
Champion rads are all I use. 6 blade steel fan and shroud. Cheap price and cool just as good as the expensive ones. A cross flow cools better than conventional in My opinion...but look ugly
