Question for the Electricians on 110V
#2865604
12/28/20 10:08 AM
12/28/20 10:08 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I was changing a dimmer switch yesterday and ended up blowing a $30 switch.. this a dimmer with 2 locations to turn it on or off... what I have for wire colors... I have one green(ground).. one red.. single black.. and a cluster of 3 black together then the whites not attached to the switch.. with the switch in the upright position I have 2 screws(left and right side of the switch..both brass color... then lower on the right side I have a copper color screw.. can some one give me some idea what I did wrong so I can buy a new switch today and get this done.. I am headed out to Texas for the next 3 months(winter Texans) leaving tomorrow... THANKS for your help ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
Re: Question for the Electricians on 110V
[Re: MR_P_BODY]
#2865652
12/28/20 12:21 PM
12/28/20 12:21 PM
Posts: 374 Alberta, Canada
300rag
Alberta, Canada
The switch that I took out had 2 red wires and a black ..green(ground) In your original post the number and colour counts don't match up with this.
Peter
'65 300 'vert 413/4spd '18 Challenger R/T Shaker '19 Durango R/T
[Re: 300rag]
#2865656
12/28/20 12:41 PM
12/28/20 12:41 PM
MR_P_BODY
The switch that I took out had 2 red wires and a black ..green(ground) In your original post the number and colour counts don't match up with this. This is true.. I am confused on what goes where now... both switches have a total of 4 wires with one being green(ground)... the original switch has 2 red.. one black and the green... the replacement one is the above pic.. I replaced this switch 20 years ago and had a issue back then and have forgot what I did back then....Thanks guys ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: MR_P_BODY]
#2865659
12/28/20 12:59 PM
12/28/20 12:59 PM
300rag
Alberta, Canada
The switch that I took out had 2 red wires and a black ..green(ground) In your original post the number and colour counts don't match up with this. This is true.. I am confused on what goes where now... both switches have a total of 4 wires with one being green(ground)... the original switch has 2 red.. one black and the green... the replacement one is the above pic.. I replaced this switch 20 years ago and had a issue back then and have forgot what I did back then....Thanks guys Based on the description of the group of 3 black wires, my instinct is that this is the power feed that goes to the odd-colour screw (common), and the two single wires are the travellers between the two switches that need to be connected to the two same-colour screws. That said, the only real way to be sure is to use a meter to check.
Peter
[Re: 300rag]
#2865663
12/28/20 01:08 PM
12/28/20 01:08 PM
MR_P_BODY
The switch that I took out had 2 red wires and a black ..green(ground) In your original post the number and colour counts don't match up with this. This is true.. I am confused on what goes where now... both switches have a total of 4 wires with one being green(ground)... the original switch has 2 red.. one black and the green... the replacement one is the above pic.. I replaced this switch 20 years ago and had a issue back then and have forgot what I did back then....Thanks guys Based on the description of the group of 3 black wires, my instinct is that this is the power feed that goes to the odd-colour screw (common), and the two single wires are the travellers between the two switches check that need to be connected to the two same-colour screws. That said, the only real way to be sure is to use a meter to check. I used my VOM to check for power yesterday.. I can check for common today.. you believe the common goes to the copper color screw... where would the red go... thanks ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: second 70]
#2865673
12/28/20 01:36 PM
12/28/20 01:36 PM
MR_P_BODY
Best thing to do is look at other switch. If the 2 red are on the top 2 screws and black on bottom do same to new switch. Black wire will only be hot to bottom of 1 switch the other goes to light. If after installing you can't turn the light on and off with either switch all you have to do is flop the 2 red wires on new switch. On the original switch the wires are molded into the housing(no screws).. the wife got got me a new switch and I will try this again... any more help would be great... I dont want to fry this new switch... not at $30 a pop... thanks much ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: MR_P_BODY]
#2865749
12/28/20 03:34 PM
12/28/20 03:34 PM
Posts: 1,497 North East USA
BIGGERED
Reasonable Title
Reasonable Title
North East USA
Well just blew another switch......screw this crap... I'll get my buddy over here when we get back from vacation... not wasting $30 a pop I had an issue with slider dimmers on three way switches. Next door neighbor is a retired "electrician" from the power company. He jacked it up worse by messing with both switches. There was no need to open up the other switch as I had left it alone. He couldn't figure it out so my residential electrician friend sorted it out in five minutes. I do not think I am stupid and can read electrical schematic but the poor excuse for a schematic on 3 way switch packaging is confounding.
[Re: BIGGERED]
#2865766
12/28/20 04:09 PM
12/28/20 04:09 PM
MR_P_BODY
Well just blew another switch......screw this crap... I'll get my buddy over here when we get back from vacation... not wasting $30 a pop I had an issue with slider dimmers on three way switches. Next door neighbor is a retired "electrician" from the power company. He jacked it up worse by messing with both switches. There was no need to open up the other switch as I had left it alone. He couldn't figure it out so my residential electrician friend sorted it out in five minutes. I do not think I am stupid and can read electrical schematic but the poor excuse for a schematic on 3 way switch packaging is confounding. Yes it is... they say tape/mark the common in the pic but in my mind common is the white... but the white is not use.. I originally never touched it ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: MR_P_BODY]
#2866018
12/29/20 12:33 PM
12/29/20 12:33 PM
300rag
Alberta, Canada
... but in my mind common is the white...
In this scenario "common" is not white, but a reference to the terminals on the switches. The common on one switch is the power in, and the common on the other switch is the load (light). This is the one screw that is a different colour than the other two. The other two same coloured screws are the travelers between the two switches, as seen in the diagram.
Peter
[Re: 300rag]
#2866026
12/29/20 12:52 PM
12/29/20 12:52 PM
Posts: 3,623 Millinocket, Maine
JonC
Millinocket, Maine
The problem is there are at least three different arrangements to wire a three way (with a single light). Without seeing how the original wiring is, it would be almost impossible to walk someone with limited knowledge through it. I know a couple Master Electrician in my area that can't even do the simple way to do it. Again, without determining how the wires are run it will be difficult to walk anyone through it. JMHO
11B40
[Re: JonC]
#2866055
12/29/20 02:00 PM
12/29/20 02:00 PM
Posts: 2,673 Northern MN
1E2C
Northern MN
The problem is there are at least three different arrangements to wire a three way (with a single light). Without seeing how the original wiring is, it would be almost impossible to walk someone with limited knowledge through it. I know a couple Master Electrician in my area that can't even do the simple way to do it. Again, without determining how the wires are run it will be difficult to walk anyone through it. JMHO Oh, such a totally accurate statement..
