Push rod oiling #2866667
12/30/20 07:12 PM
12/30/20 07:12 PM
baldwinsville new york
a493demon Offline OP
Does anyone have pics of the push rod oiling set up on a alum. KB block ?
Re: Push rod oiling [Re: a493demon] #2866670
12/30/20 07:15 PM
12/30/20 07:15 PM
Hemi or wedge and which heads?
Re: Push rod oiling [Re: Cab_Burge] #2866754
12/30/20 10:18 PM
12/30/20 10:18 PM
Wedge / B1
Re: Push rod oiling [Re: a493demon] #2866763
12/30/20 10:43 PM
12/30/20 10:43 PM
I haven't used pushrod oiling on a KB aluminum block, I do use pushrod oiling on my current S/P 400 block stroker motor with a set of Indy 440-1 heads that have a set of the Jesel paired shaft rocker arms with no oiling from the heads
I bought a set of Comp Cams AMC solid roller lifters for pushrod oiling and a set of Indy spray bar valve covers and used both on that motor for the first couple weekend racing, I was over oiling the top end so I ended up taking one of the spray bar covers off and block the oil line off that went to that head. I raced it 3 more weekends like that and saw no harm on the side with no spray bar oiling and change the other side to pushrod oiling only and haven't look back up shruggy
I have a set of the original B1 heads back east for freshening right now that came with the Jesel paired shaft rocker arm set up like the 440-1 heads are using so I will probably used the same lifters on it to start with, no spray bar oiling this time luck up Those heads are going on a new KB 4.500 bore size aluminum wedge block (572 C.I.) that I'm hoping I can make close to 900 HP on Oregon 92 octane non ethanol pump swill devil
Re: Push rod oiling [Re: Cab_Burge] #2866768
12/30/20 10:57 PM
12/30/20 10:57 PM
I'm looking for ideas on the way it's plumbed to the lifters .How /what type of distribution block the lines got to .
Re: Push rod oiling [Re: a493demon] #2866777
12/30/20 11:15 PM
12/30/20 11:15 PM
The Comp AMC lifters oil through the stock Mopar oiling system through the sides from the stock lifter bores, does your block have provisions to oil the lifter bores? scope
Mine does with a .060 size hole to the lifer bores shruggy I'm planning on using that system to oil my rocker arms with pushrod oiling luck
Re: Push rod oiling [Re: Cab_Burge] #2866798
12/31/20 12:14 AM
12/31/20 12:14 AM
My KB block doesn't oil through the lifters
Re: Push rod oiling [Re: a493demon] #2866889
12/31/20 11:01 AM
12/31/20 11:01 AM
NC
440Jim Offline
440Jim  Offline
NC
When I bought my KB aluminum block, I paid for the option to have the lifter galleries oil pressurized.
In 2014, they had the oil pressure flow around the rear cam bearing (between a groove in the block and the bearing shell),
then it went up to the lifter galleries.
My understanding of the newer blocks (see new picture here) is the yellow lines.
Re: Push rod oiling [Re: 440Jim] #2866919
12/31/20 11:53 AM
12/31/20 11:53 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
When I ordered my keith black block I messed up and didn’t have it drilled for pushrod oiling. Tom Hemphill 30 miles from me in pa drilled it for me and fixed me up.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Push rod oiling [Re: a493demon] #2867437
01/01/21 12:14 PM
01/01/21 12:14 PM
NY
challenger451ci Offline
NY
I could email you some pictures of how I did my Indy Maxx block if you're interested.
Re: Push rod oiling [Re: challenger451ci] #2867540
01/01/21 02:01 PM
01/01/21 02:01 PM
Thanks for the pics
Re: Push rod oiling [Re: challenger451ci] #2867593
01/01/21 02:50 PM
01/01/21 02:50 PM
Washington
hemienvy Offline
hemienvy  Offline
Washington
Challenger451,
Did you do that distribution block work yourself ?
I am in the same boat, I have an older KB block with no lifter gallies,
only way to do it is what you did.
Re: Push rod oiling [Re: hemienvy] #2867681
01/01/21 05:28 PM
01/01/21 05:28 PM
NY
NY
Originally Posted by hemienvy
Challenger451,
Yessir. I think I had about 40hrs into the whole project. Indy's price was around $800.00 to drill the block for pushrod oiling and I was trying to keep costs down where I could so I decided to do it this way. If I were to start over today, I'd gladly pay them the $800 to have it done. smile
I used a 0.040 nitrous jet in each of the feeds. My theory there was if I tossed a lifter, I wouldn't lose oil pressure. I just broke a rocker this fall and only lost a few psi of oil pressure so I guess it worked. I'm having the lifter bores bushed over the winter because the one that got tossed ended up gouging the bore.
Re: Push rod oiling [Re: challenger451ci] #2869422
01/05/21 05:25 PM
01/05/21 05:25 PM
Washington
hemienvy Offline
hemienvy  Offline
Washington
Thanks Challenger, sorry for the late reply.
I guess it won't be that expensive but sure will be time consuming.
It looks like the tubes are Nickel-Copper, NiCopp is quite easy to bend and flare.
Re: Push rod oiling [Re: hemienvy] #2869698
01/06/21 01:57 PM
01/06/21 01:57 PM
NY
NY
That's correct, I used Ni-Copp tubing and it was pretty easy to work with. The fittings on the block side are 1/16" NPT x -03 AN, I think from Fragola. I cut the AN side down so 0.040" a flare jet can be inserted to mate up with a flare fitting and provide a restriction. That might have bene overkill, but I was already into the project for so many hours, I figured a couple more won't hurt.... smile
Re: Push rod oiling [Re: a493demon] #2869712
01/06/21 02:29 PM
01/06/21 02:29 PM
WA
JD Dart Offline
JD Dart  Offline
WA
Here is how I did my Indy Block same concept sent it to the machine shop to have them drill the holes then I plumb it after that works great. Note the the section I welded on the inlet side it acts as an accumulator so the oil flows evenly to all the lifter and push rods.
best so far 8.53 @ 158.59 MPH 60'1.240
Re: Push rod oiling [Re: JD Dart] #2869747
01/06/21 03:14 PM
01/06/21 03:14 PM
Washington
hemienvy Offline
hemienvy  Offline
Washington
JD, I like it. Lot of work, no way around it.
Re: Push rod oiling [Re: hemienvy] #2869751
01/06/21 03:17 PM
01/06/21 03:17 PM
an8sec70cuda Offline
Stupid question...what situation/combo requires pushrod oiling? Or is just a preference?
The stuff I've messed w/ has all been conventional oiling.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Push rod oiling [Re: an8sec70cuda] #2869764
01/06/21 03:43 PM
01/06/21 03:43 PM
PA.
"Little"John
"Little"John
PA.
One question why didn’t you guys just use number three stainless flex lines. Sure would save a lot of work.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Push rod oiling [Re: an8sec70cuda] #2869890
01/06/21 05:18 PM
01/06/21 05:18 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
Paired T and D individual shaft rockers need pushrod oiling.
....BAD A$$ STREET CAR.....
Re: Push rod oiling [Re: n20mstr] #2869930
01/06/21 06:05 PM
01/06/21 06:05 PM
WA
JD Dart Offline
JD Dart  Offline
WA
Yea what he said plus when you go to bushed on the roller for the lifter they need oil.
Re: Push rod oiling [Re: JD Dart] #2870196
01/07/21 12:17 AM
01/07/21 12:17 AM
NY
NY
I mostly did it because I wanted to run Crower HIPPO lifters that pressure feed the roller axles.
Re: Push rod oiling [Re: n20mstr] #2870260
01/07/21 09:09 AM
01/07/21 09:09 AM
Gotcha...no other way to get oil to the other 3 shafts if they are separate, unless you have spray bars. The B1 motors I've messed with were common shaft w/ T&D rockers.
Spray bars in the valve covers seem like a simpler solution, but I guess they aren't as effective?
I've always liked the fact that my KB block doesn't oil the lifters. After 14 years I've had no issues, but my cam isn't aggressive either.
CHIP
