Re: Stuck
[Re: 70VERT]
#2866867
12/31/20 09:51 AM
12/31/20 09:51 AM
Posts: 10,931 North Dakota
6PakBee
North Dakota
Short answer, I'd bet it's in the bulkhead connector. You do have an FSM, right? Do you have power to everything else, lights, radio, heater, etc? If so you have power to the ignition switch. Look on the wiring diagram and see if you have power to the starting conductor on the ignition switch when you turn the key to start. This would be on the passenger compartment side. If you do, the switch is good and the wiring to and from the switch is good. Then go to the engine compartment and see if you have power on the same lead when you turn the key to start. My bet is you won't but that is only a bet at this point.
Forgot to ask, manual or automatic? If automatic you could have a problem with the neutral safety switch wiring and have the ignition switch side of it all perfectly functional.
Re: Stuck
[Re: 70VERT]
#2866872
12/31/20 10:14 AM
12/31/20 10:14 AM
Posts: 12,801 Benton, IL.
DaveRS23
Master of nothing...
Benton, IL.
Try bypassing the fusible link. They don't like to be bent or twisted too much at their age.
Master, again and still
Re: Stuck
[Re: stumpy]
#2867212
12/31/20 10:05 PM
12/31/20 10:05 PM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
If you jump the 2 big terminals. You are bypassing the relay and both circuits that feed it. Get a multimeter or test light and check for ground at the small terminal when in Park and Neutral. The other small terminal should be hot when in the start position. Come back with results and we can help you troubleshoot further.
