Re: Electronic ignition question
[Re: TJP]
#2864759
12/25/20 08:54 PM
12/25/20 08:54 PM
Posts: 4,715 Wichita
GY3
Wichita
You are likely to get differing opinions but I like the factory stuff, especially when it comes to diagnosing (if needed) and availability /cost of parts. get stuck somewhere on a roadie with that MSD and your up schitt creek without a paddle LOL, 6AL's are everywhere in every town. Much more likely to turn one up than you are a Mopar style ECU at a parts store anymore. When you do find one it's an overseas unit that probably won't work very long if at all. Things aren't the same as they were 10 years ago. The things that make the MSD head and shoulders above the Mopar unit is the additonal features. It comes with a rev limiter that you can tailor to your needs and you can plug in things like two steps and timing controllers. I can adjust my timing from the drivers seat.
[Re: 71birdJ68]
#2864842
12/26/20 10:31 AM
12/26/20 10:31 AM
Posts: 10,777 North Dakota
6PakBee
North Dakota
MSD and the Mopar units are now made in china, so reliability is down the drain. Either points, or Pertronix would be the choice. Unfortunately I think there is no real way out. Why are Chinese electronics substandard, because they use substandard components. Where are you going to find better components? Most of them are made in China too. So a USA manufactured unit using Chinese components probably wouldn't be any better. I wish someone had the internal schematic for the Mopar ECU, someone handy with electronics could probably improve on it AND dig up quality components. Remember, even back in '72 everything in them was low bid!
[Re: 68SportSatvert]
#2864844
12/26/20 10:50 AM
12/26/20 10:50 AM
Posts: 4,768 Moved to N.E. Tennessee
GomangoCuda
I am going to say go with the GM HEI conversion. The HEI module is more reliable, more powerful, more available and less expensive than any Mopar box. Kind of a win, win, win, win.
Edit:. I see there is another thread where the HEI is slammed so I guess you have to take this suggestion with a grain of salt. Or find some old modules just like you need to do with Mopar ecu's.
[Re: 6PakBee]
#2864954
12/26/20 03:26 PM
12/26/20 03:26 PM
Posts: 26,036 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Why are Chinese electronics substandard, because they use substandard components. I wonder if that's true across the board. Many of us can remember when anything from Japan was junk and now they're known for quality. At some point in time they were shamed into improving their products, China might be doing the same...especially when an American company monitors quality control. ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif)
[Re: John_Kunkel]
#2864957
12/26/20 03:40 PM
12/26/20 03:40 PM
Posts: 10,228 Colleyville
3hundred
Colleyville
Why are Chinese electronics substandard, because they use substandard components. I wonder if that's true across the board. Many of us can remember when anything from Japan was junk and now they're known for quality. At some point in time they were shamed into improving their products, China might be doing the same...especially when an American company monitors quality control. Japan had Edwards Deming, all China has is cheap labor and thievery. Vietnam and Malaysia have even cheaper labor. 2¢
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
[Re: GY3]
#2865060
12/26/20 09:08 PM
12/26/20 09:08 PM
Posts: 15,565 Omaha Ne
TJP
Omaha Ne
You are likely to get differing opinions but I like the factory stuff, especially when it comes to diagnosing (if needed) and availability /cost of parts. get stuck somewhere on a roadie with that MSD and your up schitt creek without a paddle LOL, 6AL's are everywhere in every town. Much more likely to turn one up than you are a Mopar style ECU at a parts store anymore. When you do find one it's an overseas unit that probably won't work very long if at all. Things aren't the same as they were 10 years ago. The things that make the MSD head and shoulders above the Mopar unit is the additonal features. It comes with a rev limiter that you can tailor to your needs and you can plug in things like two steps and timing controllers. I can adjust my timing from the drivers seat. As I stated You are likely to get differing opinions , And I would put 100.00 bet on the availability of a Mopar ECU vs an MSD unit at a parts store in city with a population of less than say 10,000 or even 300,000 ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif) ![ozbbq ozbbq](/ubbthreads/images/graemlins/custom/OzBBQed.gif)
[Re: TJP]
#2865085
12/26/20 09:59 PM
12/26/20 09:59 PM
Posts: 6,356 nowhere
Sniper
nowhere
You are likely to get differing opinions but I like the factory stuff, especially when it comes to diagnosing (if needed) and availability /cost of parts. get stuck somewhere on a roadie with that MSD and your up schitt creek without a paddle LOL, 6AL's are everywhere in every town. Much more likely to turn one up than you are a Mopar style ECU at a parts store anymore. When you do find one it's an overseas unit that probably won't work very long if at all. Things aren't the same as they were 10 years ago. The things that make the MSD head and shoulders above the Mopar unit is the additonal features. It comes with a rev limiter that you can tailor to your needs and you can plug in things like two steps and timing controllers. I can adjust my timing from the drivers seat. As I stated You are likely to get differing opinions , And I would put 100.00 bet on the availability of a Mopar ECU vs an MSD unit at a parts store in city with a population of less than say 10,000 or even 300,000 ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif) Keep your money. My hometown is less than 100k. O'reilly has a stock type ECU in stock, Autozone has a 6AL in stock.
[Re: John_Kunkel]
#2865281
12/27/20 02:39 PM
12/27/20 02:39 PM
6PakBee
North Dakota
Why are Chinese electronics substandard, because they use substandard components. I wonder if that's true across the board. Many of us can remember when anything from Japan was junk and now they're known for quality. At some point in time they were shamed into improving their products, China might be doing the same...especially when an American company monitors quality control. John, I wish you were right. My prime example is ignition condensers. Where do you get a quality one today?
[Re: 6PakBee]
#2865449
12/27/20 09:06 PM
12/27/20 09:06 PM
TJP
Omaha Ne
Why are Chinese electronics substandard, because they use substandard components. I wonder if that's true across the board. Many of us can remember when anything from Japan was junk and now they're known for quality. At some point in time they were shamed into improving their products, China might be doing the same...especially when an American company monitors quality control. John, I wish you were right. My prime example is ignition condensers. Where do you get a quality one today? maybe Accel or old stock on Ebay ?? And keep in mind a lot of our phones, computers and their components, TV's etc. come from ? yep China
[Re: mopower440]
#2865611
12/28/20 10:26 AM
12/28/20 10:26 AM
6PakBee
North Dakota
I installed the HEI 4 pin module inside a gutted mopar ECU box. Looks stock and the car fires up much easier than it ever did with the mopar box. I just bought a cheap HEI module from oreillys and it does fine. Now that is thinking outside the box! ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
