Water testing a Hemi #2865834
12/28/20 07:43 PM
12/28/20 07:43 PM
STL
cdstl Offline OP
cdstl  Offline OP
STL
I guess.
I took a picture of a picture today of what looks like the WT of a Hemi.
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
Re: Water testing a Hemi [Re: cdstl] #2865848
12/28/20 08:09 PM
12/28/20 08:09 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
So....
.......what exactly was water testing? Pressurizing the system and see if holds a bleed down spec?
Re: Water testing a Hemi [Re: Pacnorthcuda] #2865854
12/28/20 08:33 PM
12/28/20 08:33 PM
okla.
sam64 Offline
sam64  Offline
okla.
That exhaust manifold ! Oh Lord!
Re: Water testing a Hemi [Re: sam64] #2865877
12/28/20 09:20 PM
12/28/20 09:20 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
"Yup, no water outta the carbs - she's good !" laugh2
Re: Water testing a Hemi [Re: topside] #2865895
12/28/20 10:15 PM
12/28/20 10:15 PM
Illinois, USA
superbee69 Offline
superbee69  Offline
Illinois, USA
CROSS RAM NO LESS
Re: Water testing a Hemi [Re: Pacnorthcuda] #2865952
12/29/20 05:27 AM
12/29/20 05:27 AM
STL
cdstl Offline OP
cdstl  Offline OP
STL
Originally Posted by Pacnorthcuda
So....
I have no idea. Except that whenever you see a Hemi block talked about or put up for sale, they make a point to mention the WT on the engine pad.
Re: Water testing a Hemi [Re: cdstl] #2865959
12/29/20 08:07 AM
12/29/20 08:07 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Considering the exhaust is hooked up to it maybe that is some kind of run stand? Those manifolds are terrible but would be just fine for firing one up for a moment.
68 Barracuda Formula S 340
Re: Water testing a Hemi [Re: Bad340fish] #2865962
12/29/20 08:35 AM
12/29/20 08:35 AM
STL
cdstl Offline OP
cdstl  Offline OP
STL
You are probably correct.
Re: Water testing a Hemi [Re: cdstl] #2865963
12/29/20 08:39 AM
12/29/20 08:39 AM
STL
cdstl Offline OP
cdstl  Offline OP
STL
From what little that I know, it does not appear to be a K head.
So would this be a 1966 later image?
Re: Water testing a Hemi [Re: cdstl] #2865964
12/29/20 08:41 AM
12/29/20 08:41 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
Is there a dyno attached we cannot see in the picture?
I wonder what percent over operating pressure it was tested to?
If it passed the WT did they then run the Hemi up to rated TQ and HP in stages?
Remember the scandal about “hammering” the new Gen III 5.7 Hemi on the company dynos to loosen the rings so that an advertising claim of “one horsepower per cubic inch” could be made as planned? Toyota, GM, Ford and Nissan all claimed their dyno tests showed 20 less HP than 345 HP that Chrysler claimed. SAE revised their official dyno test rules afterwards.
Re: Water testing a Hemi [Re: cdstl] #2865996
12/29/20 11:06 AM
12/29/20 11:06 AM
Yes
sixpakdodge Offline
sixpakdodge  Offline
Yes
1964...it has Carters on it. Either a very early SS motor, or one of the Hardtop Hemi pieces.
Re: Water testing a Hemi [Re: Bad340fish] #2866073
12/29/20 02:51 PM
12/29/20 02:51 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
iagree From what I understand, water testing was done on the bare block.
Re: Water testing a Hemi [Re: John_Kunkel] #2866100
12/29/20 03:52 PM
12/29/20 03:52 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I think the photo is of another test set-up, maybe the initial light-off test.
Looks like K heads to me, front of valve cover is straight.
Carters would be an early deal; after a winter test at Lions Drag Strip they switched to Holleys.
There are photos of that drag test on the web; they compared Maxie Stage 3 to the new Hemi.
Re: Water testing a Hemi [Re: topside] #2866205
12/29/20 08:30 PM
12/29/20 08:30 PM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
I just copied all of this & sent around to some old retired Chrysler engineers. Their responses should be interesting!
Re: Water testing a Hemi [Re: Sunroofcuda] #2866240
12/29/20 10:08 PM
12/29/20 10:08 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
The exhaust is the 64 race Hemi manifolds, butchered up to be able to use on the dyno. I would guess that this was a very very early fire up and run test, maybe some durability testing. But not a real horsepower test with that exhaust system.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Water testing a Hemi [Re: topside] #2866318
12/30/20 07:39 AM
12/30/20 07:39 AM
STL
cdstl Offline OP
cdstl  Offline OP
STL
K heads have the curve, if I'm not mistaken. But I guess that it wouldn't be visible in this shot.
Re: Water testing a Hemi [Re: cdstl] #2866336
12/30/20 08:55 AM
12/30/20 08:55 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
Those are k heads, crossrammed and carters. I’d say that was an early test fire for for a 64 race hemi.
Re: Water testing a Hemi [Re: fastmark] #2866372
12/30/20 10:29 AM
12/30/20 10:29 AM
blewbyu Offline
blewbyu  Offline
Just image that was you at the plant and your job was to test fire Hemi Motors !!! boogie He had no idea when that photo was taken how the world would change once those monsters were released to the public. drive
Re: Water testing a Hemi [Re: blewbyu] #2866458
12/30/20 01:26 PM
12/30/20 01:26 PM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
Here's some replies I received so far (these were Chrysler engineers who were in the thick of all things racing & high-performance back in the day):
Hot test at M&I.Early Cross ram A990 motor.
For what it’s worth the Spark plug wire boots look like early 64/65 race Hemi that are total different than 66 up street Again the picture is not that clear on my I phone.
I’ve guessed about this before, I’ve always thought the early gen two engines where built in Marysville at the MCI plant. This looks like 64, carter carbs and K heads. It’s a hot test stand. Probably no load and I have no idea what kind of instrumentation they had on it. I know at Trenton, when Al Nichols worked on their hot test set up, they had lots of pressure and temp channels to make sure all was good to go. And of course, look for oil and coolant leaks.
I’ll second Greg’s thoughts. I have seen this picture before, as well and the consciences is this is a hot test at M & I, where some of the Hemis were built.
Re: Water testing a Hemi [Re: John_Kunkel] #2866472
12/30/20 01:57 PM
12/30/20 01:57 PM
moparx Offline
moparx  Offline
where i worked, we water tested gas field pipeline meters after the machining process was complete, but before assembly.
the main body castings and tops were tested to 4000lbs. the working pressure of the meters was 1400lbs max.
john would be correct. a water test would be done on a bare block, not an assembled one.
beer
