LCA bushing "outer shell" for Energy Suspension bushings #2866037
12/29/20 01:23 PM
12/29/20 01:23 PM
D/FW
gts95 Offline OP
gts95  Offline OP
D/FW
So I'm rebuilding the front suspension on my 70 Super Bee and will be doing the LCA bushings. I have a brand new set of Energy Suspension control arm bushings that have been in the garage for years.....it appears they work on both upper and lower control arms. Part # 5.3112G
For LCA use it states "must reuse outer metal shell". The is my first time doing this.....from the videos Im watching on Youtube it seems like people are welding washers to their old bushings and pressing them out. Where is this "outer shell"?? Is this not part of what gets pressed out? I don't see how I can remove my old bushings without damaging this outer shell?
1970 Super Bee, WM21, 383, auto, FY1, a/c, project! 1971 Chrysler 300 2dr, U-code, console car 1980 Chrysler LeBaron LS Limited coupe 2008 Chrysler Aspen, HEMI 2011 Ram 3500 MegaCab, 6.7
Re: LCA bushing "outer shell" for Energy Suspension bushings [Re: gts95] #2866069
12/29/20 02:45 PM
12/29/20 02:45 PM
Los Osos, Ca
CKessel Offline
CKessel  Offline
Los Osos, Ca
Put some heat to the inner sleeve of the bushing.
Carl Kessel
Re: LCA bushing "outer shell" for Energy Suspension bushings [Re: CKessel] #2866115
12/29/20 04:35 PM
12/29/20 04:35 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Typical bushing construction, outer shell, rubber, inner sleeve. Take a press and press the inner sleeve out. Then cut the rubber out leaving the outer shell in the LCA.
Re: LCA bushing "outer shell" for Energy Suspension bushings [Re: 6PakBee] #2866286
12/30/20 12:56 AM
12/30/20 12:56 AM
D/FW
gts95 Offline OP
gts95  Offline OP
D/FW
This is what the Energy Suspension kit looks like. From what I gather the upper and lower control arm bushings are the same.....except for this outer shell mentioned. I'm not sure where the two black urethane bushings belong?
So these new bushings press fit into the original metal shell of the original bushing? Seems strange am I understanding that right? Has anybody used these?
Re: LCA bushing "outer shell" for Energy Suspension bushings [Re: gts95] #2866294
12/30/20 02:02 AM
12/30/20 02:02 AM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
Back up. The Gold cad plated stuff in your pic are all UCA bushings and they are identical to each other.......put them aside. The two LCA bushings are used on the LCA arms as already described, into the original outer shells that will remain in the LCA’s after you press the innards out.
Re: LCA bushing "outer shell" for Energy Suspension bushings [Re: gts95] #2866295
12/30/20 02:03 AM
12/30/20 02:03 AM
D/FW
gts95 Offline OP
gts95  Offline OP
D/FW
OK I'm realizing the black urethane bushings ARE the bushings for the LCA!? And the other four are for the upper LCA. After reading all the threads on here about the issues with these urethane bushings I'm thinking just go with the stock type rubber bushing. Or perhaps the Proforged urethane bushings which at least come complete with the shell.
Re: LCA bushing "outer shell" for Energy Suspension bushings [Re: gts95] #2866298
12/30/20 02:28 AM
12/30/20 02:28 AM
I agree. I’m not a fan of the Energy Suspension lower bushings...I used them on a 70 Cuda 25 years ago..never again. Stock type are much better...but make damn sure you torque the LCA pins down with the suspension loaded!
Re: LCA bushing "outer shell" for Energy Suspension bushings [Re: 6PakBee] #2866481
12/30/20 02:09 PM
12/30/20 02:09 PM
moparx Offline
moparx  Offline
6pak, what catalog did your bushing spec page come from ? TIA
beer
Re: LCA bushing "outer shell" for Energy Suspension bushings [Re: moparx] #2866871
12/31/20 10:00 AM
12/31/20 10:00 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
beer
These guys.
AV Products Inc.
Re: LCA bushing "outer shell" for Energy Suspension bushings [Re: 6PakBee] #2866998
12/31/20 02:29 PM
12/31/20 02:29 PM
moparx Offline
moparx  Offline
there are a bunch of items there that interest me !
Thank You Sir ! bow
beer
