Question for the Electricians on 110V #2865604
12/28/20 10:08 AM
12/28/20 10:08 AM
MR_P_BODY Offline OP
I was changing a dimmer switch yesterday and ended up blowing a $30 switch.. this a dimmer with 2 locations
to turn it on or off... what I have for wire colors... I have one green(ground).. one red.. single black.. and a
cluster of 3 black together then the whites not attached to the switch.. with the switch in the upright position
I have 2 screws(left and right side of the switch..both brass color... then lower on the right side I have a copper
color screw.. can some one give me some idea what I did wrong so I can buy a new switch today and get this done..
I am headed out to Texas for the next 3 months(winter Texans) leaving tomorrow... THANKS for your help
wave
Re: Question for the Electricians on 110V [Re: MR_P_BODY] #2865607
12/28/20 10:21 AM
12/28/20 10:21 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
The wiring diagrams that come with the switches are really helpful !!
Re: Question for the Electricians on 110V [Re: MR_P_BODY] #2865608
12/28/20 10:23 AM
12/28/20 10:23 AM
Eau Claire, WI
Charger727 Offline
Charger727  Offline
Eau Claire, WI
Sounds like you bought a 2-way switch, when you needed a 3-way switch - only a guess
Re: Question for the Electricians on 110V [Re: Charger727] #2865614
12/28/20 10:31 AM
12/28/20 10:31 AM
Said on the package for light switches from 2 locations
wave
Re: Question for the Electricians on 110V [Re: MR_P_BODY] #2865619
12/28/20 10:42 AM
12/28/20 10:42 AM
The switch that I took out had 2 red wires and a black ..green(ground)
Re: Question for the Electricians on 110V [Re: MR_P_BODY] #2865652
12/28/20 12:21 PM
12/28/20 12:21 PM
Alberta, Canada
300rag Offline
300rag  Offline
Alberta, Canada
In your original post the number and colour counts don't match up with this.
Peter
'65 300 'vert 413/4spd
'18 Challenger R/T Shaker
'19 Durango R/T
Re: Question for the Electricians on 110V [Re: 300rag] #2865656
12/28/20 12:41 PM
12/28/20 12:41 PM
This is true.. I am confused on what goes where now... both switches have a total of 4 wires
with one being green(ground)... the original switch has 2 red.. one black and the green...
the replacement one is the above pic.. I replaced this switch 20 years ago and had a issue
back then and have forgot what I did back then....Thanks guys
wave
Re: Question for the Electricians on 110V [Re: MR_P_BODY] #2865659
12/28/20 12:59 PM
12/28/20 12:59 PM
Alberta, Canada
300rag Offline
300rag  Offline
Alberta, Canada
wave
Based on the description of the group of 3 black wires, my instinct is that this is the power feed that goes to the odd-colour screw (common), and the two single wires are the travellers between the two switches that need to be connected to the two same-colour screws. That said, the only real way to be sure is to use a meter to check.
Peter
'19 Durango R/T
Re: Question for the Electricians on 110V [Re: 300rag] #2865663
12/28/20 01:08 PM
12/28/20 01:08 PM
wave
Based on the description of the group of 3 black wires, my instinct is that this is the power feed that goes to the odd-colour screw (common), and the two single wires are the travellers between the two switches check that need to be connected to the two same-colour screws. That said, the only real way to be sure is to use a meter to check.
I used my VOM to check for power yesterday.. I can check for common today.. you believe the common goes
to the copper color screw... where would the red go... thanks
wave
Re: Question for the Electricians on 110V [Re: MR_P_BODY] #2865665
12/28/20 01:15 PM
12/28/20 01:15 PM
central il.
second 70 Online content
second 70  Online Content
central il.
Best thing to do is look at other switch. If the 2 red are on the top 2 screws and black on bottom do same to new switch. Black wire will only be hot to bottom of 1 switch the other goes to light. If after installing you can't turn the light on and off with either switch all you have to do is flop the 2 red wires on new switch.
Re: Question for the Electricians on 110V [Re: second 70] #2865673
12/28/20 01:36 PM
12/28/20 01:36 PM
On the original switch the wires are molded into the housing(no screws).. the wife got got me a new switch
and I will try this again... any more help would be great... I dont want to fry this new switch... not at $30
a pop... thanks much
wave
Re: Question for the Electricians on 110V [Re: MR_P_BODY] #2865687
12/28/20 01:55 PM
12/28/20 01:55 PM
Well just blew another switch......screw this crap... I'll get my buddy over here when we get back from
vacation... not wasting $30 a pop down
wave
Re: Question for the Electricians on 110V [Re: MR_P_BODY] #2865747
12/28/20 03:31 PM
12/28/20 03:31 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Pull the switch plates off both switches. Disconnect ALL wires from both switches except the grounds. Determine which are "hot" (black) and "common" (white). There will only be ONE hot in one box - the rest run off that one. There will be a red wire in each box as well. Now that all are disconnect and you know which is "hot" just follow the switch wiring diagram.
Re: Question for the Electricians on 110V [Re: MR_P_BODY] #2865749
12/28/20 03:34 PM
12/28/20 03:34 PM
North East USA
BIGGERED Offline
Reasonable Title
BIGGERED  Offline
Reasonable Title
North East USA
wave
I had an issue with slider dimmers on three way switches. Next door neighbor is a retired "electrician" from the power company. He jacked it up worse by messing with both switches.
There was no need to open up the other switch as I had left it alone. He couldn't figure it out so my residential electrician friend sorted it out in five minutes.
I do not think I am stupid and can read electrical schematic but the poor excuse for a schematic on 3 way switch packaging is confounding.
Re: Question for the Electricians on 110V [Re: BIGGERED] #2865766
12/28/20 04:09 PM
12/28/20 04:09 PM
wave
Yes it is... they say tape/mark the common in the pic but in my mind common is the white... but
the white is not use.. I originally never touched it
wave
Re: Question for the Electricians on 110V [Re: MR_P_BODY] #2865955
12/29/20 07:14 AM
12/29/20 07:14 AM
Port Huron, Michigan
MI_Custumz Offline
MI_Custumz  Offline
I am by no means an electrician. But whenever I pull out a switch or plug, I take photos. I may not take photos if it's been done before and I get the concept. I also compare the plugs and labeling before removing stuff. There was a member here who helped me install a GFCI with great instructions via PM. Maybe he will chime in.
Re: Question for the Electricians on 110V [Re: MR_P_BODY] #2866018
12/29/20 12:33 PM
12/29/20 12:33 PM
Alberta, Canada
300rag Offline
300rag  Offline
Alberta, Canada
... but in my mind common is the white...
In this scenario "common" is not white, but a reference to the terminals on the switches. The common on one switch is the power in, and the common on the other switch is the load (light). This is the one screw that is a different colour than the other two. The other two same coloured screws are the travelers between the two switches, as seen in the diagram.
Peter
'19 Durango R/T
Re: Question for the Electricians on 110V [Re: 300rag] #2866026
12/29/20 12:52 PM
12/29/20 12:52 PM
Millinocket, Maine
JonC Offline
JonC  Offline
Millinocket, Maine
The problem is there are at least three different arrangements to wire a three way (with a single light). Without seeing how the original wiring is, it would be almost impossible to walk someone with limited knowledge through it. I know a couple Master Electrician in my area that can't even do the simple way to do it. Again, without determining how the wires are run it will be difficult to walk anyone through it. JMHO
11B40
Re: Question for the Electricians on 110V [Re: JonC] #2866055
12/29/20 02:00 PM
12/29/20 02:00 PM
Northern MN
1E2C Offline
1E2C  Offline
Northern MN
Oh, such a totally accurate statement..
Re: Question for the Electricians on 110V [Re: MR_P_BODY] #2866093
12/29/20 03:35 PM
12/29/20 03:35 PM
CO
Redbird Offline
Redbird  Offline
CO
I would not think of rewiring a switch that I did not understand, then leave town for 3 months.
Perhaps it is time to turn off the breaker to that circuit before you leave town?
As someone else mentioned, taking pictures before disassembly is your friend.
